Originally Posted by
Coderedpl
Some dealership also told me there is no such thing as a b5 b6 b7 -_-
haha. Its no secret that there are many idiots working at the dealership
CorneliusRox
So why would my velet key start the car and then kill it? and when it did work it would disable the navi, keep the flashers on, and keep it in limp mode? The only thing that has changed really is the tune, but that is usually just fuel map (with wastegate, rail press and a few others)
What happened was somebody probably got a new key a long the way and then had it coded. But when you do that, you need to code all keys that you want to use at the same time. They didn't bring the valet key in and therefore, it's no longer a valid key to electrically unlock it, however, it will turn the ignition. Bring all your keys into the dealer and have them recode it, if you want to add keys, do it at this time.
