Page 8 of 8 FirstFirst ... 678
Results 281 to 285 of 285
  1. #281
    Jun 27 2019
    2019 Forester Limited
    Encinitas, CA
    Quote Originally Posted by if6ws9 View Post
    Its likely that the pin, or whatever it is that goes into the slot of the shaft is fully engaged, preventing the shift knob from being freed. At this point you don't have many options, I'd start dismantling the shift knob, piece by piece, it'll destroy it but it might be the only way to get it off. Good luck and keep me posted.
    This is exactly what happened and what I wound up doing. I ripped off the button, which freed up the top surround. I could then see down the top of the knob and dislodge the pin and pull the knob off. It was still really stuck in there and I had to use a slide hammer to get it off.
  2. #282
    Veteran Member Four Rings if6ws9's Avatar
    Feb 08 2012
    Grand Cherokee
    Palm Harbor, Fl
    Quote Originally Posted by mattymess View Post
    Glad it worked out without damage to the car, it must've been nerve wracking having to deal with that. It might have been a faulty shift knob, will they replace it or will you have to order a new one?
    2014 A5, Gloss Boat Blue, Black Optics, Sport package, MMI+, B&O, AWE Touring, AWE DP, USP HFC, CTS CAI, APR Stage 2, ST Coilovers, Alu Kruez, 034 TX insert, ECS diff bushing, Apikol blue diff mount, VAG's, Escort Redline, ZR4 shifters, 20% tint, Sprint Booster, ECS dipstick, FB steering wheel, piston diverter valve, ECS rear lower control arm brace, 10mm & 12mm spacers, BFI shift knob, CR 15, powder coated calipers, extended paddles, Vossen CV3-R's, Eurocode F&R sways, RS grille
  3. #283
    Jan 01 2021
    New Jersey
    This saved me big time. 2016 s6. Stock shifter. Removed it to change boot. Pressed the Everton while taking it off. Super easy, took 30 secs. Didn’t push all the way up. About a half inch from top and twisted it.
  4. #284
    Veteran Member Three Rings Lauri0112's Avatar
    Jan 29 2015
    Estonia
    Having some issues installing the knob. Heating and twisting went great. But the button gets stuck in. I have sanded the white plastic down a lot, but still installing the knob after the hard press to engage the lever, button goes in hard and stays in. Also, while messing around one of the few springs popped out. What exactly is the purpose of the springs? They rather pull the trigger in than help push is back out to release the shifter.
    It looks like the spring only mission is to not make button rattle when installed and has no other task. No with only one spring it should work just fine.
    Anyway. Sanded the plastic down a lot. Tomorrow will try the knob again and it still wont make the button pressable, then F it and it will stay as is. Any more sanding and I will sand right through it.
  5. #285
    Jan 29 2015
    Estonia
    After hours and hours I finally figured out the problem. The white plastic rod was not 100% straight. Before I looked at it from the top and it seemed to be straight from every angle, but looking it from the side it was obvious that it was bent forward. So brought out the heat gun again and after 5 minutes the rod was straight as an arrow. And guess what. Popping on the knob, it worked perfectly. So, if you have problems. Make damn sure it is straight in all axes.
