Results 1 to 2 of 2
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Reference - Quick Shifter Trim Info (Pics)
    Not sure if this has been said before, but just to make it easier to search in the future, heres the definite answer on the differences between auto and manual trim.
    They are actually exactly the same lol
    Same part numbers, so the difference is just in the trim ring around the outside of the opening
    The screw pattern is slightly different between the auto opening trim and the manual shift boot
    Heres the auto trim with a manual shifter in reverse
    And the same thing but in 6th
    So if your planning on doing the swap, but want to keep your trim setup, all you need to do it get a custom shift boot made up and installed, or pickup a stock shift boot and screw it into place.
    Hope this helps people in the future.
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    Bellingham, WA
    Link to original thread for discussion:
    http://www.audizine.com/forum/showth...rim-Info-(Pics)
    -Matt-
    B5 S4, B5 A4 Moderator
    2871r'd 2001 A4 1.8t Build thread
    You may think I'm not online. But I'm always here. Even if I'm not posting. I'm always here. Scrolling. Judging.
