    Established Member Two Rings jpres's Avatar
    Apr 26 2011
    2006 A4 Sedan 2.0T CVT - White
    FL
    Strong Smell of Oil/Gas after CC and VC Install
    Need some help running this one down. About a month ago I installed an 034 CC and Eurojet VC. Ever since then, I'm getting a really strong smell of oil/gas coming from the engine bay. The smell seems to be coming from the catch can area, but I've double-checked all my hoses and they are secure. Even when I take the top pipe of the CC and smell the can, it doesn't smell exactly like the odor I'm trying to track down. I'm not getting any oil leaks. The car is running fine with no codes. Idle vacuum right at 21.
    I do have custom piping mating up the Eurojet VC and 034 CC. I'm routing my crankcase hose and my VC hose into a T-fitting and then to the side of the CC. I'm routing the top of the CC over to the turbo inlet. Everything seems to be fine with the CC setup, but this seems to be the most likely culprit. Any ideas? Picture of my setup:
    08 Cab 2.0T CVT, REVO Stage 2+, 034 HFC, IC piping, TIP, and catch can, APR HPFP, Carbonio, ER DSMIC's, Devils Own W/M, BFI snub mount, RS4 sway bar, Rokkor c/o's, R8 replica 18's, TTS MFSW w/ paddles, RS4 grill
    Deactivated Two Rings
    Jun 01 2011
    Evo 9 MR
    Summit Point Raceway
    If you had a Vent-To-Atmosphere (VTA) Catch can, I'd tell you that it is entirely normal, however, it looks like the 034 CC is a recirc. setup. Check all of your lines/fittings/etc. to ensure that they're not leaking or seeping oil. Feel free to email me directly if you have any other questions! [email protected]
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    Can you post more detailed pics of your set up.. you 90deg fitting looks different than mine.
    '08 Brilliant Black B7 A4 w/ DTM Conversion Stage 2+ - Sold
    '14 Midnight Blue Allroad Premium Plus w/ Nav & LED Package - Sold
    '13 Ford F150 XLT - Current
    '14 Glacier White Q5 Premium Plus - Current
    '08 Ibis White B7 A4 Titanium Edition Stage 1 - Current
    -Steven
    Apr 26 2011
    FL
    Quote Originally Posted by Eurojet@STaSIS View Post
    John - thanks for the reply (love the VC by the way). It's weird because the smell seems to be coming from the top of the CC, yet I'm getting no seepage or oil anywhere, and I've double-checked all the hoses and connections. I'll keep looking and try to get some more pics.
    Veteran Member Four Rings CleverA4Name's Avatar
    Dec 09 2009
    2006 A4 2.0T Quattro 6MT, 2016 Audi SQ5
    Portland, OR
    Yeah that VC is gorgeous
    F.T.W.L.T.B.D.W.I.C.T.W.
    -Trent
