Results 1 to 15 of 15
Thread: 3.0 30V-ers
    Established Member Two Rings greenpelikan's Avatar
    Nov 04 2004
    Audi A4 3.0Q S-Line
    Los Angeles (Silverlake), Cali
    3.0 30V-ers
    Hello all you 3.0s or maybe the few of us.
    Please give a shout if you're out here.
    Inquiring minds would like to know.
    "Stand on the right!"
    USP CLUB MEMBER #88
    2005 A4 3.0Q S-Line
    Veteran Member Three Rings KaiDaRudeboy's Avatar
    2003 A4 3.0Q
    Hawai'i/SoCal
    Re: 3.0 30V-ers
    i've got a 3.0
    -Kai
    Nov 04 2004
    Audi A4 3.0Q S-Line
    Nice Ride!
    I just got back from a Vegas trip and the drive was wonderful. Cruzin around 100 while the traffic was light.
    USP CLUB MEMBER #88
    2005 A4 3.0Q S-Line
    Mar 10 2005
    99.5Audi A4 2.8 quattro/03 Suzuki GSX-r 600
    Las Vegas, Nevada
    holla!!! reppin the 2.8's in las vegas
    Veteran Member Three Rings slee22's Avatar
    Oct 27 2004
    2016 Q5 Premium Plus
    Houston, TX
    I've got a A6 3.0.
    I wanted a black 2.7T, 6-speed, quattro. I ended up with an Alpaka 3.0, CVT, FWD. Oh well, at least it's pretty.
    2003 Porsche Targa
    GT3 Front Bumper / GT3 Underpinnings / Fabspeed Maxflo Exhaust; 100-cell Cats / Fabspeed Tune / LN IMS / Andros Spec P Wheels
    2010 Q5 3.2 Premium Plus (Gone)
    X-Pipe - Resonator delete / Eurocode Billet Trans Mount / LED Fogs / VCDS Goodies / SQ5 20" Wheels / Facelift Q5 345mm Brembos
    2016 Q5 3.0T Premium Plus
    Tech, Black Optic, S-Line, Sport / Stock...for now
    Established Member Three Rings db boy007's Avatar
    Sep 22 2004
    2004 Porsche C4S-2003 Audi Avant
    Palmdale California
    I'm a '03 Avant with every extra option that come on a Audi and I love it. It is just waiting for the supercharge kit, and it will be all that.
    Sep 16 2015
    Chicopee,Massachusetts
    I have an 02 Audi A6 Quattro with a 3.0. Awesome car
    Sent from my SM-G950U using Audizine mobile app
    Active Member One Ring Charlzy1979's Avatar
    Sep 11 2017
    Leeds United Kingdom
    I have a 3.0 and it’s been the Bain of my life!! Plagued with overheating problems 😩
    Nov 23 2018
    Vito (2.2 w211 eclass lump/turbo) WORK BRICK.
    harwich, essex
    just acquired a tidy 2003 3.0 30v avant.
    so far fairly impressed as a comfortable cruiser but it needs a bit more ooomph, time to get the spanners out :)
    Red meat is in no way bad for you....
    Furry green meat however..........................
    Jan 24 2019
    St. Clair Shores Michigan
    I've got an 02 a4 quattro 3.0 with a 6 speed. I love the car, just put a new clutch in it at home. I really want to find some performance parts.
    Oct 15 2018
    san clemente, ca.
    I purchased a 2004 a-6 3.0 about a year ago. Not running. A cam gear bolt had broken so I had the heads done(3 bent valves) and it's all back together $3k later. There's a Technical Service Bulletin, 17 Engine oil pressure is below specified value. So, I'm wondering if anyone has experience with oil pressure problems, as that oil pump is not available in USA. The car is running, but oil pressure light is on and engine shuts down.
    ∞[/SIZE][/SIZE]
    Senior Member Three Rings Dodaman's Avatar
    Mar 27 2018
    Have an 05 A4 Quattro, 3.0 with 5 spd tip, cabriolet. Had a few issues with coolant flange leak, output shaft seal. All fixed now. Did timing belt and all the accessories. Runs great. Love the car. I agree it would be nice for a bit more umph but good for now.
    2005 A4 Cabriolet Quattro, 3.0L
    Senior Member Four Rings Deerhurst's Avatar
    Jul 22 2019
    1986.5 SE-V6 4x4 Nissan D21
    Oregon
    Yo! Tuned 3.0 A4 Avant 6MT!
    Oct 21 2019
    Sydney Australia
    Hi all, got my self a great looking A6 C6 3.0 2005 but mechanically not great for cheap down under in Australia. Writing this so it may help some of you. Got a random misfire and B1 S1 fault. Cat was glowing red also. Wasn’t safe to drive. Very random misifre, some days it was good other not and so my problems kept on going. Had all sparks replaced, coils too, throttle body cleaned, maf tested + cleaned, fuel injectors cleaned, PCV valve replaced, checked for carbon build up ( all clean). Same old day in and day till I had a pro look at the car and found out that connectors on fuel injectors was ware lose on almost every single one. As the car hits a bump it may come good, and other times goes bad. Weird part is, not the connectors but the wiring inside them. So my problems are solved now. Will enjoy the old my new Audi from Monday. Hope this helps, as the pro said to me, apparently they do this and I have read just about every post on rough idle there is and also had an electrician look at the car when i got and found no problems. Also no check engine light, or any faults came up of this kind. Even the misfire was some days on and other days not showing.
    Hope I made sense and helped someone who might read this.
    Cheers boys and girls
    Junior Member Two Rings
    Nov 12 2020
    2018 Toyota Rav 4 Hybrid
    Brooklyn, NY
    I know i'm WAY late, but.... 2016 B8.5, glad to be here!
    2016 SQ5 Premium Plus "Blaque Widow"
    APR ECU Stage 1
