Results 1 to 14 of 14
    Veteran Member Three Rings srcrash715's Avatar
    Jul 15 2011
    VW MQB Tiguan, VW Rabbit. HD Street Bob, Mercedes E320 CDI
    Frederick/Maryland
    Boost Gauge Cycling Colors
    I have a new south boost gauge that came with the ecs tuning column gauge kit, the thing out of nowhere started cycling colors. I put the resistor on per the instructions from new south if the gauge started doing that. But, the gauge is still cycling colors, does anyone have any ideas why it is doing that or any possible fixes?
    Current: Sprint Blue MT B7 S4 Avant
    Mods: OCarbon Reflexive Silver Trim | VMR 701 19x9.5 with 265/30 Yokohama Advan Neova's with a wee bit of rub
    R.I.P. 2005.5 BAT Quartz Gray Tip
    Oct 14 2009
    Okinawa Japan
    Haha sounds comical, post a vid :-)
    I know not really helpful lol, I would remove this feature physically. Prolly a printed circuit in the gauge? Mecahnical gauge?
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Jul 15 2011
    Frederick/Maryland
    I normally dont notice it because I am used to it now but every now and then a bright color will come up and catch me off guard and then I just get pissed off that it is still doing it lol. It is mechanical but I am ready to just say the hell with the ecs column and the new south gauge I have been having troubles since day one with it.
    Established Member Two Rings cbaquol's Avatar
    Mar 28 2011
    Baltimore
    Are you sure its not set to change colors at a certain psi? My podi flashes red after like 15-16psi
    2005.5 Brilliant Black 6MT Quattro 2.0T REVO Stage 2 / 034 Motorsport Turbo Inlet / Carbonio CAI System / BSH PCV Fix / NGK coppers / Revision "D" Diverter Valve / RS4 FPV / Podi Electronic Guage Steering Wheel Mounted / Cupra R Lip / RAI Test Pipe / Adjusted Wastegate
    Vagcom: Euro Lights / Seat Belt Chime Disabled - If you need logs and you are local I am always willing to help shoot me a PM!
    Jul 15 2011
    Frederick/Maryland
    Im positive, it cycles through about 20 different colors regardless of what psi it is. I mean the directions said that if it was doing that install the resistor which I did and that didnt work.
    Jul 15 2011
    Frederick/Maryland
    For your request Draklore, a minute vid of the magical cycling boost gauge. Some of the changes are subtle but they are there...
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    dude.....put your seatbelt on.....saves lives bro
    idk sounds like you have a electric switch fucking up or something
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Jul 15 2011
    Frederick/Maryland
    Quote Originally Posted by mr shickadance View Post
    I was sitting in my driveway... Bro.
    Jul 08 2010
    tucson
    danbury
    i..... was joking.....pal.
    [CENTER]Scott
    2011 S4
    Feb 25 2011
    Seacoast NH
    "If you could feel how my face felt, you would know how Mace felt
    Thank God I ain't too cool for the safe belt"
    -Kanye West, Through the Wire
    Oct 14 2009
    Okinawa Japan
    That would bug me :-/ flamer gauge
    Either get them to find a fix, or return and buy a real gauge... Like Podi! Jk, find out the bore of the mount, and ^see what other gauges will fit in it. Then ^see if they will work a deal for your troubles. Link them to this thread. Tell them it would show good customer service ect... :-)
    Shane drake
    -Shane Drake-
    >DRAKLOREs Build<
    Established Member Two Rings lesurfman's Avatar
    Mar 03 2010
    montréal, Canada
    Just call Steve at NewSouth Performance 919.967.8917 and he will take care of you.
    I had a problem with my electric vent gauge, called him and he replace the faulty gauge even if I bought it from a canadian distributor and didn't have an invoice.
    They really stand behind their products.
    SPRINT BLUE 2007 A4 2.0T MT6 Quattro S-Line Titanium
    APR Stage II Tune (Stock, 91, 93, and valet modes) - APR Carbonio CAI - APR Snub Mount - 034 Motorsports Motor Mounts - 034 Motorsports Turbo Inlet Hose - RAI 3" HFC - OEM "D rev" DV - RS4 Rear Sway Bar - RS4 Pedals - New South Performance Vent Boost Gauge.
    Oct 14 2009
    Okinawa Japan
    OP sounds like they already got good CS so just figure out if this is really the gauge for you and go from there :-)
    -Shane Drake-
    >DRAKLOREs Build<
    Jul 15 2011
    Frederick/Maryland
    Thanks lesurfman I will give them a call, thanks for the info... and then I shall see if it really is the gauge for me lol
