Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 184
  1. #81
    Veteran Member Three Rings Bob This's Avatar
    Feb 28 2010
    2012 Nissan Versa, 2006 Nissan Frontier, 2006 Mazda 5
    Hawaii
    everytime I see the APR radiator on a car i want one that much more, looks so sick
    http://www.facebook.com/sfscc
    S.F.S. - Velocity - L4P - HH - Battle Style SPL - OMaM - GoT
    We sleep until the sun goes down because We're up all night to get lucky
  2. #82
    Veteran Member Three Rings autoluxe's Avatar
    Mar 01 2011
    Chester, NJ
    Quote Originally Posted by Deckdout2 View Post
    Doesn't get any cleaner than this......
    Thats awesome...how does it sound/hit??
  3. #83
    Veteran Member Four Rings Deckdout2's Avatar
    Sep 13 2010
    2010 Audi B8S4 Ibis Prestige (SOLD), 2016 Audi C7.5 A6 Prestige (SOLD), 2004 Audi C5 A6 4.2 - 6spd
    Charlotte, NC
    Quote Originally Posted by autoluxe View Post
    Clean as hell, and overkill! lol
    APR Stage II+ | APR TCU | APR Ultracharger | APR Dual Pulley | APR CPS | APR Open Intake | AWE Non-Res DP & Touring | H&R Coilovers | Hotchkis F/R Sways | Alu Kreuz Stabilizer Bar | USS F/R Endlinks | SPC Adj Arms | 034 Arms Kit | 20 x 9 +35 Rotor Reps | 255/30/20 V12 evo2 | RS6 Pedals Shifter | RS6 Shift Knob | Audison/Hertz Amp & Sub | RS4 Grill | Deval CF Splitter | Facelift Flat-Bottom | S6 Start/Stop Button | oCarbon Red CF | Relak v2.0 Paddles | ECS Stage 1 Brake Kit
  4. #84
    Sep 19 2009
    MA
    is this connected to B&O system?
  5. #85
    Veteran Member Three Rings 2011_S4's Avatar
    Dec 08 2010
    2014 Ford Fiesta ST, 1979 Datsun B210, 2001 Infiniti QX4
    Calgary, AB
    Awesome car. Very well done!
    2014 RS5 | ibis white | black nappa | titanium package w/ sport exhaust
    SOLD - 2011 S4 | premium | meteor gray | black nappa | s-tronic | sport diff | milltek non-res exhaust w/ downpipes | supercharged badges | b&o | carbon atlas | pilot super sport 255/35/19 | 40% tint | roc-euro intake | vmr v710 19x9.5 et 45
  6. #86
    Oct 07 2010
    South Bay/CA
    Quote Originally Posted by queue View Post
    I like how you use the coin holder - never acutally used mine, for anything...
    super clean - love everything about your car - some nice mods!
    Wow, I didnt even know those slits were for coins. lol thanks!
    2011 B8 S4; Quartz Gray Metallic w/ Ti, 25% tint, Black PC Tri-Spokes, Milltek Non-Res w/ DP's, Stasis Tune.
    Black and Gray
  7. #87
    Jun 21 2011
    Can you please provide the specs on a sub and an amp?
    Did you get the gain control installed in the cabin? if so, where?
    Sep 13 2010
    Charlotte, NC
    Quote Originally Posted by oneiztoomany View Post
    It is. Audison has line level inputs, so we were able to use that and connect it to the stock sub harness for input signal. Saved me from having to get a nice set of Stinger RCA cables.
  9. #89
    Sep 13 2010
    Charlotte, NC
    Quote Originally Posted by petrashevsky View Post
    I originally had a Hertz HX-300D which was a 12". After getting the mold for the fiberglass done, the way it would have fit into the space would not have come out as clean as it did, and I'm all about form and function. I opted to move down to a Hertz HX-250D 10". Power difference is 1200W Peak/600W RMS for the HX-300D vs 900W Peak/450W RMS for the HX-250D. Because the volume issue and the efficiency range, the HX-250D performed at a much better/louder range than the HX-300D would have. It's more punchy, but with the same box, the 10" still hits lower.
    For the Amp I went with the Audison LRx 1.1k 1090W. I only have this bridged down to RMS Power @13.8V @2 ohm 1 x 800 watts. I have multiple options as seen in the specs below but, this is the best setup for this sub. Plus the whole setup itself is so much overkill for me it's not even funny. I love it! HA.
    I have the gain controller installed in the pocket to the left of the cupholders. It fit perfect, and the lights sickly match up with the rest of the interior. I forgot to get a picture of that, but I'll get that for you guys later on.
    Specs:
    Hertz HX-250D
    Specs Chart: http://www.hertzaudiovideo.com/Doc/pdf_hx250d.pdf
    Sensitivity: 88dB/SPL
    Comp: Dual Coil Sub
    Power Handling: 900W Peak/450W RMS
    Impedance: 4ohm + 4ohm
    Audison LRx 1.1k
    RMS Power @13.8V @4 ohm 1 x 420 watts
    RMS Power @13.8V @1 ohm 1 x 1090 watts
    Damping Factor 1khz,4ohm 120
    S/N Ratio (a weighted @1V) 100dB
    Crossover Bypass Yes
    Crossover Hi-Pass 50-5kHz @12dB
    Crossover Lo-Pass 50-5kHz @12/24(mono)dB
    THD @ 1kHz 0.04%
    Size: 198mm x 438mmx 56mm
  10. #90
    Sep 19 2009
    MA
    this is exactly what i think i'd want if i end up getting an S4, i have a totally aftermarket stereo in my current car and know from reading others comments that i will be dissapointed with the low end of the B&O stereo. Are highs and mids solid though? Therefor making the system pretty impressive after replacing the Sub with something with balls?
  11. #91
    Sep 13 2010
    Charlotte, NC
    The B&O stock system is ridiculous. I’ve never heard a stock system this clean and at loud volumes. The only thing it was really missing was the lows. So I fixed that problem with this setup. :) Even the mids and highs are super clean already. I had the rear deck and trunk matted as well so it’s solid. The box is full fiberglass, and super light. I think the dynomat is heavier than the amp and sub components. lol This is the first system that I have not wanted to rip out of a car. I couldn't believe how good it sounded, just needed a little extra low.
  12. #92
    Jun 21 2011
    That's a big +1 on B&O. Great, great system out of the box (minus the lows).
    only other thing that it may be missing is max volume, but that's only in extreme cases and maybe its just me.
    my audio guy offered me to replace a stock amp with something more powerful keeping all the speakers (sub is already upgraded), but I'm sticking with what I've got for now.
    Deckdout2 - very nice sub/amp install. Always good to see additions to your nicely built car.
    Post up a picture of a gain control when you can.
  13. #93
    Sep 19 2009
    MA
    sweet!!!!
  14. #94
    Sep 13 2010
    Charlotte, NC
    Moar......
  15. #95
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    your car rocks!
    need a sound sample just for kicks.
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
  16. #96
    Veteran Member Four Rings TofuShop's Avatar
    Aug 24 2010
    your sub and amp setup is awesome. i love how you didn't lose any trunk space at all
  17. #97
    Established Member Two Rings What's Next?'s Avatar
    Apr 06 2012
    LA
    Great looking car and great mods!
  18. #98
    Established Member Two Rings #1steelerfan's Avatar
    Oct 17 2009
    2004 - BMW 330i - 2014 - BMW X3 M Sport
    Huntersville, NC
    what's up man... i live in Huntersville but commute daily to Charlotte... I really want to meet up so I can see & hear your car in person... Looks really nice man... I will PM you my cell
    2012 Audi A4 - Prestige Package w/ MT, Titanium Package, Sports Package
    STaSiS Challenge Coilovers Euro S4 Folding Mirrors
    Sold... - Look in my for sale threads for Vag-Com & more!!!
  19. #99
    May 17 2012
    Houston, TX
    So jealous. This car is amazing. Nice build.
  20. #100
    May 17 2012
    Houston, TX
    What's the specs on the wheels? 20x9 with what back spacing? Do you rub at all? I am loving this setup. Want to get those springs as well. If you don't rub are these springs going to settle a bit more over time causing an issue then? I can't afford coilovers, maybe H&Rs, so hoping the springs can hold me over a few years.
  21. #101
    May 21 2010
    Not sure how youre going to fit golf clubs in there now........................................
  22. #102
    Sep 13 2010
    Charlotte, NC
    Quote Originally Posted by AKPS4 View Post
    I don't have any spacers, and I believe the offset is +35eta on all 4 corners with 255 tires. No rubbing unless I hit a really big dip in the road, and with rear seat passengers. I've had these springs for over a year, and I won't change to coilovers so I can keep my ADS and I have no reason to. The drop is perfect for me, the ride has zero complaints, and I still have full control over my ADS. Springs usually settle about a week after you install them so it's not going to settle anymore for me.
    Quote Originally Posted by Wilbur View Post
    I've actually fit 2 sets in there on a regular basis with no issues. :)
  23. #103
    Veteran Member Three Rings Pworld's Avatar
    Dec 19 2008
    L.A. Palm Tree's and Beaches
    roughly how much did this cost. install wise?
    Previous: 2007 A4, 2012 B8 S4 Bril Red, 2015 S4 Sepang Blue
    Function & Form Autolife / TAG Motorsports / AWE-Tuning / Injen / HRE / Falken
  24. #104
    Sep 13 2010
    Charlotte, NC
    Quote Originally Posted by Pworld View Post
    A buddy of mine has an Audio Shop and has experience with glassing. I can do everything else. We worked on a trade, but I think for him to do the glass box would be about $500. I don't know the exact amount cause we had other variables we negotiated with.
  25. #105
    May 17 2012
    Houston, TX
    Thanks! Def gettin these springs. For the cost of coil overs I'd rather get wheels and springs.
    Where did you get the ghost black finish? I only see a few other finishes available. I am actually considering a gold/bronze color for my grey s4.
  26. #106
    Sep 13 2010
    Charlotte, NC
    It's custom. :) My buddy that owns a wheel shop down here has perfected the powder and spray of Ghost Chrome just for me. I love it and will probably get any future wheels done in this color. It's very unique and is definitely a one off.
  27. #107
    May 17 2012
    Houston, TX
    Damn. Lucky. It's awesome!
  28. #108
    Sep 13 2010
    Charlotte, NC
    A little Stock vs RS4 Grill addition to my build thread.
  29. #109
    Jul 07 2009
    Lebanon
    Looks bad ass with the RS grill!
    SOLD: 2010 A5
  30. #110
    Oct 17 2009
    Huntersville, NC
    i'm digging the color of the LED's in the headlights... what mod was that? we still need to meet up sometime... i actually made it out Cars & Coffee for the 1st time this past weekend but i didn't make it till 10 & some cars were already leaving...
  31. #111
    Sep 13 2010
    Charlotte, NC
    Quote Originally Posted by Wah View Post
    Thanks man. Changed the front end up very nicely. We'll get up again at Cars and Coffee or something with the guys again at some point soon!
    Quote Originally Posted by #1steelerfan View Post
    Yessir, we do need to get up. Shoot me a message for the next event you'll be at, or just hit me up and we'll grab a drink or something. Oct is all over the place for me, so we'll work it out.
    I just changed the bulbs to a 6000k Blesk HID. It's the angle also that gives it that hue. Matches the conversion fogs I did as well.
  32. #112
    May 08 2012
    London
    What's happened to all your photos? All the links seem to be dead?
    2006 Z4M Coupe in Alpine White, weekend/track toy, with lots of mods...
    2010 B8 S4 in Sprint Blue, still stock... for now ;)
  33. #113
    Sep 13 2010
    Charlotte, NC
    Quote Originally Posted by sixspeed View Post
    Facebook thought it'd be funny to change all my links and move my photos to another directory. I've fixed all the links. I hope they don't do that anymore, that was a pain in the ass.
  34. #114
    Sep 13 2010
    Charlotte, NC
    Just a few mods I did this weekend. Enjoy!
    Deval Front Carbon Fiber Splitter
    USS Adjustable Front End Links & USS Rear End Links
    SPC Adjustable Control Arms
    2013 Flat Bottom Wheel - Partial Air Leather - Red Stitching
  35. #115
    Veteran Member Three Rings S4charged's Avatar
    Oct 11 2012
    West Covina, CA
    how do you like the steering wheel?
    Ibis White - 6MT
    APR Stage 2+ / Eurocode Headers / End Links / Sway Bars / Alu Kruez / Short Shifter /
    Milltek RESONATED. Carbon Tips / Stratmosphere Intake / H&R SS / RS4 Grill / VAG Mods --- SOLD
    2016 Prius 4
    2018 RS3 Nardo Grey - Dynamic Plus / Technology / RS Design / Black optics / Carbon Inlays - APR Stage 1
  36. #116
    Sep 13 2010
    Charlotte, NC
    Quote Originally Posted by S4charged View Post
    It's amazing! I thought that it just being aesthetically pleasing was enough, but it really conforms to the interior much better and feels good to the touch when driving. I hate to use this phrase cause it's probably a placebo effect, but I do feel really "in-tune" with my driving and the road.
  37. #117
    May 21 2012
    Toronto & U.A.E.
    awesome ride...clean and functional great job... front splitter looks amazing and the fact that you are tuning your suspension past the regular coils shows good commitment to performance...again good job...
    2009 B8 A4 Stage 1 GCC Release (Daily driver) and Porsche Cayenne GT (Baby Mover)
    2001 Turbocharged Lexus IS300 ... SOLD and Missed
    1998 Turbocharged Honda Civic SiR Coupe ... SOLD and Missed
    "Tuning Isn't a Sport, It's a way of Life!!!"
  38. #118
    Sep 28 2010
    NW NC / DE
    Very very nice and tidy work so far. Great job
  39. #119
    Sep 13 2010
    Charlotte, NC
    A night out in CLT.......
  40. #120
    Veteran Member Four Rings JOS4AUDI's Avatar
    Jul 09 2008
    2008 RS4, 2012 S4, 2013 Allroad
    So Cal
    Deckdout2's Intro/Build Thread
    Love it!!! Still one of my favorites.
    Current Audi's: 2008 RS4 Avus, 2012 S4, 2013 Allroad
    Past Audi's: 2013 A6, 2011 Q5 SLINE 3.2, 2006 S4 SPRINT BLUE, 2001 TT 225, 2006 B7 A4 SLINE, 2008 A4 CAB, 2011 A4 SPORT
