Results 1 to 25 of 25
    Veteran Member Three Rings Mani's Avatar
    Dec 21 2009
    2008 BMW 335i - Dinan Stage 3
    Irving, TX
    upgrade stock headlight bulbs
    I like to get my headlight bulbs upgraded. I like to have something brighter than it.... the stock ones are really dull....
    What are my options? I am not planning to change my headlight housing.... just the ballast and bulbs...
    Thanks in advance...
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Re: upgrade stock headlight bulbs
    Do you have halogens? If so you want a hid kit. DDM tuning sells a kit cheap, lots of people including myself have it. The light output difference is night and day lol. Im upset it took me so long to get it, definately worthwhile upgrade
    http://www.ddmtuning.com/index.php?p...=102&parent=85
    55 watt, H11 bulbs, and nothing over 6000K, I have 4300k bulbs and it looks pure white, OEM zenons are 4500K i bleieve
    2019 SQ5 Prestige
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    If you want to upgrade stockers you probably need to do the bixenons for better quality. DDM kits are good bang for your buck, I think somoene got them for like 50 bucks or so a while back. Our stockers really are kind of a let down. Just in case you just want a replacement they're 4300 D1S bulbs.
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    Dec 21 2009
    Irving, TX
    Yes... I have the halogens..
    Thanks for your suggestion... I do not have auto-leveling option in my 3.0 L.... this kit still fits the bill?
    Dec 21 2009
    Irving, TX
    Quote Originally Posted by Dan1969 View Post
    Thanks Dan... I don't want to replace the bulbs with same model.. I am not happy with the stock bulbs.... they are really not bright enough for me.....
    I will try one of the Bi-Xenon DDM kits ...
    Veteran Member Four Rings BlackB6's Avatar
    Apr 03 2008
    Pennsylvania
    Yes, skip upgraded bulbs and just get the DDM HID kit!
    Dec 21 2009
    Irving, TX
    Quote Originally Posted by BlackB6 View Post
    Is there any specific DDM HID kit that you guys can suggest?
    http://www.ddmtuning.com/index.php?p...=101&parent=85
    This one says slim Ballast...
    Veteran Member Three Rings A4.Rob's Avatar
    Sep 02 2009
    Toronto, Ontario
    Get the ddm slim ballast 5000k, its really nice pure white light with the very slightest hint of blue.
    Dec 21 2009
    Irving, TX
    Quote Originally Posted by A4.Rob View Post
    Thanks Rob. Does it require any additional wiring?
    Apr 03 2008
    Pennsylvania
    Quote Originally Posted by mani View Post
    I have the 55w 8000k slim ballast kit. The color is similar to 6000k, the color is washed out a bit due to the higher wattage. It's a crisp whitish blue color and very bright. Spend the extra $ and get the 55w kit, you won't regret it .
    Dec 21 2009
    Irving, TX
    Good deal. Thanks! I will go for the 55w slim ballast kit. I am planning to upgrade only the low beam. I dont want to upgrade my fog lights yet...
    Apr 01 2007
    houston texas
    Yea get the 55W kit. and no it does not take any extra wiring. for the install you need to attach the ballast under the headlight (where the OEM ballast would go), and punch a small hole to run the wires through the plastic. Then just stuff the wires back in and reinstall the lights. Takes about 30 minutes.
    2019 SQ5 Prestige
    Established Member Two Rings winreboot's Avatar
    Jan 06 2010
    A6 TDI, Q7 4M
    NE PA
    Does anyone have DIY for installing HID's? (maybe with pictures)
    Thanks,
    Dave
    Quote Originally Posted by texasboy21 View Post
    Apr 01 2007
    houston texas
    Quote Originally Posted by winreboot View Post
    Thanks,
    Dave
    this link came up as the first listing on google after I searched 'audi a4 ddm hid install'
    http://www.audizine.com/forum/showthread.php?t=260948
    2019 SQ5 Prestige
    Dec 21 2009
    Irving, TX
    For headlight low beam is it H7 or H11?
    Thanks,
    Senior Member Four Rings spector's Avatar
    Sep 08 2009
    SE
    Thanks,
    I think it's h7, but I could be wrong.
    I hope I'm right, though, because that's what I just got in the mail today from DDM
    Sep 02 2009
    Toronto, Ontario
    Quote Originally Posted by spector View Post
    you are right, h11 is for the fogs.
    Veteran Member Three Rings dfwhockey17's Avatar
    Jun 11 2008
    %252704%2520A4%25201.8tq%25206mt%252C%2520%252708%2520F150%2520Limited
    Fort Worth, Texas
    go with the 55w kit, I wish I did...but do us all a favor and do not go higher than 6000k!
    Jan 17 2005
    2001 S4 - 2018 Subaru Legacy
    New Jersey
    Spector, I hate to bring up this older thread but were the h7 the correct Halogen bulb for the low beams? What bulbs for the high? I don't want HIDs since I have them in my S4 already and I need some better light. I have an 1.8 if that makes a difference.
    Thanks in advance.
    Veteran Member Three Rings TomyG's Avatar
    May 07 2010
    Portland OR
    Quote Originally Posted by wheel366 View Post
    Thanks in advance.
    H7 are lowbeams, H11 are fogs... not sure on the high beams though.
    11' Brilliant S4
    01.5 Laser S4 SOLD
    flickr
    Jan 17 2005
    New Jersey
    Quote Originally Posted by Tgard123 View Post
    Thanks! I appreciate your response.
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    high beams are h7s as well
    Established Member Two Rings StyleMash's Avatar
    Mar 28 2011
    Team ace NJ
    Would you need a Dual in Dual out HID harness? And do i need the error code eliminator?
    Jan 17 2005
    New Jersey
    Quote Originally Posted by Kwarner View Post
    Thanks! I ordered some PIAA Extreme White H7s and the same in H11 for the fogs. I had the Extreme Whites in my 95 pathfinder and the difference was night and day. I can't imagine that they wouldn't be good in the A4. Very white with only a tad of blue is you actually looked at the bulb closely.
    Now, to find out how to actually replace the bulbs. The pathfinder was easy. The A4 doesn't look quite as easy.
    Sep 06 2009
    Bay Area
    actually very simple, you can remove the headlights buy removing 2 top bolts and LOOSENING 2 bottom bolts. bumper stays on.
