Results 1 to 8 of 8
    Established Member Two Rings Robv27's Avatar
    Dec 27 2006
    Richmond VA
    Question 2001 audi A4 Quattro auto transmission problems with reverse. need help please.
    hello, I have a 01 A4 Quattro w/ an auto tranny (tiptronic) and i'm having some issues when i put it in reverse. When the car is cold, tranny works perfectly, but as soon as it heats up, when i put it in reverse it doesn't always move. it seems like it engaged, but than i press the accelarator and it doesn't move. it makes no noise and it just feels like its not engaged. there's a set point that as soon as i put it on "R" and i accelerate the car harder it engages and goes. Does anyone know if it could be a solenoid issue or anything like that? are the solenoids outside or inside on the transmission? Moving forward the car moves and shifts perfectly. Any input on this will be greatly appreciated. Thanks in advance!
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    Solenoids are inside the box. Auto transmissions are extremely complex, and in turn are extremely difficult to diagnose and repair. I do all kinds of repair work with Audi/VW but I won't touch an autobox. You should take it to a transmisison shop that's is familiar with them.
    Veteran Member Three Rings SS92's Avatar
    Jul 11 2011
    2012 2.0T GTI
    Charlotte, NC
    Do a Swap :) Problem solved.
    2000 B5 A4 1.8T ATW GT2871r, Unitronic/Maestro tune, RaceTec FMIC, etc... - > FOR SALE
    Jun 30 2008
    Erie, Pennsylvania
    Does the dash reflect the shift to reverse properly (gear position indicator), and do the reverse lights come on? Any dampness near the front passenger's feet? How about fluid level?
    Very, very first thing to do is scan for codes with vag-com.
    Very next thing to do is 5MT swap that pig...like it's your job.
    Nov 11 2013
    Washington
    Did this ever get resolved? I'm having the same issue with my 2000 A4 tiptronic automatic transmission. The shop I took the car to said I probably need a new transmission but didn't seem like they actually looked very far into the issue. They quoted me at $3000 for a used/rebuilt transmission plus and the labor cost included in that price. If I can find a more precise, cheaper fix from anyone here, it'd be much appreciated. Thank you!
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    ^swap a 5-speed.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Nov 11 2013
    Washington
    How much would that generally run cost wise? I couldn't do it myself so I assume the labor would be insanely expensive.
    Dec 27 2006
    Richmond VA
    I sold it before i fixed it. I dont actually think its the transmission. I think its electronic. I one day was messing with it and forgot the maf unplugged and it worked fine but obviously ran like crap, so when i plugged the maf back in, problem came back. I know its crazy but try it...and if you find out, please let me know. Id like to know what the problem is. Rob
