Results 1 to 10 of 10
    Sep 09 2010
    Edmonton Alberta
    Halogen to oem xenon conversion.
    just got the parts for my conversion just wondering how much time/money is average to get them installed? sorry if this has already been posted, googled it to no avail.
    Veteran Member Three Rings yayjohnny's Avatar
    Jan 18 2011
    Central Valley, CA
    It's wayyyy easily doable.
    Takes like an hour tops.
    Follow the DIY guide in taking off the bumper, and then only three T-30 screws from the hood holds the lights in place. VERY easy
    Oct 08 2010
    CA
    Quote Originally Posted by yayjohnny View Post
    Spotted a Johnny.
    Previous
    2009 GT-R | 700HP
    2008 S5 | Ibis White
    2008 A5 | Matte Gray
    Jan 18 2011
    Central Valley, CA
    Quote Originally Posted by ecrew16 View Post
    Spotted a Johnny.
    Lol what? :)
    DUH! an Audi
    los angeles, CA
    think he meant spot on.
    use the diy and attempt yourself, figure 1 or 2 hours of work to do the job; not sure your shop rates where you are but you figure 100-200.
    -randy
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Where did you get your headlights? I'm up in Fort Mac and I want to do this too, any salvage yards to look for in E-town?
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Sep 09 2010
    Edmonton Alberta
    Quote Originally Posted by Jay-Bee View Post
    Nothing in E-town lol seriously Alberta sucks....You can try Carparts.com......or talk to member on here "LowestA4" hes got a waiting list but he can get clear corner oem lights for pretty good deal. i got mine on ebay they are always circulating on there. lol probably not the best choice..
    Sep 09 2010
    Edmonton Alberta
    I would attempt it myself, however each harness has a wire that have to be run somewhere and i have no idea where the hell they would go, i would assume is would be the lengthiest part of the procedure.
    btw thanks for all the quick responses guys. :)
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by Enzo10 View Post
    I assume you got the harness needed too?
    If you didnt, you're in for a surprise. You need a harness to be able to connect car connector to the bixenon housing.
    I would say it can take anywhere between 1-3 hours TOPS. Should not take longer than that. It really depends on if you know how to do it and how "handy" you are with this stuff.
    EDIT: Just saw your latest reply. The separate wires go inside the car, behind the cluster. It's well explained in one of the DIY's out there. They are for the drivers side and passenger side high-beam "flaps"
    So you take out the cluster, you will see the harness there, and you just slide the "wires" into the right holes on the harness. All plug and play really, you just have to get the wires inside the car through the firewall.
    EDIT2: Here is a pic of where I ran the wires through. There is a rubber grommet of some sort that once you take off your drivers side knee bolster you'll see. I cut the middle of it, ran it up the cluster and thats it :)
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Sep 09 2010
    Edmonton Alberta
    Thanks to for all the info. ill post pics when i get back to town.
