Results 1 to 7 of 7
    Registered User Two Rings antidote's Avatar
    Sep 01 2010
    F-350 | Aero 95 | 505 Sport | Touareg | 67 Fast Back Custom | S4
    Fullerton, CA
    Help = A5 REMOVE SPEED LIMITER
    INSTRUCTIONS TO REMOVE THE 130 MPH SPEED LIMITER
    1. Under the computer you will now see a piece of wiring with a receptacle on the end with a plug stuck into it.
    2. The whole thing is held in place by a plastic clip. Carefully pull up this plug and receptacle. This is the engine coding connector.
    3. Pull out the plug and put the receptacle back under the plastic clip.
    4. Lay the plug on the floor of the plastic compartment so that you can find it when you want to plug back in the speed limiter.
    Those are the instructions I got from AudiWorld, does anybody know exactly what plug it is? Directly undernaeth the ECU there is fuses/relays/2 connector (black i think and red)
    Any help would be appreciated, ASAP!
    2008 Audi A5 3.2 V6
    Sep 01 2010
    Fullerton, CA
    I stand corrected, WHITE & RED.
    Veteran Member Four Rings seph's Avatar
    Norwalk, CT
    why do you need to go 130?
    -Ant
    2012 A5 2.0TQ 6MT Ibis white
    Mar 29 2011
    E
    B
    Quote Originally Posted by antidote View Post
    2008 Audi A5 3.2 V6
    Those instructions were for the previous model of S4, I highly doubt it will work for you. I agree with Seph.. why going 130mph.
    Sep 02 2011
    TO
    Quote Originally Posted by GuzmanA5 View Post
    If he can do it safely (presumably on the track...), why the hell not?
    Mar 29 2011
    E
    B
    Quote Originally Posted by MonzaA5 View Post
    No way he can do 130mph in the 3.2 in any track unless he's at the salt lake in Bonneville
    Veteran Member Four Rings BlkS5's Avatar
    Nov 20 2009
    2017 Tesla S Loaded
    La Quinta, CA
    Quote Originally Posted by seph View Post
    Because he can?
    2007 A6 , Blk/Blk/Sport - Traded for S5
    2009 S5 6M , Phantom Black/Tuscan Brn/Loaded - Totaled
    2009 S5 6Tip , Phantom Black/Blk/Loaded SOLD - 30* tint/KW ADS Coil Overs, Überlegenes Stabilisatoren System/RS5 instrument trim/ClearBra/BB Sport Exhaust/AWE S-filter/Hoen zenon/Blk Ops Grill & Valence/LoJacked/trunk panel net/led's & 42 Catch Can
    2011 A4 2.0 TQ Premium Plus/Brillant Black/Blk/30* tint/back up cam
