Results 1 to 10 of 10
    Senior Member Two Rings MTN's Avatar
    Nov 01 2006
    981 Boxster Spyder / 16 Macan Turbo / 12 C63 / 12 TTRS
    Campbell, CA
    OEM B7 S4 wheels for winter setup
    I would appreciate feedback as to whether a set of OEM 18" wheels from a B7 S4 would fit my 2008 RS4. These 18" OEM wheels already have all-season 235/40/18 tires mounted. I was using them during the rain months for my B7 S4 Avant. If they fit, I plan to use them for my winter setup on my RS4.
    Thanks.
    MTN
    Current:
    981 Boxster Spyder Black / 981 GT4 Carmine Red / 12 TT RS Suzaka Grey/ 12 C63 AMG Saphire Grey
    08 RS4 Ibis White / 16 Macan Turbo Jet Black / 03 996TT Seal Grey (MT) / 05 A8L W12 / 06 Cayman S Atlas Gray (MT) / 06 E46 M3 Conv (MT) / 06 B7 S4 Avant (MT) / 01 S4 (MT) / 97 M3 Sedan (MT) / 95 M3 (MT)
    Jan 01 2008
    Long Island NY
    Most 18's fit the circumfrance just check the et.. should be under 35
    Veteran Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    RS4
    Caliper clearence may be an issue, not positive.
    RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM 3R & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : F Plate Delete : CC Mod
    Veteran Member Three Rings norsecarnut's Avatar
    Sep 15 2008
    2 Land Rovers, BMW E61 mt6
    Quote Originally Posted by Auditude2.0T View Post
    "check et" ? There's nothing really to check if they're oem. The ET will be very high/larger number than is going to look right on the RS4, possibly not even clear the brakes in terms of depth. A spacer is going to be desirable in this instance seeing as the wheel is first, sunk in to fit an S4 fender as well as an inch narrower than the RS4 wheels. Even if they bolt on and don't hit the brake face, they will look like some weird temporary spare inside the deep rs4 fenders. The inverse of trying to stuff an rs4 wheel into an s4 resulting in serious poke.
    2008 S4 Avant mt6 Dolphin - APR Full exhaust / Escort 9500ci-stealth install / backup camera / aux-in & ipod & cd / 35% ceramic / 2" hitch class 2 / Nokian WRG2 / HID fog / Stasis high-bias center diff
    AKA: jwest
    Established Member Two Rings jpo's Avatar
    Jun 22 2008
    Calgary
    Likely they are et 45ish. I agree they will need spacers. I have the 18" oem Avus wheels as my winters on my S4 and even on the S4 they look stuffed way in and dorky compared to the et 35 summer wheels.
    2004 Moro Blue S4 MT
    Nov 01 2006
    Campbell, CA
    Quote Originally Posted by jpo View Post
    Thanks. I live ind CA and only use the car to go to the snow in Lake Tahoe maybe twice or three times a year. These are the occasions when I would put on my winter setup. Otherwise, I run summer tires the rest of the year. Thus, how the wheels look on the car does not matter much. I just need a setup that's functional and safe.
    I guess I can remove one front wheel and see whether the S4 OEM 18" would fit and clear the break caliper.
    Regards,
    MTM
    Current:
    Senior Member Two Rings karsty's Avatar
    Dec 10 2010
    Edmonton, Alberta Canada
    Were you able to test fit the S4 wheel on the front to check for caliper clearance yet?
    Sep 30 2010
    Earth
    I have some S4 anniversary wheels that I use for my winters. The offset of a stock wheel will not clear and I use 20mm MTM spacers (that's 20 per wheel, so the 40mm MTM set). The wheel is still inset slightly from fender compared to stock (just a visual niggle), but they fit just fine.
    Nov 01 2006
    Campbell, CA
    Quote Originally Posted by MTN View Post
    Regards,
    MTM
    I tried one wheel and it did not clear the front brake caliper. I am guessing that a 10mm spacer would provide the necessary clearance.
    Current:
    Nov 01 2006
    Campbell, CA
    Quote Originally Posted by bos View Post
    Thanks.
    Current:
