Results 1 to 2 of 2
Hybrid View
    Senior Member Two Rings Tyrnnus's Avatar
    Jun 23 2011
    Calgary, AB, Canada
    Any way to get a digital signal from B&O audio?
    As the title suggests, I am going to add a "small" amp for a sub and was hoping to avoid using line level signal
    Veteran Member Three Rings Kandiru's Avatar
    Mar 28 2010
    Isolation, OH
    There is nothing to be gained from that, unless you had a very long run of cable.
    Better cables, with lower AWGs and silver soldered gold plated connectors would
    theoretically improve things though.
    The amp will have to do a D/A conversion and unless you paid an extra $1000 for
    the electronics in it, the pre/pro in the radio is much better equipped for this job.
    Bit of A/V addict here, filtered pre/pro > monoblock balanced amps > Paradigm Reference
    5.1 SACD and 7.1 DTSHD-MA in my basement cave.
    2012 S4 6MT Monsoon/Silver-Alc./Diff+B&O+airbags, Mods:R8 V10 St.Wheel, JHM Shifter, Summer: S5 Double Spokes 8T0601025H - Bridgestone RE-11 245/35R19 (ET32), Winter: Hollow Spokes 8K00714994EE - Dunlop 255/35R19 with BFI-5mm-Fr+10mm-Rear & RAD 35mm bolts/locks, Customcargrills upper/lower/L-fog radiators protection, Oil Dipstick, RS4 pedals x4 & Autovation Heel Guard, Seat Bins, Trunk Triangle, Laminx fronts+fogs+edges+bumper, Windesa Sonniboy 8K Curtains
