Results 1 to 11 of 11
    Veteran Member Four Rings Gujuhammer's Avatar
    Oct 07 2010
    02' Avant
    Florida
    Hotchkis rear sway with Neuspeed hardware
    I just bought a used Hotchkis rear sway bar that was suppose to come with the bracket/hardware to install it. The hardware got "lost" during shipping. I currently have a Neuspeed sway bar and was wondering if I could use the hardware from it to install the Hotchkis one? I believe the Hotchkis is 22mm and the Neuspeed is 19mm.
    Thanks for the help guys.
    Oct 07 2010
    02' Avant
    Florida
    Just got a quote from Hotchkis for the hardware...$265
    Established Member Two Rings skadic333's Avatar
    Sep 30 2011
    Chicago
    Quote Originally Posted by SAUDI01.5 View Post
    That's some poop man. Return it.
    ‘15 S3
    RIP ‘01 S4 | Santorin | Greddy | VAST | TWIN 1 | GIAC X | Stage 2ish |
    Oct 07 2010
    02' Avant
    Florida
    It's used...I think I'm just screwed
    Sep 30 2011
    Chicago
    Damn.. Fab your own hardware?
    ‘15 S3
    Sep 17 2005
    Fremont, California
    You don't have any of the bracketry? I'm not surprised at the cost; the brackets and reinforcements are the most expensive part. The bar itself isn't that expensive.
    I think you'll be better of selling your Neuspeed and buying the brackets, or fabricating some (CAUTION: please do this professionally, since there is an INCREDIBLE amount of force on the swaybar). The Neuspeed bar is 19mm vs. 22mm on Hotchkis, so you'll need new bushings too and I doubt the bolt pattern is is the same for the bushing caps.
    Mar 22 2010
    03 SILVERADO SS TOO MANY PARTS TO LIST, 2001 SUBARU OUTBACK (ONLY ECONOMICAL CAR)
    Salisbury NC
    Has anyone fabricated their own brackets? I have a knockoff nuespeed one (19mm adjustable got it new for 120 :). If so please post a diy or atleast parts needed to do this. TIA
    May 13 2011
    2015 BMW F30
    That sucks. Since you cant sell it maybe fabricate them?
    | Autospeed | JHM | Pure MS
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    call drew oliver over at hotchkis. he is a cool dude and might give you a good deal. their brackets i believe are only 100 bucks and come with all the bolts. im not sure why you got quoted so high. maybe call them up and talk to someone else.
    Feb 28 2007
    S4 Stage 3+
    Las Vegas
    I was under the impression that some were running the beefier H&R rear sway bar with the neuspeed brackets. Would the same not work for the hotchkis bar? Can't he just use it with the neuspeed brackets?
    Dec 05 2007
    I really don't see why the Nuespeed subframe reinforcement bracket won't work. That and the Hotchkis reinforcement bracket serve the same purpose, but just through a different design. Only thing I can see causing an issue is the mounting bracket/bushing that goes over the bar. Not too sure if that 3mm will cause that much of an issue, but you won't know unless you actually try to place it on. And if that's the case, ask for a price quote on those 2 bushings.
    I am coming from a Nuespeed rear with stock front to Hotchkis f&r (B5 A4, but same thing when it comes to this).
