Results 1 to 7 of 7
    Established Member Two Rings jmpaul320's Avatar
    Apr 22 2011
    2006 B7 S4 MT, 2006 Corolla CE
    Danbury, CT
    chattery valves a cause for concern?
    i guess i just might be paranoid and making things up... seems like my b7 s4 has gotten a little bit louder at idle... just had oil changed... no check engine or epc lights, mechanic said everything looked fine...
    i mean it doesnt sound like a cummins turbo diesel but there is definately a noticeable tick tick tick tick tick that follows the rpms until about 1500... settles down a bit once its warmed up but is still noticeable, sounds like noisey valves/rockers etc... no loss in power or hesitation during acceleration
    any cause for concern or should i just turn up the radio?
    please dont flame me i did a search
    Milltek non-res catback | Hyperflow CAI | APR snub mount | Black Tints all around
    Sep 13 2008
    Western Chicago Burbs
    DO you know what type of oil was used and what weight it was?
    If the oil is not the problem, I suggest changing the plugs. Mine used to be clanky at idle and now with fresh plugs, all you hear is the exhaust hum
    Apr 22 2011
    Danbury, CT
    Quote Originally Posted by B6JoeS4 View Post
    oil is 0w30 mobil 1 synthetic ... just got plugs replaced about 5000 miles ago for 55k service
    Sep 13 2008
    M1 0w-30 is one of their "Advanced Fuel Economy" oils. That means it's very thin which could probably cause excess noise (and wear).
    Run M1 0w-40, or step up to my favorite, Motul 8100 x-cess
    Apr 22 2011
    Danbury, CT
    yeah, i was going to get m1 ow40 but they were all out... i guess ive learned my lesson... what kind of plugs do you run?
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Try a PAO-heavier oil if you think it's the valves.
    PS: I don't think it's valves. Sounds like exhaust and/or vacuum leak.
    Sep 13 2008
    I run OE-style 4 lash NGK platinums. Testing done by JHM and their own experience suggest that 4-lash plugs work best for this car. A few people think that it's just a gimmick that makes the plug last longer, but not in the case of this motor.
