Took the A6 to a shop that had done reasonable work in the past.
Was supposed to do the TqC and valve cover gaskets.. was quoted about 1600 for labor, 900-1000 for the TqC itsself.
Total bill came to over 3500. Oil spilled all over the motor, rubber seals in the engine bay were hanging all over, check engine light was on (TqC code as well as Exhaust Gas Temp)... Half tank of fuel gone... and my door blade now catches on the door.
I had to clear out both on the VCDS... clean motor... fix blade... I'm less than pleased..
has anyone else had this repair done for you at a shop and what did it cost?
