Results 1 to 12 of 12
    Apr 08 2011
    2012 CW GTI 6MT!
    Los Angeles, California
    Problems problems problems... help !!
    So I recently changed my Thermostat, installed 034 silicone lower breather-hose, Spark plugs, and check valves(only left one out cause it look good still).
    I now have a CEL. I dont know the code.
    Seems that the car doesn't really want to crank over.(it takes 3 times exactly, every time I do it on the 3rd try it cranks over.)when it does crank over it runs really well, switching through all gears, it runs good.
    -I tried my fuel rail to see if it sprays out, it does. so its not fuel pump
    -tested the battery at auto-zone, they said it was pretty much brand new. 100% charged. alternator should be good because its charging the battery.
    When engine is on, it barely idles. by the meaning of that i mean idles from 900 to 950 pretty close to 1000 rpms. i can barely feel it.
    Anybody got any suggestions? (besides CEL cause i cant do anything about it till i check what the code is)
    help would be appreciated.
    Apr 08 2011
    2012 CW GTI 6MT!
    ohhhh i also tried jump starting the battery, and it started rite away. like normal. i check the battery terimals and they are making good contact.
    can it be the starter?
    Established Member Two Rings deadsoldier's Avatar
    Jun 01 2011
    Philadelphia
    Quote Originally Posted by A4.1.8turboo View Post
    def try to read the cel and post what u get.
    Apr 08 2011
    2012 CW GTI 6MT!
    Quote Originally Posted by deadsoldier View Post
    yeah its kind of weird though. cause the first attempt i did when i replaced t-stat ect. it took twice to start but the CEL wasn't on until i turned it off and turned it back on. then about 2 hours ago, i replaced spark plugs, turned it on. and no CEL came up. drove it around for a while, got the it to be at normal temperature, put gas, and when attempting to turn on, again on the 3rd try it started with a CEl. but other then that and small idle, runs really good... so idk
    Apr 08 2011
    2012 CW GTI 6MT!
    soo no one on AZ have any suggestions or anything that can help?
    Senior Member Three Rings A4QuattroBum's Avatar
    Dec 05 2010
    '05 Brilliant Black B6 A4 1.8TQ
    San Diego, CA
    If you tested the battery at AutoZone, why didn't you have them scan the code at the same time? Figure out what the code is. That's step #1. Then post up and get some advice.
    "that ass is chewing gum........and I like it." -the sheriff
    My other passion... http://www.youtube.com/ImMikeTrollston
    Apr 08 2011
    2012 CW GTI 6MT!
    Quote Originally Posted by A4QuattroBum View Post
    because i took the battery out the car, and took it to them. And as i was there i asked them. they said they dont do it anymore. you have to buy the scanner. i called couple shops around my area and they ALL said they dont check CEL's on Audi's. I asked the last shop why they dont do it, they just said they dont carry the scanner.
    Dec 05 2010
    San Diego, CA
    You got fed a nice, big bowl of bullshit.
    Autozone advertises that they scan codes all over print and television ads. I've personally had my A4 scanned several times and in three different states since I've owned it. They do it. Just ask. You don't need VAGCOM just to scan a CEL.
    Mar 15 2011
    Bronx
    probably the camshaft position sensor....but im no expert the best way to go about this is to get the code
    Apr 08 2011
    2012 CW GTI 6MT!
    You got fed a nice, big bowl of bullshit. Autozone advertises that they scan codes all over print and television ads. I've personally had my A4 scanned several times and in three different states since I've owned it. They do it. Just ask. You don't need VAGCOM just to scan a CEL.
    nopeee i went again and they said they dont do it. (went to a different one). they said they havent done it for about 3 years now. so that was a no go.
    so i went to a smog test center and they checked it and erased it for 30.
    codes were
    P0341- cam position sensor Bank 1.
    P0113- IAT 1 ckt High
    Quote Originally Posted by l0uietheking View Post
    indeed you were rite !! haha
    Apr 08 2011
    2012 CW GTI 6MT!
    codes were
    so now any thoughts on what i should start on first???
    Apr 08 2011
    2012 CW GTI 6MT!
    Position sensor is good now. doesnt struggle to start. i took it out to see if anything was wrong with it, and one of the the 3 wires was completely off. it wasnt making contact. so now to the iAT ! :)
