Page 3 of 3 FirstFirst 123
Results 81 to 120 of 124
Hybrid View
    Apr 30 2015
    Weston, Florida
    Hi i order the 23mm spacers with 58mm bolts and was so exciter to install them today. But when i opened the box found the spacers :-) but the bolts say 48mm. :-( will they fit? Or should i request for the longer ones. Bummer :-(
    Registered User Four Rings Dion@Achtuning's Avatar
    Jul 01 2008
    ^ Saw this after our phone call this morning. Sorry again for the inconvenience - incorrect bolts were indeed pulled. We've got that replacement order already en route!
    Jul 01 2008
    One of our most popular, the Hartmann HTT-256-MA:M wheels are back in stock at Achtuning! Call 425-895-0000 or order online by clicking the image above!
    Veteran Member Four Rings Jupiteraudi's Avatar
    Mar 29 2009
    01 S4 Avant 6spd, 08 S4 DTM pkg.
    Jupiter
    I believe it was mentioned earlier in this thread but I'd like to confirm the oem bolt length for a 2015 Q7 TDI. Are they 35mm? I'm on the 21' peelers.
    Jul 01 2008
    Quote Originally Posted by Jupiteraudi View Post
    Yes, they are.
    Apr 15 2007
    WNC
    Any specials for us Q7 folks looking to pick up a set of winter wheels? PM if you have something for me!
    2013 RS5, 2014 Q7
    Jul 01 2008
    Getting that PM written up now. Check inbox shortly.
    Jul 01 2008
    We determined the QuattroWorld.com Audi Q7 needed 18mm DR style H&R wheel spacers up front and 30mm DRA style spacers out back to even out the "stance" and give the Q7 a much more aggressive look. Mission accomplished!
    Nov 30 2011
    Portland Oregon
    That looks awesome. I have a Q5 S line (2011) . Could I run the same rim/tire/spacer combo you have on the Q7 ? , if so what is the spec
    Thanks ...
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    The Q5 and Q7 use some pretty different specs though you may be able to use wheel adapters to run the OEM Q7 wheels (5x130 bolt pattern) on the Q5 (5x112 bolt pattern). The OEM Q7 wheels are a 21x10" with an ET44 offset. Adapters are usually available in 20-25mm thickness. Running a 10" wheel with an effective ET24 offset of the Q5 would place the face of the wheel outside of the fenders though which may not be the look you are trying to achieve.
    Another option would be to pick up a set of Hartmann HRS6-204 wheels in 20x9.0" ET25 which would be a direct fitment and pretty aggressive looking on the Q5. The wheels are currently only available in gloss silver but you could probably have a local wheel repair shop refinish them in the Audi style titanium finish for a few hundred dollars.
    http://shop.achtuning.com/Hartmann-H...eels-Audi.aspx
    Jul 01 2008
    Ryan sends us pictures of his S-Line Audi Q5 on some 20" Hartmann HRS6-204 wheels! Thanks for sharing, Ryan!
    Nov 30 2011
    Portland Oregon
    Thanks guys for the reply. I still think the wheel well is to big on Ryan's , that's what I'm trying to avoid . I already have the Audi 20" rims . Im looking to drop it and add an exhaust system . But I love the aggressive stance of the Black Q7, that's the look I want
    Senior Member Three Rings Symko's Avatar
    Jun 10 2011
    ‘12 Glacier S4 ‘19 SQ5 (wife’s)
    Reston, VA
    Quote Originally Posted by Dion@Achtuning View Post
    Dion is your Q7 adaptive air, coilovers or springs? I love the setup but I do not have adaptive air and hate how high our Q sits. I would really love to improve on the stance.
    Thx, Dave
    Jul 01 2008
    Jim negotiated a Hartmann Wheel install when he bought his new Audi Q5 from Audi Wilsonville in Oregon. Soon after taking delivery, Jim was on our door step in anticipation of having the 20" Hartmann HRS6-204 Wheels thrown on his new ride! The factory offsets are always a bit on the weak side and we mentioned to Audi Wilsonville that the 20x9 +25mm offset would be a better fit for the Q5, filling the fenders out nicely and giving it that much needed, aggressive stance. We're glad they went for it, and we're happy to report Jim is a happy customer!
    Senior Member Three Rings Boom's Avatar
    Oct 29 2012
    08 Jetta
    VA Beach
    What width,offset,spacers would you need to get the exact same stance on a Q5 with the Hartmann HRS6-204?
    So these are not Hartmann wheels? OEM?
    Feb 14 2007
    Redmond WA
    Quote Originally Posted by Boom View Post
    Hard to say as the Q7 and Q5 are completely different applications but our 20x9.0" ET25 offset is pretty flush on the Q5.
    The wheels on the Q7 are OEM Audi, the wheels on the Q5 are Hartmanns.
    Oct 29 2012
    08 Jetta
    VA Beach
    Quote Originally Posted by Skyler@Achtuning View Post
    Flush with the front fender or rear?
    Jul 01 2008
    While we are very brand loyal with regard to the parts we sell at Achtuning, we certainly wouldn't turn away an install of reputable-brand parts we don't offer, especially when it comes to brake and suspension upgrades as we feel we specialize specifically in those areas. So when Jason contacted us to install a set of KW V2 coil-overs on his Q5, we were happy to oblige!
    An already fantastic-looking Audi Q5 thanks to the Caractere body kit and HRE wheels is made even better with the lowered stance and performance-oriented suspension! Thanks for the opportunity, Jason!!
    Jul 01 2008
    StopTech has unveiled their new line of racing brake pads!
    StopTech, the ultra performance and racing brand from Centric Parts, introduces a new line of StopTech Racing Brake Friction that brings the company’s “Brake Late, Finish First” philosophy to a wider range of racing disciplines. The new racing pads complement the company’s extensive range of high performance brake component and system upgrades - and help turn any StopTech system into a dedicated race system.
    Available in four formulations, the new StopTech Racing Brake Pads are engineered to provide optimal friction levels for a variety of different racing applications. All StopTech Racing Brake Pads provide shorter stops, increased control through superior pedal modulation, and fade-free performance at extreme racing temperatures. StopTech Racing pads are designed to provide superior performance in any racing brake system, and match the outstanding performance capabilities drivers have come to expect from all StopTech Racing Brake Systems and components.
    StopTech's unique metallic compounds are blended with carbon and graphite particles to provide an optimal high temperature race friction material. The result is smoother, more predictable and more consistent brake engagement along with exceptional release characteristics not found in most other racing friction materials.
    StopTech engineers work directly with race teams, often trackside, to gather valuable experience in dynamic real world conditions. Data is immediately integrated into the research and development process, resulting in optimized brake systems for individual racing programs.
    StopTech Racing Brake Pads Provide:
    • Optimized friction levels for shortest stops
    • Engineered for extreme temperatures
    • Superb modulation and release characteristics
    • Low compressibility for precise pedal actuation
    • Excellent pad and rotor life
    Pad Compound Characteristics
    SR34 Compound
    • Superior pedal feel and modulation characteristics
    • Formulated for high initial bite
    • Slight torque rise with temperature
    • Extremely low pad and abraded disc wear
    • All purpose pad for high grip, high power applications
    SR33 Compound
    • Slight reduction in torque compared to SR34 Compound
    • Excellent pedal modulation for applications requiring a medium friction level
    • Flat torque curve with temperature rise
    • Extreme fade resistance
    • Great for rear applications that require less friction but same level of control as SR34 Compound
    SR32 Compound
    • Similar friction levels to the SR34 Compound
    • Linear torque curve with temperature rise with excellent release characteristics
    • Superb abraded disc wear
    • Maximum high-temperature stability
    • For medium to high horsepower applications that require higher friction levels
    SR30 Compound
    • Medium to low friction levels with linear torque curve with rising temperature
    • Extreme high temperature fade resistance
    • Excellent modulation and release characteristics
    • Repeatable performance
    • For Touring Car rear applications and others requiring lower torque
    StopTech Racing Brake Friction products are available now. For more information about any StopTech product or to place an order, visit www.achtuning.com or give us a call - 425-895-0000.
    Jul 01 2008
    GOOD NEWS!! MANY of you are on waiting lists for wheels that have been out of stock for a LONG time. It's been frustrating for everyone and we can't thank you enough for your continued patience! As of this morning's sales meeting, we are told the first (of several) Hartmann Wheel containers will be shipping THIS week! That puts us in the 4-week (ish) time frame for delivery of our first shipment. STAY TUNED for Hartmann Wheel delivery updates at ACHTUNING!
    Jul 01 2008
    Achtuning is announcing new low prices on AWE Tuning exhaust systems starting Monday, February 8th. We will be lowering our prices and offering an additional 8% off those lower prices with FREE SHIPPING anywhere in the “Lower 48!” No tax for our out-of-state customers!! And even better, Achtuning is stocking the most popular applications so your order ships as soon as you “check out” online. Contact the Achtuning sales team with any questions, and thanks in advance for your order!
    Jul 01 2008
    If you haven't already, sign in and follow us on Instagram @Achtuning! Here's the link to our Instagram online profile: http://instagram.com/achtuning/ And don't forget to tag us using #Achtuning when taking pics of your Achtun'd ride!!
    Jul 01 2008
    12-21-12 is Free Freight Friday at Achtuning!
    Achtuning is offering FREE ground shipping in the lower 48 states on all Hartmann Wheel purchases currently listed at full MSRP! Go online to achtuning.com or call us at 425-895-0000 to place your order!
    Jul 01 2008
    TODAY IS THE DAY!! This very RARE FREE SHIPPING offer (good within the lower 48 States) on any Hartmann Wheel order not already on sale is on! Take advantage and place an online order at ACHTUNING.com or give us a ring - 425.895.0000!
    Jul 01 2008
    ACHTUNING will be closed on New Years Day but will re-open on Wednesday, January 2nd. We still have plenty of Holiday Specials for you to take advantage of! Click the link below to check out our "special offers" summary...
    http://achtuning.com/specials/special-offers-summary/
    Jul 01 2008
    APR is pleased to announce an unplanned 24 hour sale to thank all of their loyal customers and to commemorate Audi’s 1-2 victory and APR’s podium finish at the Rolex 24 Hours of Daytona! The sale is live from January 30th at 6PM to January 31st at 6PM Eastern Standard Time. Shop online at Achtuning.com NOW until 6PM EST tomorrow and get SALE PRICING on just about anything offered by APR - since we STOCK these items your ON SALE purchase will ship immediately!! GO APR!!!
    Jul 01 2008
    Friendly reminder that we do wheel alignments and corner balancing here at ACHTUNING! Send us an email to [email protected] or give us a ring at 425-895-0000 for scheduling and quotes.
    Jul 01 2008
    A big "Thank you!" to our friends at University Audi for lending us an Audi SQ5 for verifying Hartmann Wheel fitment over those massive brakes! Fortunately we have a good selection of large caliper clearing wheels so your Audi SQ5 Hartmann Wheel options are plentiful! The Hartmann Wheel website will be updated with SQ5 fitment specs shortly and we'll be adding the brand new "Audi SQ5" model section to the Achtuning.com online store soon. Give us a ring at 425-895-0000 and get a head-start on your winter wheel shopping!
    www.achtuning.com
    Jul 01 2008
    Shortly after taking delivery of their new brand new Audi SQ5, the Conner’s rolled in from Yakima to pick up a set of 20″ Hartmann HRS6-204-MA (matte-anthracite) wheels to run this Winter. The HRS6-204 is one of many options we have available for SQ5 owners looking for alternative Winter wheel options. Give us a call and let us set you up with the ride look this Winter for your Audi SQ5!
    Jul 01 2008
    For our local enthusiasts!
    Jul 01 2008
    Buy and install H&R or Vogtland suspension upgrades at Achtuning and receive a FREE wheel alignment once that new suspension has had time to settle! This promotion will last through the month of June. Check out your suspension options by visiting our online store or call 425-895-0000 and let’s upgrade your suspension!
    In, Out and Around...
    any photos of the PQ6 "Peeler" wheels in 22" on a Q7?
    i noticed these are et50 and 9.5" when stock are et44 and 10".
    the stock wheels are pretty conservative and recessed... do these 22" sit recessed in the wheel well?
    Jul 01 2008
    Quote Originally Posted by iconoclast View Post
    Compared to those stock specs you list, yes by 12mm. Sadly, no images of the 22" HRS6-204s on a Q7 yet but the pic below should give you an idea as the Hartmann HRS4-252s share the same spec...
    We also stock H&R wheel spacers for the Q7 which were added to this same Q7 to achieve a better over-all "stance".
    ( ^ a pair of 23mm spacers were added, front and rear.)
    Jul 01 2008
    Achtuning is excited to announce the arrival of two NEW additions to the Hartmann Wheel line-up!
    HRS7-163-MA:M (matte-anthracite/machined)
    The Hartmann HRS7-163-MA:M is currently available in the following specs:
    * 19×8.5 +25, $310 ea.
    * 19×8.5 +38, $310 ea.
    HRS6-091-MA:M (matte-anthracite/machined)
    The Hartmann HRS6-091-MA:M is currently available in the following specs:
    * 20×9 +29, $370 ea.
    * 20×9 +40, $370 ea.
    As with all high quality Hartmann Wheels, factory Audi center caps and factory wheel bolts are compatible. These are IN STOCK, ready to ship! Place an online order by visiting our online store or call 425-895-0000.
    Jul 01 2008
    Bundle up with an ACHTUNING pull-over hoodie this Winter, only $39.95 shipped! (Avail. sizes: Mens’s M-XL)
