Results 1 to 29 of 29
    Veteran Member Four Rings AudiForeman's Avatar
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    trouble with fresh tial 605 build
    picked up the car last night and it ran great, this morning i took my dad for a rip and it pulled great until i shifted into 5th,she quit pulling and started to lose speed actually. wjat is going on, ripped great through the rest of the gears but as soon as i try and pull in 5th 105+ it just has nothing. crusing around town in 5th with no boost everything is fine. im trying to get her up to autosport werks in broomfield for a legit tune and look over. anyone have any imput
    Veteran Member Three Rings Danza's Avatar
    Jun 28 2010
    so now it won't boost at all? Check for boost leaks
    -Ian
    Senior Member Two Rings Highhats's Avatar
    Feb 12 2006
    00 Audi S4 NOS Stage 3, 02 Audi S6 Avant
    Greenwich, CT
    sounds like the load in 5th is throwing you in soft limp mode.
    S
    Tune time
    EPL Built 2000 Audi B5 S4 Stage 3 w/ 100 shot Nitrous
    YOUTUBE OF S4
    EPLABS.NET
    ICSPERFORMANCE.COM
    Jun 15 2010
    San Antonio, TX
    Just to clarify, is it only having problems in 5th, or did it start having problems all of the time after you first got into 5th? Do you have a boost gauge?
    From the sound of it, you're just on a base tune. I wouldn't worry too much until you have better tune, as that could very easily be the problem.
    Veteran Member Four Rings flyingfish2626's Avatar
    Nov 23 2008
    2008 GMC Sierra 1500
    Colorado
    Bryan at Autosport Werks is the man. He will figure it out for sure.
    2016 S3 Black Optics/LED/technology package/EQT stage 1 ECU/TCU
    2008 A4 Avant APR stage II / 6-speed.....Sold
    2001.5 S4 Avant/Pearl/Oynx/Tial 605/6-speed......Sold
    2015 VW GTI PP/LP/APR/6-speed....Sold
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    Quote Originally Posted by flyingfish2626 View Post
    yes! we have talked and this is the place im going as soon as i get back in town. yeas the problem is only in 5th/6th, every other gear pulls like a trian. boost/ af guages are being installed asap. im hoping its only a shitty base tune as it scared me for a minute thinking i might be cutting fuel and running lean. no boost leaks at all
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    Now it all runs like Shit. Plugs are fouled out and cel is flashing. What are ppl running for plugs?
    Feb 12 2006
    Greenwich, CT
    Quote Originally Posted by AudiForeman View Post
    How do you know its plugs.... Did you vag her?
    S
    YOUTUBE OF S4
    EPLABS.NET
    ICSPERFORMANCE.COM
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    your giving us no real info to help you diagnose it online. if you have vagcom or any code reader see what codes you are getting. what tune do you have, does the base file have a low rpm redline, how much boost are you running, do you have a boost controller, have logs, etc etc etc. give us more info please and we can see what we can do to help
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    What tune are you running right now... what is it setup for, what hardware (maf, injectors, etc).
    Veteran Member Four Rings 2380S4's Avatar
    Jul 16 2008
    2001 S4 Avant, 07 DTM S4, 15 328XI & 90 Turbo Grand Prix
    Living The Dream!!!
    If you want serious answers you need to give serious info.
    From your posts sounds like you just got your car done.
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    Base file from fellow member, 600cc injectors. Stock maf, peak 24psi tapers to 22. Plugs are all black with fuel/ oil. I think it just flat out needs a legit tune and more work. I thought she would he legit for a while but I know it needs to get on the rollers and get dialed in. Misfire on all cylinders says vag.
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    This
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    Oct 29 2005
    10speed
    San Francisco, CA
    Ah the old fellow member tune, always the fastest
    Dec 14 2008
    Finland
    Base file. Stock maf, peak 24psi tapers to 22.
    without
    equals:
    Hopefully you are lucky and didn´t break anything.
    Veteran Member Four Rings jasonsowers's Avatar
    Feb 18 2007
    Denver, Colorado
    Bryan is absolutely one of the best in the Business. I'd log the car yourself before taking it there. I woud check w plugs first. Run a smaller gap .024 seems to be the fix. Run the cheap copper 4644 Ngk's I haven't read any of the replies above. But it is where I would start.
    The car obviously has issues and most likely not the base file making your car run like shit. If I were in town we could log the car.
    2002 B5 S4 Laser Red Avant - Tial 605 EPL tuned
    2000 B5 S4 Brilliant Black - Stage 3 K04/RS6 hybrid sedan EPL tuned
    2006 Cayenne Turbo - Stage 2 EPL tuned
    2006 Audi B7 A4 Avant 2.0t 6mt - Stage 2 EPL tuned
    2013 Phantom Black Pearl Effect 3.0t Q5
    2014 Monsoon Grey SQ5 - Stage 2 EPL tuned
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    the purpose of the base file was so i could just get her home until i could snage a trailer and get tuned, it ran fine on the way home so i stopped by my dads to show off a bit, thats karma for ya. and then yeah by the time i got home shit was junk,oh well better it running rich than lean i say. needs a legit tune plane and simple, thanks for all the help guys
    Veteran Member Three Rings RusS4's Avatar
    Nov 14 2006
    2000 Audi S4,1980 VW Caddy,05 R1
    VA
    Your problems sound like the tune and possibly boost leaks.
    Tial 605's EPL Tuned
    Lots of other goodies.
    Sep 11 2009
    NE
    Stock maf with 605s and 600cc and WOTing? Are you insane? I wouldn't be surprised if you run 20:1 afr up top and possibly damaged something due to knocking.
    Sep 17 2005
    Fremont, California
    You are running a random file from a fellow member, with 600cc?? (you mean 630?), and a Stock MAF with 24psi on Tial 605???
    Think you answered all of your questions right there.
    Julex is completely right; WOT with that setup in 5th gear could cause serious damage.
    NEVER GO WOT ON AN UNKNOWN OR BASE FILE TUNE
    Nov 23 2008
    Colorado
    You really need a 85mm MAF for 605's. Get that car to Autosport Werks and bring your check book. You will need to buy a fueling kit from EPL.
    Mar 21 2005
    2019 RS5 SB / 2017 Jeep SRT
    FL
    Might as well run an MBC only and crank up the boost just to complete the circle of fail...
    2019 RS5 Sportback - Nardo, Black Optic Carbon Package, 034 Stage 1+ ECU/ Stage 2 TCU, APR intake, Wagner IC/HX, 034 HPFP, ABT H.A.S., BBS CI-R, E-Codes, Bull-X res delete, 034 rear sway, 034 trans/subframe mounts
    2017 Jeep SRT - Wife's grocery getter
    2015 Audi S3 - Unitronic Stage 2
    2002 Porsche 911 Turbo - AMS billet K16's / EPL tuned
    2006 Trailblazer SS - bolt-ons
    2001 Audi S4 - EPL stage 3+
    Jun 15 2007
    this must be a joke? so let me get this straight.. stock MAF, random unknown tune, 24psi, WOT, unknown AFR's, etc??? wow ok either troll or idiot.
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Jan 29 2009
    not even WOT but WOT in 5th... LOL...
    Established Member Two Rings Yuckie's Avatar
    Jan 13 2010
    '02 S4, '11 Ninja
    San Diego, CA
    Sub'd for tears.
    Apr 05 2007
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    alright im sorry, you guys are too easy to jack up, i knew the stock maf would get everyone worked up so i couldnt resist. it is a 85mm maf and i thought the injectors were 600 but i guess trheir 630's. no as far as the tune is concerned i bought from a fellow member that said he ran with his 605 kit, in fact the entire fueling kit he ran with his setup. i kinow i should have done more research on the tune but i just wanted to get her home and honestly couldnt resist a few punches. dumb i know. all spark plugs were black as could be, i replaced them with ngk4644 and she purs, i didnt drive her just started up and let warm up in my garage without a single hiccup. waiting for tune time.
    Jan 29 2009
    of course.. that's what I would do... ask for help but make sure to give false info just to get a rise out of people trying to help diagnose your issue.
    Makes sense
    Mar 18 2010
    Ottawa
    Quote Originally Posted by NOTORIOUS VR View Post
    Makes sense
    I'm with him
