I'm following Mark P's DIY on wheel bearing replacement, and am just trying to put everything back together. All is in good, except for the lower control arm nut/bolt shown in step 10 here...
http://www.audiworld.com/tech/wheel45.shtml
That 19mm nut is just threaded onto the ball joint shaft. How is that tightened/untightened? The whole thing just spins in the ball joint! This is an otherwise great DIY, but I don't see any way to secure that ball joint shaft so the nut will spin freely on it. There's no allen or hex connection anywhere else to grip that threaded rod.
Another, MUCH less ideal option would be to ride on the loosened control arm bolt to a shop. There's no steering linkage, etc, back there like the front control arms, so if this connection is loose like 3/4", would it do anything catastrophic, or just rattle like a m/f? I mean, if I can't get that bolt to wind off (or back on all the way, for that matter), I don't think it's too likely to wind itself off.
If anybody had this problem, or any ideas, TIA as I'm on jack stands in pieces as you read this.
Thanks everybody.
