    Senior Member Two Rings archangel.308's Avatar
    May 30 2011
    2022 Audi SQ8 /2018 Audi SQ5
    Chandler, AZ
    2011 A4 Chrismas tree
    Last night I went to leave the office and started the car and the dash was lit up...
    TPMS Sensor
    Flashing Parking Break
    Dynamic Stability control unavailable
    EPC
    Check Engine
    No Boost Either
    No the way to end a long day at work...
    I only have 5029 Miles
    Turbo: Exhaust gasses go in, witchcraft happens and you go faster. - Jeremy Clarkson
    MODS:
    • SQ5: (B9) IE Intercooler and Carbon Fiber Intake Kit w/ Inlet pipe., 034 Transmission and Rear Subframe Mount Insert, 034 Billet Oil Filter Housing,
    • SQ8: (4M) 034 Transmission Mount Insert, and Billet Oil Filter Housing
    • R8 V10 (MK1) Stock
    Veteran Member Three Rings NickZag's Avatar
    Feb 22 2010
    2006 S4 Avant
    Northern, CA
    I got all of those codes when I installed my BBK when i unhooked all the sensors. Looks like you might have cut a sensor line or one got disconnected somehow. There might even be an ABS issue. You deffinetely need to have a tech check it out. Don't want to mess with your braking.
    2021 A4 | 2006 S4 Avant
    Oct 09 2008
    Could it be a dying battery?
    Scan the codes, report back.
    The Awesome™
    Veteran Member Four Rings vhstejskal's Avatar
    Feb 01 2011
    UT
    Take it to the dealership. That "should" not happen to a new car...
    -Vic
    May 30 2011
    Chandler, AZ
    The Dealership has it and is looking into the issue, I am interested in what they find. The service consultant was thinking loose connector.
    MODS:
