Page 4 of 56 FirstFirst ... 234561454 ... LastLast
Results 121 to 160 of 2226
  1. #121
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Yup. Straight from Greg. Each set will be made to order
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
  2. #122
    Feb 01 2011
    Folsom
    Quote Originally Posted by Scotty@Advanced View Post
    Yup the 99.5 had an AEB, which was DBC. Early 2000's also had the AEB which was DBC. The ATW engine is essentially a DBW AEB, then late 2000 had the AWM which was the 06A block and DBW.
    If you install the appropriate wiriing DBC/DBW doesn't matter, however it's much easier to start with a DBW car and use a DBW engine.
    All 40V v8's were DBW and it's impossible to convert them to DBC unless you go standalone, which adds $3-$4K to your build.
    If you want a DBC engine then look for a 32V engine from an A8.
    Definitely not impossible.
    You just have two throttle bodies.
    One doing the engine air management, the DBC TB.
    And one sitting in the engine bay satisfying the ECU doing nothing, tucked away somewhere so it doesnt look like ass, and moving like the ECU tells it to.
  3. #123
    May 16 2008
    South Texas
    Quote Originally Posted by kaploww View Post
    That doesn't sound like it would work too well. but it's worth a try.
  4. #124
    Oct 30 2009
    Miami, FL
    The problem with that is the 32v tune would be different than the 40v tune, sure it would probably work but it's far from ideal.
    EDIT: I misunderstood, for some reason I thought you were talking about a 32v ECU with a 40v motor. The problem I see with that method is you'll still get an error code for missing the throttle, which will likely put the ECU into limp mode. The electronics in these cars are complicated to the point where hack jobs and workarounds just aren't feasible because so much can go wrong.
  5. #125
    Veteran Member Four Rings revolution337's Avatar
    Apr 03 2009
    4.2 A4, 82 Vanagon, Mk7 Sportwagen
    Pennsylvania
    Did you get up getting that S8 engine jumbo, or are you still searching?
    Life is too short to drive ugly cars.
  6. #126
    Sep 16 2006
    '98 528i
    Not yet.....I was banking on getting one locally, but the guy's shop is swamped....so I haven't been able to swing up there to get it. At the moment, I'm focusing on getting a decent daily driver for my move down to CT. I think I'm going to take my time with this swap, get a low-ish mileage engine (at a reasonable price, if possible), and really get this thing installed without a hard deadline looming over my head.
    It was unrealistic to think I could have gotten this done in 3 weeks.
    On a positive note, I might be picking up an '05 1.8T 6spd w/ K04 and a bunch of other goods....only has a few needs.....slow, but it'll be a nice daily. Should be picking it up next week
  7. #127
    Sep 16 2006
    '98 528i
    Got some stuff done over the last few days.....
    FINALLY installed some S4 skirts
    and finally got this little pea shooter yanked out
    Heartless B5...
    Lastly.....upon visual inspection, it looks like I MAY run into a problem with the driver's side downpipe with the v8 motor. The passenger side has plenty of clearance, but the driver's side trans mount is definitely in the way...
    Does anyone recall seeing any info in the other build threads about potentially switching the driver's side trans mount to a B5 2.8L mount?
    Also, if anyone out there is interested in buying my stroker motor, PM me. I'm trying to sell it locally first tho
  8. #128
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    If it comes down to it, you may have to swap your subframe to the 2.8L or automatic one. In my car, since it was originally auto, my drivers side is the 2.8 one.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
  9. #129
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Your best bet is probably to get an S4 subframe. Not sure if they differ from a 2.8 subframe or not, so it might not matter.
    -Darrick
  10. #130
    Sep 16 2006
    '98 528i
    Hmmm.....I'll continue to do some more research to see if there's a way around getting a new subframe.....I would rather not uninstall it.
  11. #131
    Nov 14 2006
    Gig Harbor, WA
    The subframe is probably fine, you'll want a tranny brace (or whatever it's called) from a V6 model though since they have two humps in them for the downpipes to go through.
    -Darrick
  12. #132
    Sep 16 2006
    '98 528i
    Just did some more research......you're definitely right. I'll need either the drivetrain stabilizer brace, or an S4 or V6 subframe.......I THINK i may go the subframe route......Just ONE more thing I've gotta buy and install....damn
  13. #133
    Apr 03 2009
    Pennsylvania
    It looks like when kaploww (I think that is his username) did the swap he used an AWE drivetrain stabilizer bar as the transmission mount. Not sure if he just completely eliminated the drivers side mount then or what.
  14. #134
    Sep 16 2006
    '98 528i
    I think that's what everyone who started out with a 1.8T has done.....I just don't feel comfortable eliminating the driver's side mount altogether. I'm looking into locating a V6 subframe and upper trans bracket locally
  15. #135
    Apr 03 2009
    Pennsylvania
    I'd rather not have to modify/swap out my current subframe if at all possible. I wonder how stable the trans would be with just the stabilizer bar and the passenger side mount.
  16. #136
    Sep 16 2006
    '98 528i
    A subframe swap is easy. I'm not too worried about it anymore, especially now that the motor is out. Here's the Bentley DIY
    http://www.dj-sures.com/GraphicFiles...%20install.pdf
  17. #137
    Apr 03 2009
    Pennsylvania
    Just so I'm clear, what exactly is the difference between the two subframes? If you use a 2.8 you can run both PS and DS trans mounts?
  18. #138
    Sep 16 2006
    '98 528i
    Exactly....The 1.8T subframe and trans mounts only leave room for a downpipe on the PS. The 2.8/s4 subframe will allow proper spacing for both downpipes. .....Hopefully everything will go together without a hitch
  19. #139
    Apr 03 2009
    Pennsylvania
    I see. Another topic, I'm not exactly sure what flywheel I can use for this swap. Obviously I need something that will allow the trigger wheel to line up correctly with the sensor, as well has have the 8 bolt pattern. And whats the deal with the trans spacer? When is this necessary? I'm getting some mixed signals as to if this is needed or not.
    edit: pilot bearing? I haven't figured out what to do there yet either. The more I dive into this project, the more I realize how much work this is going to require lol
  20. #140
    Sep 16 2006
    '98 528i
    Yea, it's certainly not nearly as easy as I was anticipating, but fortunately, I'm picking up a DD next week, so this project will be done at a more reasonable pace. As for the flywheel, I got a spec b5 S4 LWFW, because it was available at a great price. If it doesn't work, I'll get rid of it. But, from what I understand, the transmission spacer will aid in getting the trigger wheel to line up properly......There are definitely a few things that I need to iron out as well
  21. #141
    Veteran Member Three Rings SeekB00st's Avatar
    Dec 09 2008
    A tricycle
    Nofolk VA (Its Hood Here)
    I see your running a AME tru boost controller.
    Put Werk Here
    [/SIZE]
  22. #142
    Sep 16 2006
    '98 528i
    I was......ya want it? $225 shipped
  23. #143
    Jun 30 2008
    Erie, Pennsylvania
    Just to add some more info (or confusion) to the subframe issue, I'll add that (AFAIK) all B5 subframes are effectively the same, other than 1.8T *5-speed* subframes. So a 1.8T automatic, or V6 automatic, or V6 5-speed, or any B5 S4 subframe would work to fix your issue there. The only one that *won't* work (and requires that chunky mount) is the 1.8T 5-speed subframe, which happens to be the one you have.
  24. #144
    Sep 16 2006
    '98 528i
    Yea.....working on hunting down one that is V8 friendly....Thanks for the info
  25. #145
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    once you get going if you want a hand with some work lemme know, I could stop by some weekend day and help out. I'm actually starting to consider doing this swap as well, my A6is too big to be fun but I love the 4.2/S8 cams/S8 IM/LWCP/LWFW stg4 clutch/longtube headers powerplant. I think in a gutted out B5 it could be some good fun.
  26. #146
    Sep 16 2006
    '98 528i
    Yea, I cannot WAIT to get this done.....it think the B5 chassis will be a great match for a S8 powerplant.....Once I get rolling on this, I may be shooting you a PM.....However, I have no timetable for when that might be....Will keep all of you posted
  27. #147
    Feb 01 2011
    Folsom
    as far as mounts go. I have eliminated both trans mounts, and will be running the DTS bar as transmission support. In addition to that, I installed a set of stern mounts. Between the near solid engine mounts, and the beefy stabilizer bar, I'm not even worried about it. those components are so strong. If the drivers side transmount still fits when all is said and done, I migh pop it back in, but as if now. Im not worried about it.
  28. #148
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    Wow, good on 'ya for pulling the trigger. Best of luck, I'll be watching.
    PS: subframe is easy to pull with the motor out. My guess is that you'll be changing out the uprights anyway, so it's not much more work at all.
  29. #149
    Sep 16 2006
    '98 528i
    The parts are starting to pour in!
    For those that're interested, here's what I've got so far:
    C5 A6 4.2 upper motor mount brackets (including oil cooler)
    Stern C5 Motor Mounts
    B5 S4 Transmission spacer
    Dual 12" push radiator fans
    SPAL 185-degree Harness
    A6 4.2 Coolant Expansion tank
    SPEC LWFW for B5 S4
    034 SAI Blockoff plate
    2.5" Milltek Downpipes (currently being made)
    Other misc. items needed for the swap
    NEED to buy:
    S4 front subframe
    S4 DS trans mount and upper bracket
    Flywheel bolts
    That's it so far.....still searching for a set of a6 4.2 lower motor mount brackets....I THOUGHT I'd located a set (through a supplier known here on AZ), but my payment was just refunded earlier today, and I've received no explanation for it.....SO, the hunt resumes......I'm buying a daily within the next few days, so I'm not in a huge rush to get this done. Hopefully my patience will pay off.
    And, for my exhaust....I THINK I'm gonna try to mate the downpipes to a 2.5" B5 S4 true dual exhaust (I think techtonics and milltek make a 2.5" version....but they're rare).
    And, lastly.....I'm regrettably STILL looking for an engine. I thought I had one locally, but I have yet to hear back from that shop, as they are constantly swamped with work, and they haven't gotten around to returning my phone calls or responding to my emails. SO, I'm moving on for now......
    I'll post more updates as I continue to compile parts and install stuff
    *EDIT*
    Torn between which of these two cars to choose for my new daily:
    Stock-ish IMOLA B5 S4 w/ alcantara, euro S4 rear, and oem RS4 front ** no extensive records, clean cosmetically, recent(ish) T-belt and turbo replacement
    http://www.audizine.com/classifieds/...dy-mods&cat=67
    or an '05 B6 1.8T 6sp w/ K04, RNS-E, and a bunch of other mods ** good mechanical shape, full maintenance history, but somewhat rough cosmetic shape
    I'm leaning more towards the B6......but that Imola is hard to pass up.....I'm gonna be test driving both this weekend.
  30. #150
    Nov 14 2006
    Gig Harbor, WA
    Having had both a 1.8T B6 and an Imola B5, that's a tough decision.
    The interior on the B6s are nicer and they're a bit larger/more luxurious feeling, and the 1.8T tends to be lower maintenance. However, 2.7Ts are just plain fun to drive, but they're a bit of a pain in the ass to work on.
    Between those two specific cars there, I think I'd go with the B6.
    -Darrick
  31. #151
    Veteran Member Three Rings ColinAndrews's Avatar
    Oct 29 2007
    Edmonton, Alberta, Canada
    I'll second the B6 with a 1.8T as a daily. The torque of the 2.7T is fun, but working on it sucks. The 1.8T with a K04 will still be plenty of fun on a daily basis and A LOT nicer to sit in.
  32. #152
    Sep 16 2006
    '98 528i
    Yea, I'm leaning more towards the B6 as well....I know the engines inside and out, so it'd be an easy fix, if need be.
    I was just drawn to the B5 cuz it just looks so damn good....and I'd keep the bumpers for THIS b5.....But, I'd hate to have to work on the 2.7 when any problems pop up
  33. #153
    Jun 04 2007
    Austin/DFW, TX
    1.8t w/k04 and bigger interior seems like DD material to me.
    My 5-Speed Swap DIY
    - B6 USP
  34. #154
    Apr 03 2009
    Pennsylvania
    You have a link to the fans/harness that you're using? I'm still browsing around for electric fans and haven't decided on a brand yet.
  35. #155
    Sep 16 2006
    '98 528i
    I got some Champion Cooling 12" radiator fans on Ebay. I was originally looking for SPAL fans only, but I couldn't find a set of 12" fans at the time. I found some good reviews on them, and they have a pretty high flow rating. From what I've seen, they appear to be pretty good quality. Not flimsy or cheap at all. And comes with a full money-back guarantee!
    http://www.ebay.com/itm/200660850548...84.m1439.l2649
    As for the harness, I got this:
    http://www.ebay.com/itm/200662473537...84.m1423.l2649
    It's for one single fan. I'm thinking I may always run one fan (like a viscous fan) and use the other to kick in at higher temps (i.e. the stock auxilary fan).....still not sure
  36. #156
    Sep 16 2006
    '98 528i
    Btw, here's the mod list on the B6......think I'm def gonna go with this, if the test drive goes well
    KO4 turbo giac x+ tune, tt 225 injectors
    Forge 007 Diverter Valve
    Custom FMIC
    H-sport front and rear sway bars.
    Koni sport shocks
    H&R sport springs
    B5 s4 engine mounts
    Stern Solid trans mount.
    Stainless Steel Brake Lines
    B5 S4 Front Brakes, with Hawk Hps Pads
    CM FX300 240mm Clutch Kit
    034 motorsports high flow cat.
    Auto Speed USA 2.5in stainless catback
    JHM short shift kit
    OEM RNS-E
    raw carbon fiber interior trim
    OEM V10 R8 oil and coolant caps.
    OEM ECODE Xenon HID's
    Diesel Geek Skid Plate
  37. #157
    Apr 03 2009
    Pennsylvania
    Will you be able to fit 2 12" fans on the radiator? From my (rough, mind you) measurements I found that dual 12" fans won't fit, so I was planning on running dual 10"
  38. #158
    Sep 16 2006
    '98 528i
    Will let you know by the weekend. I thought I'd read somewhere that dual 12s would fit. If not, I'll go with 10s
  39. #159
    Veteran Member Three Rings Crispy222's Avatar
    Mar 15 2008
    Syracuse, NY
    Quote Originally Posted by JumboBlack1.8 View Post
    I have one of these as my main cooling fan for my 1.8T. I deleted the clutch fan. I can't comment on life, but I've had no problems with it for almost 8k miles. (mostly highway 70mph+)
    If you stagger the fans, you should be able to fit two 12".
  40. #160
    Sep 16 2006
    '98 528i
    How do you have that wired up?
