Originally Posted by
Turbwhistle
Isn't the 4.2 just slightly heavier then the 1.8t, and more power stock.
I think its difference is ~20lbs due to the aluminum block verse iron. A disassembled 1.8t block is heavier then it looks.
coolgraymemo
Have you looked at the 034 B5 track car? It has a 1.8T.
I'm sure is a diesel block (longer stroke) bored to run 2.2L. Some have pushed the bored to 83.5mm to make 2.3L. Mike Hood is running 83.5mm bored in a 1.8T block which some people refer to as a 2.1L.
I think for the money, the 2.7T is the one to go with. Its been pushed to its limits already. All sorts of parts are available so you're not into thousands for custom fabricating parts. As with any engine, due it right or due it twice. I would assume you want a true track car to wind out on the long stretches and not a autocross sprinter to bounce around cones.
