Page 5 of 5 FirstFirst ... 345
Results 161 to 191 of 191
  1. #161
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    Quote Originally Posted by redline380 View Post
    id love to see some videos of this. a vr6 swap is somewhat of a dream for me. it will never happen, so id like to see what it can do. and i want more boost than the last video. wheres 30 psi at?
    I have been having some issues with my Synapse wastegate not allowing me to boost past about 19lbs so I ordered a Tial 38mm wastegate instead to try out. Its odd because I had no trouble boost past 30lbs on my old 1.8t setup with the same wastegate. I just need to find some time to fabricate the dump tube for the Tial since its a different size.
    30psi might be a bit of a push though on the stock engine. A built block is definitely in the future but I don't want to push the limits of the stock cast pistons. Being on E85 should give me a bit of a safety net as far as cooling and timing advance/knock goes but even then shit can get scary. I'm probably only going to turn it up to somewhere around 23-25lbs to see where that puts me.
  2. #162
    Dec 05 2007
    You running the same turbo as you did on the 1.8t? Maybe the Synapse can't cope to well with the added exhaust volume?
  3. #163
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by 1NaudiA4 View Post
    Yep its running great now. Two cylinder heads and multiple valve stems seals later its finally not burning any oil. I had to take my cylinder head back to the machine shop and have them pop out all the valve guides, put em on a lathe to cut them down, put them back in, and then recut the valve seats. I have about .036" of clearance between the bottom of the keeper and the valve stem seal now which should be just enough.
    Intercooler is working good. I'll take some IAT logs over the weekend so you can have an idea of how it works with the 35r.
    Glad to hear your issues have been addressed. I would really appreciate you posting those logs. Thanks and awesome work here!
  4. #164
    Oct 27 2011
    TOYS
    Philly Suburbs
    Any luck in getting logs?
  5. #165
    Feb 19 2011
    Earth
    Good to see this is going well for you now Joey.
    Get some videos up.
    2000 Achat S4
  6. #166
    Feb 13 2007
    98 A4
    Chicago
    Quote Originally Posted by jaychen View Post
    Get some videos up.
    A little late but I went to a dyno day yesterday. 444awhp/400ftlbs on 23lbs of boost.
  7. #167
    Apr 01 2011
    B5 on jack stands
    charlotte
    Hellzzz yeah!!!
  8. #168
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Awesome numbers on a stock block! What is your duty cycle like with your inj on E85?
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
  9. #169
    Feb 13 2007
    98 A4
    Chicago
    Re: 1Naudia4's VR-T Build Thread
    Quote Originally Posted by viceprp View Post
    I'll have to check out the logs but I want to say the duty cycle was pretty low at around 65% or so.
  10. #170
    Veteran Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    B6 A4 USP - B5 VR6T Avant
    Buffalo, NY
    I miss that sound. Keep it up!
    1990 Audi Coupe Quattro - 4.0t 6spd swapped
    4.60 60-130mph Xona 10569s E70
  11. #171
    Oct 06 2004
    Minnesota
    Great work!
    Instagram r_michals
    '12 Q7 TDI- Glacier White
  12. #172
    Feb 13 2007
    98 A4
    Chicago
    Dyno'd again this past weekend with the boost turned a little bit up.
    Boost was set at 29 psi and managed to pull off a 487whp/460ftlb dyno run. On the second run I increased the timing 2 degrees around 300kpa which netted a +11whp/+18ftlb change so there is definitely plenty more to be made with small tweaks on the setup.
  13. #173
    Veteran Member Three Rings un1ko's Avatar
    Feb 10 2007
    Las Vegas
    Awesome! Where did you Dyno your car?
    New Build - S4 with A4 Heart| 01 Audi 2.0T S4 6MT | CT43-6465 TBB | 82.5 Supertech Pistons | IE Tuscon Rods | Supertech single Groove Valves & Springs | 3660 Cat Cams | SEM Intake Manifold | 75mm RS4 TB | | 1000cc FIC | Eurodyne Maestro 7 | 450 Walbro Fuel Pump | Clutchmaster FX400 8-Pad Clutch | 44mm Tial Wastegate | 50mm Tial BOV | Treadstone TR1035 FMIC |
  14. #174
    Oct 27 2011
    TOYS
    Philly Suburbs
    Are you going to the track at all? Curious about what your ET/Trap looks like and your car's weight?
  15. #175
    Feb 13 2007
    98 A4
    Chicago
    Quote Originally Posted by un1ko View Post
    Boostin performance in Hoffman Estates. They had a dyno day Sunday where it was $50 for two pulls.
    Honestly probably not this year but I would venture to guess it would trap somewhere in the mid-high 120's. Problem is that my 1-2 shift collar is a little sticky so it doesn't like quick 1-2 shifts.
    I do want to get it weighed though. I'm guessing I shaved a few pounds from a stock S4. No front rebar, no AC, and wheels that weight 17 pounds a piece.
    The car is pretty damn fast as it sits. I raced a friend of mine who owns a tuned F10 M5 (570whp) from 60-120 and was able to walk him pretty good.
  16. #176
    Apr 01 2011
    B5 on jack stands
    charlotte
    That last paragraph bring tears of joy to my
    eyes.
    Cheers to you sir.
  17. #177
    Veteran Member Three Rings DeltaAlpha9's Avatar
    Jan 03 2012
    '92 Acura Integra GS, '92 Acura Integra GS-R
    Edmonton Alberta, Canada
    My god that sounds amazing. Aren't Mustang dynos notorious for reading low?
  18. #178
    Feb 13 2007
    98 A4
    Chicago
    Quote Originally Posted by DeltaAlpha9 View Post
    Yes, Mustang dyno's typically read somewhere around 10% lower than dynojets. So figure 487whp x 1.10 and it would equal roughly 550whp on a dynojet.
  19. #179
    Oct 17 2009
    alonE, Pa
    Very cool! I was hanging around the Lugtronic's tent at Fall National's and their VR's were running mid/low 9's on E85. My buddies 6766 made a few passes with back syncros and still hit 120.
    What are your next plans?
    STEVE
  20. #180
    Veteran Member Three Rings b518's Avatar
    Jun 20 2011
    long island
    NICE. Might ship u a 24v and my car lol. Congrats
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
  21. #181
    Feb 10 2007
    Las Vegas
    Good to know. I'll check them out once I finish my project.
  22. #182
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    All depends on how the dyno's are setup, even Mustang dyno's can be setup to read high. Plus 10% lower then a dyno would be a Dyno Dynamic and those read lower then a Mustang. In the end the numbers are what they are. Trap speeds on a good run is the true test. lol
  23. #183
    Veteran Member Three Rings Blake2423's Avatar
    Sep 11 2010
    '04 Cayenne Turbo
    Atlanta, GA
    So seeing this thing saturday was awesome and the fact that it shot some huge ass blue fireballs was the shit!! Sick car man!!
    01.5 S4 AVANT Brilliant Black - SRM SMIC, SRM K24 HYBRID, SRM 102MM INTAKE, 1000cc INJECTORS, GET WATKINS E85 TUNE, JHM STAGE 4 CLUTCH, JHM SYNCHROS, SRM 3INCH DOWNPIPES, AWE MID MUFFLER EXHAUST, JHM SHIFTER, BREMBO GT KIT FRONT AND REAR, H&R RSS CLUBSPORT COILOVERS, 034 swaybar and links, AWE DRIVETRAIN STABILIZER, STERN ENGINE/TRANS MOUNTS AND REAR DIFF BUSHINGS, ECS REAR DIFF MOUNT
  24. #184
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    ex B8.5 SQ5, ex 8V S3, ex 8P A3 VR6, ex B5 STK S4
    Norcal
    I watched this video and completely forgot it was a VR6, which then made me really disappointed, because for a second I thought someone had somehow made a 1.8T sound amazing. =(
    The Best Things in Life Are Free... Or Heavily Discounted!
  25. #185
    Feb 13 2007
    98 A4
    Chicago
    The clutch started slipping towards the end of summer 2013 so I decided to pull the engine and inspect what was going on. It seems as though either the rear main seal or the input shaft seal was leaking oil which in turn got onto the clutch disk. Replaced the seals and ordered up a new Spec Stage 5+ clutch with a super clamp pressure plate. If this mofo starts slipping its twin disk time.
    I'm also re-doing some of my intercooler/intake piping, making a custom SS catch can, and in general just cleaning up things around the engine bay to make things a little bit cleaner. Should be a good year!
  26. #186
    Veteran Member Four Rings NYEuroTuner's Avatar
    Oct 24 2008
    "Silvaro" B5 S4, 2013 B8 S4, 2018 RS3
    Great build thus far, looks great man
    -- George
    SEMPER FI
    Build Thread--------------->My VR6 Journey<-Click it, Click it good.
    IABEDINDUSTRIES
  27. #187
    Established Member Two Rings AudiholicA4's Avatar
    Nov 09 2013
    Cincinnati, Ohio
    any update?..
  28. #188
    Feb 19 2011
    Earth
    Quote Originally Posted by AudiholicA4 View Post
    any update?..
    last time i spoke to joey he was daily driving it. just enjoying it
  29. #189
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    thread death?!
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
  30. #190
    Oct 24 2008
    My younger brother bought the car. He has a rebuild thread somewhere on here
    -- George
    SEMPER FI
    IABEDINDUSTRIES
  31. #191
    Veteran Member Four Rings thedanplasse's Avatar
    Apr 05 2016
    RI
    Quote Originally Posted by NYEuroTuner View Post
    http://www.audizine.com/forum/showth...us-Vr6-Journey
    "Better stick to your A4 forum, peasant."
    Santorin Avant Project
    Atlas Avant Daily
