Results 1 to 7 of 7
    Veteran Member Four Rings Deckdout2's Avatar
    Sep 13 2010
    2010 Audi B8S4 Ibis Prestige (SOLD), 2016 Audi C7.5 A6 Prestige (SOLD), 2004 Audi C5 A6 4.2 - 6spd
    Charlotte, NC
    So.....I either busted a coolant hose or my radiator. Time to upgrade?
    Got in my car after work yesterday, and proceeded to back out of my parking space. Car yells at me and tells me to park and check my coolant level with a "Red" coolant symbol appearing in the DIS display. It's low for sure, but I make it home with no other issues with overheating or drive ability. I get home and park and go change before I try to go back and diagnose the issue. About 30 mins later, I come out and there's a huge pool of coolant in front of my car, pop the hood, and I can see the vicinity from where it is leaking. Looking down between the motor and radiator looks to be in the area of a lower hose on the right side of the radiator/intercooler, but I think I'm going to have to pull the under panel off at least to see what exactly it is (either hose or radiator). I'm also thinking that to replace/repair this part if it is indeed the hose, I'm going to have to pull the front end off again.
    This sucks, as the car only has 5k miles and is a 2010. Anyone every heard, seen, experience this before? Water pump and thermostat recall was done on the car, I have all the APR performance mods, I don't know what could have caused this besides heat. I'm going to find out from Audi if it's covered under warranty today. Could it have been the gains from these mods that caused this? I'm thinking not as I would have heard/read about it already if so. My consensus is this, if I have to just replace a hose then I'll do just that. If there is more damage as in the radiator or intercooler parts, then I'll upgrade to the complete APR Coolant system. However, I don't think that the APR system was created to prevent this on a modded car, but to keep temps lower in the coolant system am I correct? How much pressure is going through that lower line for this to occur?
    At anyrate, wondered if anyone on the forums had any ideas on this issue.
    Thanks-
    -Paramy
    APR Stage II+ | APR TCU | APR Ultracharger | APR Dual Pulley | APR CPS | APR Open Intake | AWE Non-Res DP & Touring | H&R Coilovers | Hotchkis F/R Sways | Alu Kreuz Stabilizer Bar | USS F/R Endlinks | SPC Adj Arms | 034 Arms Kit | 20 x 9 +35 Rotor Reps | 255/30/20 V12 evo2 | RS6 Pedals Shifter | RS6 Shift Knob | Audison/Hertz Amp & Sub | RS4 Grill | Deval CF Splitter | Facelift Flat-Bottom | S6 Start/Stop Button | oCarbon Red CF | Relak v2.0 Paddles | ECS Stage 1 Brake Kit
    Veteran Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    Busted intercooling radiators are not uncommon and the symptoms match yours. It's not a warranty item but considered "wear and tear" (yet for some reason there is an OEM protection screen available that comes on the A7). It's like $700 to fix if I remember correctly. If that is indeed the case, it's definitely a good time to go ahead and do the APR CPS upgrade as you'll save money if you plan to do it anyways down the road.
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, B8.5 MMI 3G+ Nav, Ti Pkg
    APR Stage 2+ Stock/93/100/Valet, Eurocode Alu Kreuz, Eurocode USS Sways + End Links, Eurocode Meisterwerk SSK, Roc Euro Intake, Apikol Rear Diff Mount, Fast Intentions Exhaust, Escort 9500xi, Laser Interceptor, P3 Vent Gauge, VCDS
    Sep 13 2010
    Charlotte, NC
    Quote Originally Posted by helix139 View Post
    Just spoke with Audi of Charlotte, and they said that it was a warrantied part, even though they haven't looked at the car yet. Audi Roadside is getting my car towed to the dealership at the moment. I'll give a heads up on what's going on.
    Sep 13 2010
    Charlotte, NC
    Welp, they called me back and said that this wasn't a warrantied part as helix mentioned. I canceled the Roadside and will tackle this myself. I hope it's a part that the APR kit replaces as if so, I will go ahead and perform the upgrade.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Dealer replaced mine for $450 + tax.
    Veteran Member Three Rings Kandiru's Avatar
    Mar 28 2010
    Isolation, OH
    Build yourself meshwire grilles for upper, lower, and behind left foglight housing radiators.
    There are plenty of DYIs on this here, still cannot believe Audi won't cover.
    http://www.audizine.com/forum/showth...oling-radiator
    2012 S4 6MT Monsoon/Silver-Alc./Diff+B&O+airbags, Mods:R8 V10 St.Wheel, JHM Shifter, Summer: S5 Double Spokes 8T0601025H - Bridgestone RE-11 245/35R19 (ET32), Winter: Hollow Spokes 8K00714994EE - Dunlop 255/35R19 with BFI-5mm-Fr+10mm-Rear & RAD 35mm bolts/locks, Customcargrills upper/lower/L-fog radiators protection, Oil Dipstick, RS4 pedals x4 & Autovation Heel Guard, Seat Bins, Trunk Triangle, Laminx fronts+fogs+edges+bumper, Windesa Sonniboy 8K Curtains
    Jul 17 2010
    2015 Ducati Panigale 1299S, 2016 Cadillac Escalade ESV
    Georgia
    Quote Originally Posted by Deckdout2 View Post
    The radiator is replaced with the APR kit. I would definitely install the DIY wire mesh screen after getting the APR kit.
    2017 Audi S6. Stock. Boring, bone stock.
