Results 1 to 21 of 21
    Veteran Member Four Rings rs4 tony's Avatar
    Sep 13 2010
    Long Island, NY
    brake humming/vibration
    I was on the road last night doing about 75-80 and lightly hit the brakes and I heard a very loud noise from the brakes.. then I tries doing it again and I couldnt reproduce the sound... it must be when the brakes are cold it happens. also when I pull out of my driveway(again when the brakes are cold) and lightly hit the brakes(under 3mph) it hums...... any idea's of what this could be?
    2007 Audi Rs4 Daytona Pearl/Carbon Fiber Trim/Navi/Lambo Verde Ithaca Pearl Painted Calipers/H&R Springs/JHM 93 Octane Tune/K&n Drop In/Apikol Red Rear Diff. Mount/StopTech S.S. Lines/Michelin Super Sports 275-30-19/H&R 8mm Front Spacers/MTM 10mm Rear Spacers/JHM Intake Manifold Spacers/SPEC Stage 3+ with LW Steel FW/JHMCatless Downpipes/JHM 2.75" Non-res Catback Exhaust/JHM Lightweight Front & Rear Rotors/034 Torque Mount/
    Instagram: @rs4_tony
    Veteran Member Three Rings darkstar's Avatar
    Dec 24 2004
    1998 silverado, 1986 c10
    Folsom, CA
    you are probably hitting the rivets on the pads! you will see lines in the rotors.
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    When did you last replace the pads? Mine do the same thing after high speed stops (150+) they get hot spots on the rotor
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Pads are always going to be noisier when they're outside their "optimal" operating range.
    Sep 13 2010
    Long Island, NY
    I had them replaced brand new with my purchase of the car on September 8, 2010 so exactly a year on the pads and they have lots of meat on them.
    EDIT:Pads in front and back and rotors upfront.
    Dec 05 2006
    So. Cal.
    Take the pads out and take a look at them. If they are the stock pads the rivets will show about half way through their life. You think that the pads have a lot of meat on them, but when you take them out, you will see the rivets , which are supposed to wear softer then the rotors, but they don't.
    Sep 13 2010
    Long Island, NY
    you got it. thank you
    Sep 13 2010
    Long Island, NY
    they have 17.5k miles on them.
    Veteran Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    RS4
    Doesn't matter how many miles as much as it does driving condition/style. Like Raudi said, remove the pads and inspect. It's one way to verify if your issue is the pins, if not at least you ruled them out.
    RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM 3R & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : F Plate Delete : CC Mod
    Sep 13 2010
    Long Island, NY
    will do. here's some pics that might/might not do justice. they are smooth to the touch.
    Nov 03 2010
    Cupertino, CA
    Just slap it up on some cinder bricks and check out the pads, not that hard!
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Veteran Member Four Rings musanoadsaba's Avatar
    Jan 24 2009
    2007 Ibis RS4
    Rockies
    Are the rivets on the front and back pads? or just the front?
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by BenSti View Post
    nah no need to. a jack will do.
    Veteran Member Three Rings dtoys4.2's Avatar
    Oct 01 2007
    Imola%20RS4%20bagged/500whp%20300zxTT/Gated%20V10%20R8
    queens NYC
    Maybe its your long hair in the way of your proper hearing and causing u to hear weird noises. Get a hair cut and then drive the car again lol. Yo u emailed bout Cliffs yet?
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by dtoys4.2 View Post
    lmao yo I did not. did you get an email? I can't find it on the "local" forum sites
    May 08 2009
    Southern California
    Quote Originally Posted by rs4 tony View Post
    I have this same exact problem. Check this video...is it the same sound? http://www.youtube.com/watch?v=jteBBxHhO7k
    When I've inquired with the dealer, they (of course) couldn't recreate the problem. I have Stoptech pads on mine so I personally dont think its a product of the stock pads as much as something with the rotors. My rotors are still the originals but do no require replacement yet.
    I've had it happen the same as you too....when I've been on the freeway traveling 75-80 and I press on the brake and then even when Im exiting a parking structure and just rolling to a stop and very lightly touching the brake it'll sometimes happen.
    New - 2013 S4 Moonlight Blue Metallic
    Gone But Never Forgotten - 2007 RS4 Phantom Black Pearl - Stasis MS, Hotchkis F/R Sways, Clutchmasters FX300, GMG Exhaust, Piggy Pipes, VMR V710 19x9.5, K&N Drop-in
    Aug 14 2009
    RS4
    Tony, was it wet outside either of these instances? Driveway thing could have been a light surface rust situation. Highway thing could have been a small pad deposit on the rotor.
    Sep 13 2010
    Long Island, NY
    nooo it was dry out for both times and wasnt rust on it in the driveway b/c I had just gotten home from school and went back to school in the matter of 30 mins
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by Tekk View Post
    I'll take a look at the video in a few
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    lol, I think he was being facetious.. Also FYI, if you haven't heard anything about COI already, you won't.
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by staticuxo View Post
    nope havent
