Results 1 to 17 of 17
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    Euro Bumper and Headlights
    Who should I go to for a Euro front bumper and Euro clear corner headlights? I am in need of both. Price is not as important as time to get the parts.
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Nov 07 2005
    RS6, M5
    Melbourne, Australia
    Alex @ Europrice seems to be the go-to guy for these sort of parts in the US.
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by Alister View Post
    This... Alex FTW!
    FRRG AZ Ring
    Nov 03 2010
    Cupertino, CA
    I will give Alex a call tomorrow. Do you guys know what the typical lead time is on the bumper/headlights?
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by BenSti View Post
    It varies...but he'll be able to give you an approx. lead-time...
    FRRG AZ Ring
    Oct 11 2007
    Suburbia
    Alex or bust! He hooked me up with that exact order about a year ago. It does usually take several weeks, as it's all coming from Europe by boat.
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~
    ~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Bilstein PSS9s~Girodiscs~JHM shifter~
    01' A4 Silver 1.8T Avant 5MT
    ~Motoza Ko4 tune~550cc injectors~Apikol SMIC~3" testpipe~ST coilovers~18" Avuses~
    Senior Member Two Rings Trogdor1464's Avatar
    Apr 20 2011
    IL
    Just curious, but why a euro bumper? Is your's jacked up or something?
    Established Member Two Rings NJAUDI1's Avatar
    Sep 24 2006
    07 S4 A/T, 07 RS4 6MT, 11 S4 6MT
    definitely alex, best customer service.....
    Veteran Member Four Rings musanoadsaba's Avatar
    Jan 24 2009
    2007 Ibis RS4
    Rockies
    Do you want the euro beam pattern or just the clear corner is of importance?
    Nov 03 2010
    Cupertino, CA
    Quote Originally Posted by Trogdor1464 View Post
    My front end had a 5mph collision with a trailer hitch. Basically hit 1/4" above bumper beam and screwed everything. Bumper, headlights, grill, radiator, oil cooler, radiator support, fans, hood, etc are broken and need replaced.
    Insurance will cover the damage so I figure I might as well just order the proper parts rather than order parts and then have to modify them.
    Jan 24 2009
    2007 Ibis RS4
    Rockies
    Shite, sorry to hear about that. Bumper hitches should be illegal unless something is attached to it.
    Nov 07 2005
    RS6, M5
    That's a fair bit of damage for a 5mph accident!
    Nov 03 2010
    Cupertino, CA
    Quote Originally Posted by musanoadsaba View Post
    Couldn't agree with you more. Basically I was behind him at a light, the light turned green, he went, I let out the clutch and was just beginning to go, not even on the gas yet. He slammed on the brakes right as the back of his car got to the limit line and I hit him. He had no brake lights (both appeared burnt out or not connected), no license, no registration (1993 Sticker), and no insurance. From my point of view, there was no reason he should have stopped, nobody was in front of him, but he must have had a good reason. He didn't want to stop cause the truck was fine, but I got him to pull over and got his info. My insurance company said that they were going to investigate it which basically means, I will be found at fault.
    Either way, it is covered, still sucks though. I want to get it painted perfectly. It is at the best bodyshop in the Bay Area, The Works Autobody.
    Would have been headlights, grill, and hood without the tow hitch. Probably 1/4 the price.
    Dec 05 2006
    So. Cal.
    Sorry to hear about that Ben.
    Jan 24 2009
    2007 Ibis RS4
    Rockies
    That description sounds like he had no teeth either.
    Veteran Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    RS4
    lol - & maybe a bottle of Jack in his lap and a rifle hanging in the rear window.
    RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM 3R & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : F Plate Delete : CC Mod
    Nov 03 2010
    Cupertino, CA
    Hispanic gardener guy...
