A few weeks back i replaced my suction jet pump and while i was doing so i would occasionally brush up against the brake booster line that runs through the firewall. When I applied some pressure to the line to move it out of the way, it hissed. Is this normal or is it indicative of a loose connection or leak? Braking is normal.
Also for my own information, when the motor is shut off and the car is parked, if I press the brake pedal a few times it stiffens up significantly. Is this normal. I have just assumed that it is the left over vacuum that is being exhausted by the brake booster, and that once it is used up, the braking stiffens. That's just a guess on my part though. I don't even know if the booster functions normally while the motor is off.
Thanks for any feedback
