    Jul 19 2011
    Chicago, IL
    Type of Transmission Fluid
    Hey everyone,
    I know there are diffrent types of transmission fluids out there and i want to know what people out there recommend/ use.
    I drive a 2001 A4 1.8T Automatic trans.
    Thanks
    Jordan
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Click here for all applicable automatic transmission fluids.
    Although it's a bit pricey, I would recommend OEM.
    PM me if you have any questions or concerns
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Dec 05 2007
    OEM ATF. I am a big Amsoil fan, and would have more than likely tried their ATF though if I had an automatic (I have a maunal transmission and use their manual tranny fluid along 75w90 gear oil for the rear diff). The one they have says that it is compatable for G-052-162-A1, but it seems you are supposed to use G-052-162-A2. Not sure of the A1 to A2 is a revision in the forumula or what. But it's people with manual transmissions usually try out different brands. Also, there are service intervals with it comes to automatic transmission fluid.
    96-97 (all): 45k intervals
    98: 25k intervals for 1.8t/37.5k intervals for 2.8
    99: 20k intervals on 1.8t/22.5k intervals for 2.8
    00: 20k intervals for 1.8t/32k intervals for 2.8
    01: every 2 years regardless of mileage
    Veteran Member Three Rings 9744RR's Avatar
    Sep 01 2005
    2016 A6 3.0T, 2003 A4 1.8T Tip, GTRS Elim, REV0, 440 injectors, ASP front mount, etc Porsche 356
    Pentosin ATF 1
    Check NAPA Auto.
    2016 A6 3.0T Stock
    2003 A4 1.8T Q TIP not stock
    Porsche 356 Stock
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    I use/recommend Valvoline MaxLife Dex Merc. I'm running it in a 2.8 A4 and a 3.0 A4, and a 1.8T Passat. I had to have my Daughter's 1.8T Jetta's 5-speed auto rebuilt because of worn clutches (always filled previously with VW ATF), and the transmission shop our company uses, Riverside Transmission, filled with MaxLife without me asking for it. He told me that with a 3-year warranty to consider, he wasn't going to take a chance with the fluid he uses. But don't expect snappy, grabby shifts. I had some first-gear shudder on my 2.8 using factory fluid, after two MaxLife changes it is smooth every shift.
