Results 1 to 16 of 16
    Jun 27 2010
    Murrieta CA
    Bought new key fob shell, trying to transfer my key blade and circuit board...
    I am sorry but I don't have any pictures (writing this at lunch time from work) but I can add some later if what I am describing is not clear. Like the title states, I bought a new key fob shell and I am trying to transfer my existing blade and circuit board to the new shell. My problem is with the circuit board. It's held into the old remote with two brass "rivets". The rivets don't seem to pull out and they don't twist out (I can turn them but they don't unscrew). How do I get past this? Do I need to actually break the rivets off? Thanks in advance.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    you will probably have to drill them
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    why not just program the new circuit board to the car?
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Jan 29 2009
    i'm guessing (hoping?) he bought an empty shell
    May 24 2011
    Wildomar, CA
    Quote Originally Posted by infinkc View Post
    Quote Originally Posted by NOTORIOUS VR View Post
    From the original post, "I bought a new key fob shell"
    Established Member Two Rings gablks4's Avatar
    May 20 2011
    Los Angeles CA
    I tried programming a new key fob to my S4 using my ross tech cable and software and it did not work. Tech support said to erase all keys and reprogram....seriously. I only have one good key and the last thing I want is to have that one not work.
    So how do you reprogram a new key fob on a b5 s4?
    Jun 27 2010
    Murrieta CA
    Quote Originally Posted by gablks4 View Post
    Maybe you can search or start a new thread instead of changing the topic, please. In this thread, I am only asking how to remove the circuit board from an existing OEM key fob which is held in by two brass pins/rivets. Thanks.
    Jun 27 2010
    2002 Audi allroad 2.7T - GIAC Stage1
    Palm Desert, CA
    Heat the brass rivets with a soldering iron very carefully and they will come out, with needle nose pliers. The rivets attach only once to a barbed plastic pole, after the circuit board slides on.
    Oct 05 2006
    Baltimore, MD
    I used needle nose pliers and they eventually came out.
    Jun 27 2010
    Murrieta CA
    Quote Originally Posted by Zachariah View Post
    Zach, you saved the day. I was nervous about the use of a soldering iron but after countless wasted minutes of trying to pry the rivets out, I went for it. It was totally amazing. It was almost magic - lol. After leaving the iron in contact with the rivet head for about 45 seconds, the rivet rose out of the plastic tunnel it was embedded in, all by itself. Both rivets did this. It was neat to watch. You are right, the rivets are 'barbed'. Thanks man!
    Veteran Member Four Rings kbS42001's Avatar
    Mar 03 2009
    01S4
    Delaware
    so my key blade snapped off today...when i get the top half of a key from ebay with a blank blade, how do i get the pin that holds it to the spring mechanisim to come out?...
    TIA
    '01 Santorin S4
    "Welcome to owning an Audi...its a love/ f'n loathe relationship...but shhhhh...it might hear you and somthing else will break..."
    Veteran Member Four Rings MDJ's Avatar
    Jun 29 2010
    TIAL S4 ** '74 Superbeetle ** '60 MGA
    So, how du ewe raplake tubaws?
    May 13 2011
    2015 BMW F30
    ^ haha
    | Autospeed | JHM | Pure MS
    Mar 03 2009
    01S4
    Delaware
    Quote Originally Posted by MDJ View Post
    Thanks, ass
    nevermind, got it
    just wanted to make sure there were no threads or other way of keeping it in there before i started trying to tap it out.
    '01 Santorin S4
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    why not just get a new key fob? you can't be saving that much money with just a shell...
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Jun 27 2010
    Murrieta CA
    Quote Originally Posted by Klum00 View Post
    In my case, my electronics were fine and my key was fine, I just wanted a new shell for cosmetic reasons. I disagree that there is not a decent price savings when buying a new shell over a brand new complete key fob.
