Results 1 to 11 of 11
    Established Member Two Rings orafalcons's Avatar
    Mar 11 2010
    06 A4 S-Line, 06 Ducati Monster 620
    Bama
    Changing Front Brake Pads... HELP!
    Got both pads on and put the front a back half of the caliper back on but they won't close all the way. I'm assuming I need to compress the brake caliper but I'm not sure how ti do it. I have the Compressor tool but I dont know where to secure it or anything... Could someone give me detailed instructions on how to get the caliper to close all the way? TIA
    2006 Brilliant Red A4 Quattro S-Line 6MT - Autospeed Custom Exhaust / Carbonio CAI / RS4 Rear Sway / Debadged / 20% Tint
    Senior Member Two Rings bitskyline's Avatar
    Jul 29 2010
    Edmonton Alberta Canada
    I used a pair of channel locks
    works just fine just squeeeeeze, oh and make sure your not going to over flow your reservoir.
    DO NOT do this to the rear, the rear needs to be spun while its pushed in.
    06 B7 A4, APR K04 kit, Exhaust, Intake, HPFP, JHM SSK, H&R touring cup kit, DXD clutch/flywheel, Forge DV, 034 FMIC, Focal/JL audio.
    Senior Member Two Rings AUDI101's Avatar
    Oct 10 2007
    06 A4 S-Line 3.2 Quattro
    Long Island NY
    No tool needed for fronts use C clamp to compress. The rears However you will need the brake caliper tool
    Autozone usually lones them out
    Active Member One Ring A4TQuattro's Avatar
    Apr 26 2011
    Alexander, Arkansas
    Quote Originally Posted by bitskyline View Post
    Spun? Do you mean the piston needs to be spun when compressing? Just curious.
    2006 A4 2.0T Quattro 6MT
    Veteran Member Three Rings J.Owen's Avatar
    Aug 12 2010
    I run -361* of Camber.
    Bucks County, PA
    make sure the cap is off the reservoir before you compress the piston.
    Expenses in F1 have gone down since the 1960s because teams don't need an extra pit crew to help the driver carry around his balls when he is not in the car.
    Mar 11 2010
    Bama
    This is all information I have. I really need to know what two points the C-Clamp or pliers should be compressing.
    Oct 10 2007
    Long Island NY
    when i did my brakes i put the C clamp over the old brake pad that sits on top of the piston and compressed.
    Hope that helps
    Oct 10 2007
    Long Island NY
    check out this DIY this is what i went by
    http://www.audizine.com/forum/showth...DIY)?p=3141202
    Jul 29 2010
    Quote Originally Posted by A4TQuattro View Post
    the rear yup
    Established Member Three Rings b7kevin's Avatar
    Jan 04 2011
    East Haddam, CT
    Quote Originally Posted by AUDI101 View Post
    Beat me to it :)
    2006 A4 Brilliant Black 6MT
    - Revo Stage 2+ - AWE HPFP - ST Coils - K&N - 034 TIP - Newsouth Vent Gauge - Neuspeed Snub - OEM DV Upgrade - E-Code test pipe - AWE Quad tip - s4 rear valance - de-badged - vag'd -
    -Wake up an address the biggest issue of our freedom. National DEBT.
    Apr 21 2009
    14 Q5, 12 A4, 14 S1000RR
    Camarillo, CA
    I did the rear brakes today and what a pain in the ass. My problem was I bought the cheap Napa piston tool. Sucked, real hard to turn. Fronts were way easier.
