Rusted Wheel Help Needed!!
As the topics states im seeking help getting the wheels of a Audi A4 i recently bought. Ive tried lubricating then hammering the wheels to get it off but it does not budge. I even tried forcing it off from underneath the car.
I am wondering if i need to loosen that hex bolt in the center to get it off.
Can someone assist or offer suggestions on how to get it off. Please see the pics below. All wheels are the same.
Update:
This is the Solution that worked for me. I loosened all five bolts just a little and lubricated the hub bolt and inside between the rim and the hub (see picture). I then drove the car a short distance at slow speeds then jammed the brakes. I wasnt sure once was enough so i tried again and again. This method is fairly risky, so attempt with caution. On the third "move then stop" the wheel begun to wobble. I had three wheels that were seized I suggest you try this method with just one wheel at a time, if youve properly lubricated the wheel (best if done overnight) once or twice should be enough. I tried hammering, from inside outside and all angles that didnt work.
Inside
The Hex Bolt
