hello,
A4 1.8t 130k, here's the scenario:
Most of the time, engine starts normally. No lights, runs great, no issues.
Occasionally, however, when the engine is hot and has been off for around 10 minutes, but less than an hour or so, the starter will turn for 5-10 seconds before the engins starts. When this happens, the EPC Light comes on, however, if the engine is shut off and started 5 seconds later, it starts instantly, no lights, runs fine.
Scan shows two things - Engine Speed sensor and P0328, both intermittent.
(okay ** just now found similar topics)
http://www.audizine.com/forum/showth...d+sensor+p0328
Looks like I should probably replace the engine speed sensor then? Is it likely that this is tied to the other error code as well?
Any insight would be great - thanks!
