Time: 30minutes-1hour
Cost: ~$120 for the spark plugs
Tools:
- 3/8" Ratchet
- 3/8" Torque Wrench
- 6" Long 3/8" Extension
- 5/8" Spark Plug Socket
- 1/4" Ratchet
- 2" Long 1/4" Extension
- T-20 1/4" Drive Bit
- Medium Philips Screwdriver
- Medium Flat Screwdriver
First, you will need the spark plugs. I had my friend order these from Worldpac for cheaper than at the dealer and I got them 2 hours later.
1. Let the engine cool with the hood open for an hour or so. If it feels warm on the top of the motor anywhere, the sparkplugs will still be blistering hot. (Learned this the hard way)...
2. Remove the air intake duct. Remove the two Philips screws in the front of the engine bay. Pull up on the rear part of the duct and then pull the whole assembly towards the back of the engine bay. Remove it and set it aside for later.
3. Remove the top of the airbox. To do this you need to loosen the hose clamp on the tube going to the engine. Disconnect the MAF connector by pushing down on the clip and then pulling to disconnect. Lift up the rubber tube that is snapped into the cover, and then finally remove the tube that connects to the front of the airbox by squeezing the connector together and pulling out. Remove the airbox cover from the car and set it aside. Now is a perfect time to either replace your air filter element or clean it if you have a K&N one.
4. Remove the two small T-20 Torx screws holding the harness to the valve cover.
5. Push down on the clips on each coilpack until the pop and then disconnect them. Once they are all loose, you can move the harness out of the way of the coilpacks. If you have trouble disconnecting them, you can push the connector towards the coilpack and then squeeze the tap to release it while pulling away. It can be tricky to get them off, just use patience and you will eventually get them all undone.
6. Remove the 4 coilpacks by pulling up on them evenly. Careful, they are fragile.
Now for the driver's side
7. Lift on the plastic engine cover starting at the front corner and then working back. There are 3 clip locations. Remove from the car and set aside. Remove the dipstick and set it aside.
8. Remove the Philips screw holding the coolant tank. Lift up the front of the tank and disconnect it from the back by pulling forward. Be careful not to stress any of the hoses.
9. Remove the two small T-20 Torx screws holding the harness to the valve cover.
10. Using the same method as before, disconnect all of the coil packs. Once they are disconnected, pull them directly out and set them aside. The one under the coolant tank is a little tricky. You can carefully pull the coolant tank a little to provide room.
11: Go around to each plug with the Socket, Extension, and ratchet (you could use a breaker bar for this as well). Break each one free then unscrew it using the socket and extension only. Once each plug is removed, set it aside and then move to the next one. Careful, they are very hot.
12. Take each new plug and check the threads to make sure nothing is damaged. Stick it in the new plug into the extension and socket and thread each one in BY HAND. Do not use a ratchet for this. If you feel any resistance, stop and try again. They should go in a couple turns before stopping. Leave them finger tight. Do all 8.
13. Set the torque wrench to 22lb/ft. Go around to each plug and torque it to 22lb/ft. It will turn about one full turn before becoming tight, this is normal. Make sure to do all 8.
14. Insert the coilpacks back in each hole and press them down until they are fully seated. Do this for all 8. Plug in the harness to each one and squeeze the plugs until they are fully seated.
15. Reinstall the 2 T-20 Torx on each side. You only want them slightly snug. Don't strip them out.
16. Reinstall the coolant tank by cliping in the back two clips then fastening the Philips screw.
17. Reinstall the plastic driver's side engine cover by clipping in the 3 clips. Replace the oil dipstick.
18. Reinstall the air filter and airbox. Can be tricky, take your time and it will go in just fine. Make sure to plug in the MAF sensor and replace the hoses in their clips.
19. Reinstall the air intake guide and refasten the two Philips screws.
20. Clean up everything and start the car. If it was anything like mine, it will idle much smoother.
