Page 2 of 2 FirstFirst 12
Results 41 to 49 of 49
  1. #41
    Established Member Four Rings
    May 20 2017
    New Hampshire
    You can run meth on a straight 93 pump gas tune and the results are great. Itís even better on legit 100 octane tune. Since the meth will increase the 93 to over 100.
  2. #42
    May 20 2017
    New Hampshire
    And windshield washer fluid will work fine in a pinch, as long as itís not the de-icing kind. Youíll have to look up exactly which chemical additive it is to be safe and avoid the kind that has it.
  3. #43
    Jun 17 2013
    jersey city nj
    Ive heard of people gardening nozzles in front of the inter-cooler and activate when under wot spraying water ing to absorb the heat and avoid heat soak effect. theory. But dont know how effective it is in real life conditions thou
    APR KO4, APR HPFP,RS4 LPFP Cntr,145 bar PRV, APR TP, TT DP, GFB DV+, AWE FMIC, BFI CC, AWE Exhaust, RS4 Exh tips, ST CO, 034 RSB,034 St Dnsty Mtr Mts, New Sth West Bst guage, B7 RS4 8 pot Calipers.Stop Tech slotted rotors.Goodridge SS brake lines frt & rr. Hawk HPS frt & rr. RS4 PS rack, RS4 Servotronic Relay,RS4 rims. S4 mirror caps,RS4 Mesh Style Grill,LED tail lites
  4. #44
    May 20 2017
    New Hampshire
    Home Depot mods are worse than eBay mods. Lol
  5. #45
    Jun 17 2013
    jersey city nj
    No joke. here it is for yourself
    http://www.autospeed.com/cms/article...Spray&A=112690
    https://www.youtube.com/watch?v=NmzLaaFQjiQ
    http://www.enginebasics.com/Advanced...0Sprayers.html
    these was just a few of them
  6. #46
    May 20 2017
    New Hampshire
    Water meth is absolutely going to be more efficient than even one of those professional looking water only sprayers.
    Better living through chemestry. 😀
  7. #47
    Senior Member Four Rings rhfosu's Avatar
    Jan 01 2015
    DC
    Googling things always works.
    https://www.dieselarmy.com/engine-te...nol-injection/
    I can't believe someone would rig up an exterior sprayer for their intercooler. Hilarious.
    "I don't understand Audi enthusiasts. They buy a car that looks like a bar of soap, then they spend money modifying it so it looks slightly less like a bar of soap."
  8. #48
    Senior Member Three Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    chemistry*
    he didnt say it was better, but that it was a thing. if you could dial it in correctly to flash evaporate pre combustion it would absolutely be feasible (obv not better than adding alcohol to gas, but again, not what he said). water cools hot metal, flashes into gas, both of which are highly more flammable than atmospheric gasses, better combustion achieved. problems would be the precision and water quality.
  9. #49
    May 20 2017
    New Hampshire
    Doh!!
