Results 1 to 37 of 37
Threaded View
    Aug 22 2008
    Finland / Vasa
    Cool S3 turbo on A4 2.0 Tfsi DIY:ish
    Okey so I have fitted an Audi S3 turbo (K04) to my A4 and will try to do a DIY on this as I know there are many questions regarding this and not a lot answers.
    Sadly I have not taken enough pictures of the install process so I'll just describe it the best I can.
    I will not describe how to remove and install the turbo because there are already DIY:s for that.
    List of parts needed:
    - S3 turbo
    - S3 injectors
    - custom downpipe
    - custom turbo outlet (picture 1 number 1)
    - HPFP upgrade
    - Oil lines (picture 1 number 2)
    - Vacumpipe turbo -> engine (picture 1 number 3)
    - Dumpvalve relocation (picture 1 number 4)
    - Misc Nuts and bolts
    - Misc gaskets
    Picture 1 from Turbozentrum's upgrade kit.
    CUSTOM DP:
    The exhaust flange on the S3 turbo will not fit the A4 downpipe because the bolts are further apart on the S3 turbo.
    There are S3 flanges for sale at ebay but I did not use one of those. I bought a standard testpipe for an A4 and a magnaflow 200 cell cat. I cut away the corners on the flange where the holes are and welded in new metal and drilled new holes.
    Here I have testfited the testpipe with the modified flange.
    The magnaflow cat that will be welded in
    MODIFICATIONS TO THE TURBO:
    Because the turbo outlet flange is bigger on the S3 turbo the flange will hit a engine mount.
    To deal with this you need to cut of a bit of extra metal on the turbo flange. In my case this was enough but there is a possibility you would have to modify the engine mount as well...
    Here you can se that I have trimmed down one of the corners of the turbo flange:
    CUSTOM TURBO OUTLET:
    This is at the welder at the moment but it will be similar to the one in picture 1 number 1.
    This outletpipe will connect to the stock rubberhose.
    OIL AND WATER PIPES:
    Stock water pipes do fit quite easily.
    Stock oil pipes can be bent to fit. This is what I did but I believe that the S3 oil pipes should be a even better fit.
    VACUME PIPE (PICTURE 1 NUMBER 3):
    The two holes for the bolts are wider apart on the A4 so either you can drill a new hole and make it fit or you can go with a pipe from a S3.
    DUMPEVALVE RELOCATION:
    The S3 turbo do not have an internal dumpvalve so you will need to move this. There are some relocation-kits available. I have made a outlet for the dumpvalve in the turbo outlet pipe (pic 1 number 1)
    Some pictures of the install:
    Injector tool I made from a standard slidehammer:
    I know that this is not a great DIY but it's a start and I will try to anwser all your questions...
    I will be getting my car mapped / chiped with the new hardware 24:e june so I'm hoping to make about 320-330 hp.
    2011 A4 B8 2.0TFSI Flexifuel (E85 or gas) Quattro Avant
    Stock
