I have been having some issues with my Synapse wastegate not allowing me to boost past about 19lbs so I ordered a Tial 38mm wastegate instead to try out. Its odd because I had no trouble boost past 30lbs on my old 1.8t setup with the same wastegate. I just need to find some time to fabricate the dump tube for the Tial since its a different size.
30psi might be a bit of a push though on the stock engine. A built block is definitely in the future but I don't want to push the limits of the stock cast pistons. Being on E85 should give me a bit of a safety net as far as cooling and timing advance/knock goes but even then shit can get scary. I'm probably only going to turn it up to somewhere around 23-25lbs to see where that puts me.
