So I had change all the top seals and gaskets a few months ago after discovering that my valve covers were leaking and then cleaned everything up so I could see if they would leak again. Changed my oil a few weeks ago and they was oil all over the bottom of the car almost on everything below the exhaust manifold on both sides, everything above that was bone dry, wtf. So I cleaned it up until I got some time to check it. So this weekend I rip the car apart to find what was leaking
So after doing all of this I finally discover that my crank case system/spider hose/pcv was clogged, they was a bunch of oil in the hoses leading to my intercoolers. So my plan is to re-do my spider hose with heater hose re-use the connections but add a oil catch can. I just need to find a spot to put it. Do any of you guys with auto trans have oil catch cans and if you do where did you put it ?
