Page 23 of 23 FirstFirst ... 13212223
Results 881 to 904 of 904
  1. #881
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    due to the nature of how the coil is and how it sits on the plug, i believe the offset is negligible.
    tons of people running centered adapter plates with no issues. nothing to back up that the side load is causing problems... mostly hearsay.
  2. #882
    Jul 04 2012
    Woodbridge, VA
    "Side loading"? What A bunch of garbage. 6mm is almost quarter of an inch, which would be pretty noticeable. If that is the case then the 2.7 coils are being side loaded as well. They are almost identical.
  3. #883
    Veteran Member Four Rings odhinnhrafn's Avatar
    Jun 25 2010
    '01 Audi S4, '15 Chevy Colorado
    Reno, NV
    Quote Originally Posted by Timtheguru View Post
    You're changing yours every 3k miles :P
    True story. lol.
    '01 Black Audi S4, Stg3+: FT21, J-Fonz tune, 630cc Siemens, Deatschwerks pump, VAST Stg3 + LWFW, RS4 transmission, Stern motor/tranny/snub mounts, APR BiPipe, AWE SMIC, Hotchkis rear sway, KWv2, 18" OZ Ultraleggara
    '15 Chevy Colorado Z71
    If you haven't left blood or tears on it, you're not trying hard enough...
  4. #884
    Jun 25 2010
    Reno, NV
    Quote Originally Posted by mauromj View Post
    When it comes to grounding the coils, It sounds like this is the best way. Can anyone provide any insight on this?
    Pin 2: 12V power GND - connect to valve cover or other "power ground" point
    Pin 4: Signal GND - connect to ground wire that goes back to the ECU
    Yes. I grounded mine to one of the bolts that holds down the adapter, and I've had zero issues. I have also wired another member's where I tied both grounds to the ECU gnd wire, and he's had no problems.
  5. #885
    Veteran Member Three Rings S4gasm aka LOTR's Avatar
    Sep 30 2006
    01 S4 Santorin 6 Spd
    Missoula, MT
    Can i use these pigtails for the 2.0 coil packs?
    Or what is everyone using now?
    http://www.ebay.com/itm/4-Audi-VW-Ig...lV-s87&vxp=mtr
    01 S4/ Stg 3+/K24/+stuff
    08 A6 Avant/ S-Line/ 3.2/ bone stock
    Build Thread - http://www.audizine.com/forum/showth...ld-91-craptane
  6. #886
    Veteran Member Three Rings e30mclow's Avatar
    Feb 08 2015
    An Irishman living in Canada
    That's what I used.
    Current: 1998 Mitsubishi Pajero Evolution
    1990 BMW E30 with 1JZ
    Previous Bad Ideas: 2000 Black Stage III (BW-K04); 2000 Imola Stage III (BW-K04)
    Previous "Better" Ideas: Euro e30 m3, Euro e34 m5, Inca Orange 2002Tii, '89 325iS, '89 318i, '90 318iS, '91 318iS, 2 X '87 316, '89 320i, '81 316 and so on..
  7. #887
    Jul 01 2014
    'murca
    i have a few sets of pigtails left, LMK if youre interested.
  8. #888
    Sep 30 2006
    Missoula, MT
    Quote Originally Posted by erykv1 View Post
    are you the one selling adapter plates as well? I need the adapter plates right meow.
    I'm set on pigtails though. Just plates.
  9. #889
    Veteran Member Four Rings mauromj's Avatar
    Jul 22 2012
    Pullman, WA
    I am to lazy to retype this for the context of this thread, so here is my Facebook post question I have about this conversion.
    For those of you who have done the 2.0t coil conversion, I have a few questions regarding wiring. I have read all the threads out there on this, but just want to verify GND connections before I wrap my harness up.
    The pinout of the 2.0t coil is:
    Pin 1: Power (+12v)
    Pin 2: GND
    Pin 3: Signal
    Pin 4: GND
    Now, I have read through the long thread(s) on Audizine about misfires cause by tying pins 2 and 4 to the same ground. This make sense, because pin 2 should be chassis (power) grounded, where as pin 4 should be "signal grounded". The GND potential is likely different between the two.
    However, I cannot find a signal ground on the ECU where pin 4 would be optimal to tie into. Mostly everyone I have heard of doing this conversion (successfully) has tied pin 4 to the valve cover, while running pin 2 to the brown wire, which makes its way to the chassis ground point.
    This is still putting them at the same GND potential. Sure it may reduce noise/interference slightly, but I just don't see how this is still correct.
    Can someone who has done this swap and had no misfires please chime in?
  10. #890
    Nov 25 2009
    Lexington, KY/Orlando, FL
    IIRC it is only on a couple of the cylinders where there are not 4 separate wires for the conversion. It is on these cylinders where people try to use one ground for pin 2 and 4 together. This caused minor misfire issues for me and I went back in and grounded those particular cylinders to the valve cover and have been problem free since. But like I said it is only a couple of the coils that you will need to do this with. Hope that helps
  11. #891
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    I just connected both ground wires... no issues going on 2 years.
    Solder method. bkr7e NGKs. rdcyclist adapters. and i believe "E" revision coils.
  12. #892
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    Some people say that they don't have problems, but I know few that have had serious interference. And Audi has also grounded those to the different points, and they don't do that without a reason.
    Pin 1: Power (+12v)
    Pin 2: Power GND
    Pin 3: Signal
    Pin 4: Signal GND
    Put the signal ground to the original wiring harness ground, and the power ground wires to the intake manifold grounding point. There is already the harness ground.
  13. #893
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    I run the "power" ground to the valve cover stud/nut (shortest possible circuit) and the signal to the original one in the harness (coming from ECU; but forgot which pin of the ICM carries the ECU ground). If all fails, run to one of the chassis grounds on the firewall.
    On later conversion, I just did one ground, plus one extra ground to valve covers.
    I got into this only because I was fighting persistent misfires on one cylinder 'for no obvious reason' (compression good, leak down good, spark correct), which ultimately turned out to be a broken exhaust valve spring that just broke/seated to not impact compression, but changed the ignition enough to trigger misfire counter. Had nothing to do with wiring the ICM delete/FSI coils.
    I am running E (red) and F (black).
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
  14. #894
    Nov 02 2014
    Phila, PA
    Not sure if its OK to resurrect this thread, but I'm having some issues and was hoping I could get a few suggestions.
    Installed the ECS coil kit yesterday, and it went pretty smoothly. Replaced the plugs with stock NGK's, etc, etc. Started up and noticed it was rough, friend said he thought it was missing. Drive it around the block, and yes it was definitely missing with CEL to drive the point home. Checked VAG, and it said misfire on cyl 2. Today, went out and checked to make sure coil was seated, checked connector was snug, ran it, and same. Just in case, swapped coil #2 for coil#5, rechecked connections and took it around the block again: CEL and misfire on cyl#2.
    ECS is closed, and I would like o be able to drive to work Tuesday. Anything obvious I miss? Suggestions?
    My rationale for using the kit was ease of install and having everything on hand. Anyone else had any issues with ECS kit?
    TIA
    B.
  15. #895
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by heybiff View Post
    TIA
    B.
    What gap are you using??
  16. #896
    Nov 02 2014
    Phila, PA
    Quote Originally Posted by vavJETTAw36 View Post
    .028 checked them all before I put them in. My buddy laughed at me as he watched. I'm from back when they weren't pre-gapped.
    B.
  17. #897
    Jul 04 2012
    Woodbridge, VA
    B.
    Are you by any chance getting short to ground codes? Cel will not illuminate for this soft code.
  18. #898
    Nov 02 2014
    Phila, PA
    I will check. I had a couple of codes that needed to be looked up, but they looked like they were related to the misfire -- beginning numbers..
    16684 Random/Multiple Cylinder Misfire Detected
    p0300-35-00 -
    16686 Cyl 2 misfire detected
    p0302-35-00
    17861 Exhaust gas Temp Sensor 1 open or short to plu
    p1453 35-00 - -
    17865 - Exhaust Gas Temp Sensor 2 (G236)
    P1457 - 35-00 - Open or Short to Plus
  19. #899
    Jul 04 2012
    Woodbridge, VA
    p0300-35-00 -
    p0302-35-00
    p1453 35-00 - -
    Ok not sure about your EGT but if you had the codes before and it wasn't misfiring, it's likely that something you changed is causing misfire. Swap the Ecs coil adapter from cyl 2 with a different one to rule out the harness.
  20. #900
    Nov 02 2014
    Phila, PA
    Do you mean swap the entire cable assembly from side to side? Didn't think about that, but I guess that would be the next step. It def wasn't the coil. I guess since I have to just about take everything apart to get the cable out, I might as well pull the plug too just in case.
    B.
  21. #901
    Jul 04 2012
    Woodbridge, VA
    B.
    Pull your engine covers and you should have access to your cables... switch one thing at a time. If that doesn't yield anything, swap spark plug. #2 is easy to get to so you shouldn't have to remove much at all.
  22. #902
    Nov 02 2014
    Phila, PA
    Swapped cable assemblies from side to side, checked connections to make sure they were snug, and still misfire on Cyl#2. Oddly, engine feels strong otherwise. Taking a break before going out to pull the plug.
    Fingers crossed.
    UPDATE:
    swapped out new NGK plug on #2 for the old worn plug, misfire gone! Now misfire has moved to #5. Will repeat tomorrow on #5 and see what develops. SMH.
    B.
  23. #903
    Jan 04 2017
    Ceska republika
    Hi I just bought a bundle of 2x 1J0971658L , advise te how to connect to the computer ? (Audi s4 b5) Thank you
  24. #904
    Jul 04 2012
    Woodbridge, VA
    Teaser 2.0T Coil packs...
    Quote Originally Posted by Panpacient View Post
    Searching that part number brought up wiring harness for the 1.8t. That said, it's not a direct replacement. I am sure since it's just wires that you can make it work but seems like a PITA. And you'd have an extra coil plug on each side.
    Hooking into the computer is easy. Simply cut off the zip tie from the back of the ecu harness( mine is already missing)
    , pull off the back that the zip tie attached to.
    Then on the connector side there are pink clips you pull out.
    That will release all million wires so be careful to not allow all the others to pull out or you'll have a nightmare putting them back together.
    Simply push in the new connector ends with wires attached and slide the pink retaining clips back in. You'll obviously have to run the new harness to the engine somehow.
