Results 1 to 23 of 23
    Veteran Member Three Rings A5RIZ's Avatar
    Mar 12 2010
    DSG Gear Indictator Location ON DASH
    Anyone know if there is a setting to change the location of the gear indicator.
    Bottom left on the display just doesnt work for me...cant see it behind the steering
    wheel...not the biggest problem but seems like a design flaw if it cant be changed
    Thanks
    Mar 26 2010
    US
    With the VAGCOM mod, I see the DSG gear selection display in the bottom center.
    2019 RS5 Sportback
    May 11 2010
    2011 S4
    Quote Originally Posted by wwhan View Post
    Bottom center? Mine is bottom left as well with the mod. MY 2011...
    Jul 07 2009
    Lebanon
    Without the VAGCOM mod, I see the DSG gear selection display in the bottom center.
    +1
    SOLD: 2010 A5
    Mar 20 2010
    2010 B8 S4 red with red inter, 77 Trans Am (orignal owner); 2005 Subaru Impreza RS
    MD
    Quote Originally Posted by A5RIZ View Post
    Thanks
    I agree with A5RIZ... I wish mine was in top left corner or top center. Problem is when going around a turn really fast you can't see what gear your in and while exiting curve you shift up it would be nice to know the gear instead of trying to remember it.... This also applies before you enter the curve and you want to shift down.
    By the way A5RIZ, this was a problem in the beginning, but after a while, I learned to judge which gear I was in by memory and RPM...
    When I asked this question on a previous thread, people responded by saying there was no way to change location of gear indicator via VAG-Com...
    JS
    Mar 12 2010
    Thanks Jscaf...that's pretty much what I do but was hoping there was a VAGcom mod for it
    Veteran Member Three Rings DATZ's Avatar
    Oct 17 2010
    Northern NJ
    Just look at the tach. RPM is all that matters, not gear choice.
    Mar 20 2010
    MD
    Quote Originally Posted by DATZ View Post
    +1 ... BUT have you noticed that depending on the turn, the steering wheel blocks the RPM guage.
    Next S4 should have the RPM guage right in the middle. That would be cool...
    Veteran Member Four Rings LeadToRome's Avatar
    Apr 25 2010
    I-95
    ...what would be really cool imo is if they got rid of the analog speedo, and used the room to add an oil temp guage and a bigger gear indication. That speedo is huge and pretty much useless.
    Veteran Member Four Rings tomh009's Avatar
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    Quote Originally Posted by jscaf View Post
    No matter where the tachometer is positioned, the steering wheel can block it, depending on the sharpness of the turn. This has been the case since cars first had tachs, and yet drivers have always been able to shift. Even before cars had rev limiters. Listen to the engine note, and you should have a good idea of the revs, and when you should shift.
    Oh yes, I have a 6MT with no gear indicator on the dash. And I don't look at the shifter all the time to see what gear I'm in, either.
    2012 S4 · 6MT · Glacier White/Black Nappa · sport diff · navigation · black optics · BBS RG · TT-RS steering wheel
    Oct 17 2010
    Northern NJ
    Exactly. Engine/exhaust note is all you need to know when to shift, dsg or 6mt.
    Apr 25 2010
    I-95
    Agreed in general but with the quiet stock exhaust and the kickin stereo it can be hard to hear anything at all.
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    Quote Originally Posted by tomh009 View Post
    strange, mine came with that feature activated on my 6spd
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    Quote Originally Posted by LeadToRome View Post
    If you're driving hard, turn down the tunes and focus ...
    Quote Originally Posted by richib86 View Post
    Uhh, I better admit that my S4 has not yet arrived and I'm still driving my B6 A4 (with 6MT). I hadn't noticed a gear indicator on my S4 test drive, but I wasn't looking for one, either. If there really is one, then it's my bad on that ... but I still don't need one.
    Mar 12 2010
    Revs...RPMs...6mt...DSG...
    All I asked was if we could change the location...that's all
    Driving manual over 20 years...I hear ya on not needing it...I said
    it in the original post...just wanted to know...thanks for all the responses
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    Fair enough ... sorry about the thread digressing, that barely every happens on AZ!
    Veteran Member Three Rings Brick Oven's Avatar
    Nov 03 2010
    SF CA
    Yeah because ** disregarding the DSG vs 6MT argument for a minute ** when you shift from third to fourth, back to third, up to fourth and fifth, down back to third and so on, you remember exactly what your last shift was, where the stick is now, and your muscles are preprogrammed to grab it and move it where it needs to go. It's the culmination of all the data you're processing: the feel of the pedal, the sound of the engine, etc. You don't think about the gear number but you know it in the back of your head.
    When you're flipping paddles back and forth for a while, you forget what gear you're in. In my 6MT R32 I look at a corner and it's almost like my arm decides, "go get that stick and move it to third gear". There is no such muscle memory on a DSG. So any greater visual stimuli is a good idea, in my book. As for myself, I want a gigantic 3 or 4 or whatever that takes up the entire DIS. I mean I want a straight up rally display. And if you want to toss a digital tach bar right above it, all the better. As the platform gets older I hope there will be more aftermarket options to do things like this.
    More feedback is my main reason for wanting an aftermarket exhaust too. A cool exhaust note on the outside is nice but I want it for the noise inside.
    2013 Daytona B8.5 S5 : PP : Diff : Magma : DSG : Carbon : B&O ::: HRE P47SC 20x9.5 et20f et15r brushed titanium : Michelin PSS 265/30 : Bilstien PSS10 : SPC Control Arms : Eurocode Alu Kreuz : OEM Ecodes : OEM BO Grille BUILD THREAD: http://www.audizine.com/forum/showth...40#post7874340
    Veteran Member Four Rings ilspazzaneve's Avatar
    Jul 18 2011
    ^^^ agreed.
    Even more importantly for those who've tracked their DSG, it will refuse a downshift into 2nd until close to 3000 rpm for me (which puts me into my turn-in). I would like to know it has refused the downshift, on a nice big display, before I get back on the gas. This has tripped me up a few times.
    Doesn't the 6MT have some sort of economy mode which makes a big shift indicator on the top of the DIS? I forget if I am imagining this, but if it exists, maybe it can be enabled for DSG....?
    Veteran Member Three Rings redrocker55's Avatar
    Feb 21 2010
    St Louis, MO (USA)
    When the lap timer feature is turned (which also displays the oil temp) there is a bunch of room in the DIS that is not being used. That would be a cool place to put the DSG gear number.
    2016 S6 Prestige, Misano Red Pearl, Driver Assist, B and O, Sport Pkg, Carbon Atlas, Black Headliner,
    Alu Kreuz, 034 Motor Sport DSG Insert, RS7 Intake Box, APR Stage 1 w/ Dongle
    Sold 2010 S4 Brilliant Red DSG with Prestige Pkg
    Sold 2008 VW GTI DSG
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    Quote Originally Posted by redrocker55 View Post
    Sounds like a nice opportunity for APR (or someone else)!
    May 01 2011
    Europe
    Quote Originally Posted by ilspazzaneve View Post
    I haven't found one yet on mine. All it does provide is a small display bottom left of the current gear, and if necessary a suggestion for a gear change for economical driving, like this:
    4►6
    S4 Avant, 6MT
    Established Member Two Rings pyknosis's Avatar
    Jul 03 2010
    New York, NY
    It's actually not "unused" it's where the lap times go if you actually use the lap timer.
    2010 S4, Prestige, DSG, Quartz/Black/Black Alcantara. AWE Intake, APR Exhaust, Folding Mirror Mod, Tint.
    Jul 18 2011
    Quote Originally Posted by BobbyJim View Post
    4►6
    OK, in the same place as our DSG. Oh well.
    Anyway I'd much rather have reprogrammed DSG software that makes the DSG do what you tell it to do in M mode. Hmmm gonna resurrect that old thread again so the vendors notice.
