Results 1 to 9 of 9
    Mar 04 2009
    07 A4 3.2L Cab Ibis White
    FYI - Random Start Issues/Chocking @ Start on the 3.2FSI - What worked for me
    I wanted to share something that worked for me, hopefully it helps someone else.
    I've had random start issues - when starting the engine, it would catch, but barely, and then the engine would stumble/stall. Happened probably ~30% of the time for the first three years. Didn't matter if the engine was hot or cold.
    Nothing severe enough to bug me. Usually giving it some gas would take care of it or just restarting (sometimes 2-3 times).
    No codes, no other problems. Over the last year or so, it's slightly worse, but still far less than half the time. At high revs, it felt like the car wasn't putting out as much power as it used to, so I ran 80% of a can of BG44k through the intake and the rest in the gas (will take a shot of the hose I used later today).
    No more starting issues & mileage on highways is noticeably better - it's been about a month. Will let you guys know if it comes back.
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    What's the mileage on your car?
    Also you could be having one or more clogged injectors.
    Mike
    Mar 04 2009
    It's been happening since new (2008). In the range of ~100,000km's+/- now and no more issues (for the last month).
    Aug 26 2009
    Burlington
    I was having similar issues, but not as often as what you are describing. My car is actually at the dealer now. It has been there since yesterday and they haven't called me yet to let me know what it is. It is still under warranty, so I am not really worried
    They seemed to think it may be a leaky injector based on the symptoms I described, but there is apparently a new software flash that fixes some hard starting issues that they will likely load as well.
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    when i was at audi i remember pulling intake manis off and carb cleaning/scraping carbon off the intake valves with 17k miles...
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Established Member Two Rings abccba's Avatar
    Nov 09 2009
    BC, Canada
    Quote Originally Posted by your daddy View Post
    not applicable on the 3.2.....
    May 29 2007
    Quote Originally Posted by abccba View Post
    excuse me? yes it is! 3.2 fsi........ i have done many. eh..
    Mar 09 2011
    San Jose CA
    sounds like carbon buildup on the valves for fsi engines that everyone has been having problems with. 3.2 seem to have more of a problem than the 2.0's but i know both get it. eventually i think you have to go in and clean them off manually. what is bg44k btw?
    May 29 2007
    Quote Originally Posted by Gfunk176 View Post
    according to abccba youre wrong.... lol
