Thanks hilld! I'd not seen that tool before but definitely now want one.
I got those bolts eventually and got the new axle in! Just hoping for an easier time with the other side's axle. Going at it tonight.
Here's the exact method that I eventually got to for removing my particular stuck, stripped bolts:
Tools:
• Hammer
• Drill
• 7/32" Titanium drill bit
• 1/4" Titanium drill bit
• breaker bar
• Approx 30" of wrench extender(s.)
• Large pipe for leverage that fits over your breaker bar's handle. Mine is the handle of my floor jack.
• 1/4" socket
• Irwin Industrial Tool 53227 Hex Head Multi-Spline Extractor Set - I did not note which 2 of the 25 extractors in this kit were used. Sorry! PM me if you're in the same boat and want to know.
Always engage the parking brake fully. Use jackstands and not a jack alone. Especially important here because the force that I needed to break my bolts loose was more than you'd need to push over a car jack. Like by an order of magnitude. Once my car is lifted into what I think is a safe position, I walk around pushing hard on the car anyway to ensure no movement.
So that your wrench can eventually be horizontally aligned with bolt, rotate the axle to put the stuck bolt into the position shown below. The photo is of the threaded hole after a bolt had come out. Both front tires must be lifted to rotate axle and after that the opposite side tire should be lowered to the ground again to prevent any other rotation of axle. If you get confused by rotating to position, you're not losing your mind. These axles rotate inversely to each other. CW on one moves the other CCW. At least for a tiptronic in park.
The extractor bits will work eventually but without drilling the bolt, it's hex head is not deep enough for the extractor bit to get much of a bite. Use first the 7/32" bit to drill straight into the bolt's hex head. I don't know why and maybe it was just my bits but the 7/32" bit was able to dig into the bolt easily while the 1/4" bit would not. I eventually had to drill about a half inch of the bolt's shaft. The 1/4" bit was helpful in widening this hole after it was made by first bit. The bolt after drilling looked like this:
Fit the large pipe over your breakerbar and keep it within arm's reach. Find the biggest extractor bit that will fit into this hole at all. Put in hole and fit your socket with extensions onto it. Then wail on the extension with a hammer to drive the bit into the drilled hole as much as possible. While holding still the extension, drop hammer and lift breaker bar, try to attach it to the extension without jostling the extractor bit out of it's position. Do a power stance with legs (think Kirk Hammett soloing) and place weak hand at extension end of pipe. Strong hand farther away. Keep your body and face as much away from the bolt as possible, then try to twist the bolt out. I broke one cheap breaker bar doing this and saw a stronger one felt a strong healthy fear about metal parts snapping and flying at me. Keep others away and protect yourself as best you can. This is probably pretty dangerous.
Your extractor bit may just slip off this time and with subsequent efforts too. What I found was that a single hard try at this widened the drilled hole in bolt enough for the next extractor bit in size to fit. That's the one that was able to finally break free both of my stuck bolts.
