Results 1 to 10 of 10
    Sep 28 2010
    Phoenix, AZ
    Car doesnt want to go over 4000 rmps?
    2001 Audi S4 has a Twin 1 and X-1 intake and 710N DVs and new NGK copper spark plugs and a MTM chip. Driving normal up to 4K then hesitates and wont want to keep climbing rpms. Any ideas? No codes on VAGcom.
    Established Member Two Rings ilovemycar's Avatar
    Feb 04 2010
    Western WA
    I just had an issue this morning, and found out it's a bad maf, try unplugging yours and see if it helps
    Sep 28 2010
    Phoenix, AZ
    Tried a brand new MAF, same problem.
    Feb 04 2010
    Western WA
    Maybe a vacuum leak? Boost leak?
    Feb 28 2011
    Greenwood SC
    Quote Originally Posted by ilovemycar View Post
    I second this. the TBB would be a good place to start.
    Sep 28 2010
    Phoenix, AZ
    Pure Motorsports is going to do a smoke test on Thursday. Just was wondering if someone else had a similar problem that wasn't a boost/vacuum leak.
    Sep 28 2010
    Phoenix, AZ
    No visible tears on TTB, they are going to remove it and inspect it more closely. The stock DVs were shot so they were replaced with 710Ns.
    Veteran Member Three Rings bl0wn3ur0's Avatar
    Jul 22 2008
    NY/PA
    I had a messed up wire from the speed sensor on the trans and the car wouldn't rev past 5k. Obviously my speedo didn't work either so you'd notice that if this was your problem but I just figured I mention it.
    Sep 28 2010
    Phoenix, AZ
    Thanks, but my speedo works fine.
    Sep 28 2010
    Phoenix, AZ
    Problem solved. TBB had a tear where the clamp goes, so you won't notice it unless you removed it. Thanks to Pure Motorsports for all their help sorting my car out.
