Results 1 to 11 of 11
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    whats the thickest you can use for a wheel spacer before you need hubcentric ones?
    i have some rs4 reps that i want to toss on my car 18x8 et35, but they are barely touching my bbk. Can i use some cheap 1/4" spacers or do i need some hubcentric ones? i have studs on the car.
    http://www.oreillyauto.com/site/c/de...0291&ppt=C0337
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Apr 07 2011
    Home of the mighty beaver
    been using 5mm spacers with no issues. found some slightly longer than usual lugs that fully extend into the hubs, good to go.
    Veteran Member Four Rings wannabeS4's Avatar
    May 14 2008
    01 S4 Avant
    New Hampshire
    I think it is 8mm, not sure though.
    Brilliant Black S4 Avant
    ** Frankenturbo|034|FastIntentions|Podi|RingerRacing|Accuair|CCW **
    #BODENARMY
    Aug 09 2007
    Mount Airy, MD
    don't use those crappy spacers. real, hubcentric spacers are worth the money.
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    i would never use those spacers on anything.. those are used for like mock up purposes or when you are rolling fenders or something..
    always buy hub centric.. its not much more money
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Senior Member Three Rings AudiFan6482's Avatar
    Mar 19 2009
    2005 Chrysler Pacifica, 1972 Mercedes Benz 300
    Colorado
    if you buy those you will have terrible wobble at 50+mph (i learned this the hard way) you wont be happy unless you get hubcentric
    2008 A4 6MT Quattro... Monster mats...APR STG2...TP
    May 14 2008
    01 S4 Avant
    New Hampshire
    I dont run hubcentric spacers and have no vibrations or anything. I am running 10mm spacers btw with a lug kit.
    #BODENARMY
    Active Member Four Rings NYCVR6's Avatar
    Queens, NYC
    I run 5mm non hub centric spacers to clear my b6 s6 wheels over my bbk, and I also use longer wheel bolts. I have no wobble even at 175mph.. I personally wouldn't run bigger.
    Justin- 01.5' Pearl S4 24V VR6 Turbo Pow Pow
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Drive your car, not your dyno sheet
    Veteran Member Four Rings Bimmerchop's Avatar
    Aug 23 2004
    2000 BMW 328i
    I've ran 8mm spacers that weren't hub-centric for awhile. Had them on with a stud kit, no vibration issues here.
    Rich | 2001.5 EPL stg III+ TiAL 605.2 Pearl White S4 | Flickr
    EPL | ER | SDR | APR | Stratmosphere | 034 | ASP | SPEC | Fidanza | STaSIS | H-Sport | AWE | H&R | StopTech | Fikse
    Mar 22 2010
    03 SILVERADO SS TOO MANY PARTS TO LIST, 2001 SUBARU OUTBACK (ONLY ECONOMICAL CAR)
    Salisbury NC
    Just get hubcentric. You can find ones on eBay that are the same quality with longer lugs for 65 shipped. Mine are 10mm hubcentric. 0 vibration. Awesome quality. My buddy spent big bucks on the h and r ones and side by side you could never tell the difference.
    Active Member Two Rings 47ford's Avatar
    Oct 30 2008
    2.7t block to be built :)
    I had a different car that had 6mm spacers (H&R, not hubcentric though) and no problems at 100mph... Would get hubcentric spacers if going thicker for sure.
    Mike Michaelson
    Current modes of transportation:
    * '99.5 B5 (FL) A4 Avant (1.8t Satorian Blue)
    * '10 Rossi SC97 PhantomII/'10 K2 Pontoons/'15 K2 Pinnacle
    * 04 Specialized Stumpjumper FSR
    * '04 C5 Allroad (2.7t Brilliant Black/Nagro Blue) - awaiting new turbos :(
    Previously owned Audis:
    * '02 B5 S4 (2.7t silver sedan)
    * '99 B5 (PreFL) A4 (1.8t silver sedan)
