Results 1 to 38 of 38
    Established Member Two Rings TheDonPulido's Avatar
    Sep 24 2009
    Germany
    Key Fob Battery replacement
    Just got in my car today and got a warning light for the key fob battery. does anyone know how to replace the battery?
    Veteran Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    Quote Originally Posted by TheDonPulido View Post
    Remove the silver key from the fob, grab the black part underneath the silver key and press the silver button and the black button and pull out to remove the battery carrier. Pretty straightforward from there.
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, B8.5 MMI 3G+ Nav, Ti Pkg
    APR Stage 2+ Stock/93/100/Valet, Eurocode Alu Kreuz, Eurocode USS Sways + End Links, Eurocode Meisterwerk SSK, Roc Euro Intake, Apikol Rear Diff Mount, Fast Intentions Exhaust, Escort 9500xi, Laser Interceptor, P3 Vent Gauge, VCDS
    May 01 2011
    Europe
    I would have everything ready and try and do the swap fairly quickly to reduce the chance of it forgetting anything.
    Senior Member Two Rings thebigchu's Avatar
    Oct 24 2007
    2004 Yukon Denali, 2010 Ibis S4 Prestige 6M
    San Ramon, Ca.
    I'm new to the B8, but doesn't it charge when you plug it into the holder on the dash?
    2010 Ibis White S4 6M Prestige. Stage 1 (034 Motorsport). ADS, Sports Diff, B&O, Nappa, Tech package, 19" Trispoke.
    SOLD - 2002 Brilliant Black S4 6M ** Stage 1 ** (GIAC-X * JHM "Solid" Short Shifter * 034 DVs/TBB * Avic D3 * Clear Corners)
    http://www.audizine.com/classifieds/...inside-&cat=67
    Oct 27 2009
    Miami, FL | Boone, NC
    Quote Originally Posted by thebigchu View Post
    No. How would it? There are no metal contacts on the outside of the fob.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Sep 29 2009
    Same as other cars that do this - inductive charging
    Ever seen a cordless toothbrush? Same thing, you set it on the charger, no metal in contact.
    http://en.wikipedia.org/wiki/Inductive_charging
    Oct 27 2009
    Quote Originally Posted by NWS4Guy View Post
    Yes, but our fobs do not do that, right?
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Veteran Member Four Rings Audacious's Avatar
    May 03 2011
    you mean I've been putting the fob inside for no reason for 4 months -_-
    Senior Member Three Rings BLACKS4-10's Avatar
    May 08 2010
    2011 Ford F-150 Lariat 5.0
    real easy to do and you can get the battery for $5 at Radioshack,just make sure you get the right one.
    2010 S4 Brilliant Black- Black/Magma Nappa-Prestige-B&O-Carbon Atlas inlays-DSG-Nav/camera-35% Solar Gard tints-APR Exhaust-Eurocode Alu-Kruez stabilizer-Tyrolsport RCS kitEurocode Trufit intake-ECS 2-piece lightweight front and rear rotors with Akebono Euro pads=H&R rear sway bar
    Oct 24 2007
    San Ramon, Ca.
    Dunno... I haven't RTFM'd on that section. I only mentioned it cause my mom's TL does that so I made an assumption.
    Senior Member Three Rings forza1976's Avatar
    May 16 2011
    2015 M4
    Denver CO
    Here you go...
    Oct 24 2007
    San Ramon, Ca.
    what kind if counter is that?
    May 16 2011
    2015 M4
    Denver CO
    It's called eco-concrete. It's my desktop, weighs 400lbs. :) got it at Room and Board, however I don't think they sell this material anymore. Not sure why
    Sep 29 2009
    Unsure on the S4, I know my wife's 2008 Land Rover does this though.
    May 16 2011
    2015 M4
    Denver CO
    Well I'd venture to guess they don't because this CR2032 that is in my 2011 S4 key is not rechargable (at least from the factory). That's not conculsive but I seriously doubt there is any charging considering all the cost cutting measures Audi has done to the S4. IMO
    Veteran Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Volkswagen Beetle
    Raleigh, NC
    Do what I did - take the battery out of your second fob until you get to the store...
    Tschüß!
    Ðave
    ____________________________________________
    '10 Brilliant Black A4 Sline • Hüper Optik • 034 HiFlo Turbo Hose • EC HFC • Milltek • Alu Kreuz/ÜSS • Hankook V12's • ST-40 BBK
    Sep 24 2009
    Germany
    I had nothing to lose, so I did the recharging test and so far the replace battery error has gone away. I still went to to the store to buy a battery replacement just in case. I let you know what happens next.
    2010 Audi S4
    Registered Member One Ring BlkS4 11's Avatar
    Oct 15 2012
    2011 Audi S4, 2001 BMW X5, 2001 BMW 330i
    Orange Co. NC
    My Dealer told me the dash slot DOES recharge the key fob when I bought the car. I just got the "replace battery" warning also at 24k miles and replaced it with a battery from Walmart. I have been occasionally putting the key fob in the slot maybe a couple times a month. I bet it doesn't charge. I am taking my car for its 25k service this Wed. and will ask the service guy. I will report back later this week to let you know what he says.
    Lee
    Apr 04 2012
    MSP
    I also was told when I bought the car to use the dash every once in a while (long trips are good times) to recharge the battery in the FOB since I have keyless. I don't see why they'd say that if this was not a function. But just like any battery - especially removable batteries - they have a shelf live, chargeable or not.
    Veteran Member Four Rings ahcow's Avatar
    Apr 26 2010
    Toronto, Ontario
    Quote Originally Posted by UmIsThisThingOn View Post
    Isn't it easier to just use the other fob? O.o
    I was sure it charges...my salesperson told me to swap the fob once in awhile to make sure they both are charged. I will ask when I go in for service, should be soon.
    New: 2016 S3, Sepang Blue, Sport Seats, S-tronic, Tecknik, LED
    Old: 2010 S4, Brilliant Black, Magma Red Nappa, S-tronic, Nav, Sports Differential
    Mods: Strat Intake, 35% Ceramic Tint, RS5 Pedals, BE GTS-AV, Hawk pads, Alu Kreuz, Vag-com, APR Exhaust
    Senior Member Three Rings sirpickles's Avatar
    Jun 26 2012
    The Mid-West
    Quote Originally Posted by ahcow View Post
    B8 S4 | 6spd | Brillant Black | Prestige | B&O | Carbon Inlays | Magma Silk Nappa | ADS/Rear Diff | Driver Assist
    Mods | 20% tint | AluFelgen SF-71 19x9.5 ET42 | H&R Sport Springs
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    Seeing the type of battery as "CR2032 non-rechargeable", I don't think we can re-charge about fob. At least not with the factory battery.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Oct 15 2012
    Orange Co. NC
    Quote Originally Posted by sirpickles View Post
    I love it! That is too funny!
    Lee
    2011 Black S4 prestige
    No mods, yet...
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    i call BS on the recharge ability, even when the fob was in the dash, the warning went off like crazy. it goes off everytime you come to a stop then exceed 10mph in or out of the fob
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Oct 15 2012
    Orange Co. NC
    You are right! Just got back from service. The Fob recharging is a MYTH! Service guy said several people have asked him and he looked into it and it does NOT charge in the dash slot! My dealer didn't know what he was talking about when he told me to put it in there occasionally to charge!!!
    Lee
    No mods, yet...
    Jun 03 2009
    Raleigh, NC
    Quote Originally Posted by BlkS4 11 View Post
    Very funny guys. I didn't want the car to default to all my wife's settings which are stored on the second fob.
    Therefore, I took out her battery until I could buy replacements.
    Granted, I could have used the door preset buttons, but eff that - I drive the car 99% of the time.
    Tschüß!
    Ðave
    Veteran Member Four Rings phillips2024's Avatar
    Mar 03 2011
    Southern NH
    mine has been low for quite some time now. havent had time to bring it to the dealer. I thought there was a whole programing step involved which made it so I couldnt simply buy a new battery on my own.
    ill do that today in fear of the key dying and being stranded. ..Cant seem to find my other fob since my wedding ha
    2017 Audi S8+ | 2021 Audi RSQ8 | 2021 Cadillac Escalade Sport Platinum | 2007 Porsche Turbo
    2021 Sea Ray 350 SLX | 2020 Polaris Ranger Crew XP1000 | 2022 Polaris Indy VR1 850/650
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Type of battery CR 2032 3v - can not be recharged as some write here
    Oct 27 2009
    Re: Key Fob Battery replacement
    Quote Originally Posted by phillips2024 View Post
    The key won't forget its settings when you pull the battery out. I've pulled mine out quite a few times.
    Sent from my Galaxy Nexus using Tapatalk 2
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Mar 03 2011
    Southern NH
    great. just did it; dealer was gonna charge 8 bucks for the 1 fob. picked up 2 batteries for 7
    Mar 30 2012
    San Jose
    Mine won't work
    EDIT: Make sure you put the battery in with the correct side up. I'm an idiot.
    Replaced the battery with a brand new one this morning, but the car doesn't recognize the fob. No light flashes on the fob when I press the buttons. Do I need to reset something?
    Fob was working fine with the dying battery, just had to get real close to the car to lock/open. Now I just have to use the metal key to open doors. Thoughts?
    Nov 03 2012
    Calgary, Alberta
    This is my first post, and I hope not to speak out of turn.
    On Page# 41 (with reference to the Keys) of my Owner's Manual, Its says..."If the check light does not come on, the battery is dead and has to be replaced. In addition, when the battery is dead the <insert cool yellow dash lock symbol> appears in the instrument cluster display as well as the message...Please Change key battery...battery replacment > page 41...
    It does not mention nor does it mention anywhere through out the book that the FOB can be recharged by inserting it into the dash. If it could be I am sure Audi would have made a point of well stating this great feature.
    Audi does however say at the bottom of Page# 41 it does say...We recommend having the battery changed by an authorized Audi dealer. However, if you wish to replace the dead battery yourself, proceed as follows.......Ya thanks for the offer Audi, I will take door# 2 and give it a whirl myself and see how it goes.
    Look forward to getting to my know car.
    Does this forum have an App?
    Talk soon, Cheers
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    It cannot be "recharged". The battery is not rechargeable.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by Shott3r View Post
    Did you ever get any resolution to this problem? Would hate to have to go through some sort of reprogramming procedure just because the battery died.
    Feb 15 2011
    Giant TCR C2, Gary Fisher Superfly 100
    thousand oaks, ca
    while on the topic...does leaving the advanced key in the car while the car is off drain the battery (maybe it is searching for connection until you push start)? My wife always forgets it in the car when she parks in the garage and this was when i started noticing the batter replacement message popping up (happened to be 1.5 years into life of the car).
    Also, was there a conclusive agreement that inserting key fob does/doesn't charge the key? Sounds like it doesn't?
    Veteran Member Four Rings Deckdout2's Avatar
    Sep 13 2010
    2010 Audi B8S4 Ibis Prestige (SOLD), 2016 Audi C7.5 A6 Prestige (SOLD), 2004 Audi C5 A6 4.2 - 6spd
    Charlotte, NC
    Has anyone had to reprogram or resync their keyfob to the car after this? I can't get any of my Advanced Key Functions to work now. Only Unlock, Panic, and Trunk Buttons, but the car does not recognize the Advanced Key. Any ideas out there?
    APR Stage II+ | APR TCU | APR Ultracharger | APR Dual Pulley | APR CPS | APR Open Intake | AWE Non-Res DP & Touring | H&R Coilovers | Hotchkis F/R Sways | Alu Kreuz Stabilizer Bar | USS F/R Endlinks | SPC Adj Arms | 034 Arms Kit | 20 x 9 +35 Rotor Reps | 255/30/20 V12 evo2 | RS6 Pedals Shifter | RS6 Shift Knob | Audison/Hertz Amp & Sub | RS4 Grill | Deval CF Splitter | Facelift Flat-Bottom | S6 Start/Stop Button | oCarbon Red CF | Relak v2.0 Paddles | ECS Stage 1 Brake Kit
    Veteran Member Three Rings dawei213's Avatar
    Oct 05 2011
    Philadelphia, PA
    No, I recently just replaced the battery and everything still works fine. Might want to swing by a dealership for them to take a quick look.
    2012 S4 | REVO - Stage 1 | AWE Resonated Exhaust | BILSTEIN PSS10 | Eurocode Alu Kreuz | ALU FELGEN SF-71 HB 19x9.5 | H&R Spacers 15/20 | 20% Tint
    Senior Member Four Rings dbX79's Avatar
    May 24 2012
    2011 BMW 328i Coupe
    Atlanta,GA
    That's cool that's the first time I took the battery out of a Audi key fob. Helpful info now I can just hit up RadioShack or Wallyworld for a new one. Sweet!
    2013 S4 Ibis White | Black Nappa Leather | DSG | MMI Navigation Plus | B&O | Sports Differential |Carbon Atlas Inlays | 19" 5 Spoked Peelers | VAG Com |
