Results 1 to 8 of 8
    Apr 20 2011
    South Motors BMW
    Ecu x wont read pass 19psi
    Hi guys i just bought another imola S4, this one is a 4door sedan stg3 by AWE, i did some logs and it wont
    Read past 19psi and the boost gauge would say 24psi, the car has a boost controler and i lower the boost to 20psi and would still read 19psi all across, i lower the boost again to 10psi and then it would read 10psi on the
    Ecu x logs but if turn the boost back on to 22psi it will only read 19psi, any ideas of what it is?
    Thanks guys
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    it's pretty hard to tell why that is happening..
    it could be the sensor (unlikely), could be the MAP sensor offset in the tune, could be where you are relative to sea level.
    Apr 20 2011
    South Motors BMW
    Thanks man, im gonna get a new MAP sensor and see what happens after that
    Veteran Member Three Rings nkbks4's Avatar
    Mar 26 2009
    Silver stg 1 avant, Black 01' STG 3, wife - Honda Pilot
    Naples, FL.
    Im located straight across in Naples if u need any help. Have u tried vagcom? Just to make sure ecux isnt bleepn out...
    Stg 3 black sedan 395whp/402wtq (sold and will be missed)
    Silver stg 1 avant cleaner upper
    Apr 20 2011
    South Motors BMW
    One of my friends log his car and it reads perfect, he is boosting 22psi
    Mar 09 2004
    2002 S4, 1986 944 Turbo
    Fl
    Sounds like your boost gauge is off/wrong to me. If "it" (ECU-X) follows it down to 10psi & back up to 19psi, then my money is on a flaky gauge. Very rare that the factory map sensors shit the bed.
    Mar 26 2009
    Naples, FL.
    Quote Originally Posted by Schoolbus4 View Post
    If possible, switch maps w/ ur buddy to eliminate that prob. Then go after the guage...
    Apr 20 2011
    South Motors BMW
    Now the car Starts but it turns back off inmediately
