Hello fellow loggers! I used to log on my 2.0T all the time but just getting back to it with the 3.0T now. I did some logging tonight and there were a few oddities i'm interested to see if the rest of you have noticed. As an aside the data sampling rate was terrible, I only got like 5 data points on a 2-7000 rpm run, ill need to turn off some extra fields to get better resolution.
My car has the stasis tune at at 6400 rpm (only data point above 5500 i got) my car was making 11.8 PSI of boost and 18+ degrees of timing with almost no CF on the cylinder so I know my boost bypass isn't closing.
So the questions I have are such:
1)APR posted that group 702 was the boost bypass valve, however when i logged it 702 was charge air pressure specified. I'm assuming that seeing a high value here means the car isn't shunting any boost since it's requesting above what the car is making. Just wanted to make usre that was accurate.
2) My throttle position (group 21) never went above 85.9 during the run. What have you guys seen during your runs? 85.9 seems an odd value for what I belived was WOT though I didn't log accelerator position so I may be wrong about that....
