Page 5 of 13 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 504
  1. #161
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by context.eax View Post
    Yes. I just installed in on my car a week ago. There was a small fitment issue so I had to trim some plastic of the front bumper plate. Still waiting for an answer from Unitronic support.
    I really like the design of the Unitronic FMIC. The whole core is exposed to air flow and will give max cooling.
    When temp dropped to 18C I could go out and log it like I did with the stock FMIC and the 3.0TDI FMIC.
    Here are the result:
    I kind of knew it would be a bit better but I did not expect 8C cooler compared to the 3.0TDI. The reason I am upgrading is that I am also upgrading my turbo to a K04. (log was made with the IHI K03)
    I have a lot of pictures in my K04 thread if you want to have a look:
    http://www.audizine.com/forum/showth...g-K04-on-my-B8
    Thanks for the graph, how much did you pay for Unitronic fmic? The reason i ask, is a 8 degree C (12.8F) improvement over the 3.0TDI hardly seems like its worth it, that small of a temp change is well within the ECU's limit of adjustment. Also, you dont really see a significance temp change until you get past 4750 rpms, so in your opinion is the 3.0tdi better suited for the stock turbo, daily driver and the Unitironic is maybe a better bigger turbo (K04 +) fmic?
    Stage 1 more than you RS3
  2. #162
    Veteran Member Three Rings slowone11's Avatar
    Feb 15 2015
    Castle Rock Colorado
    Wow awesome results!
  3. #163
    Apr 22 2012
    Norway
    Quote Originally Posted by o1turbo30v View Post
    Uni FMIC was $899 + shipping $250.
    For a daily driver the 3.0TDI is pretty good. It also gives you a stock look if you have warranty on the car. Would be hard to see the upgrade I think.
    Only reason I am upgrading is because I am going for the K04 turbo. The 3.0TDI IC will be fine on a stage 1/2 tune.
    But if you drive hard in a hot condition (like Florida) I probably would have consider a bigger FMIC like the Unitronic one.
    Remember this is only first pull. If you continue pushing the IC it might get heat soak if its hot outside.
  4. #164
    Feb 15 2015
    I have stage2 revo now and plan to go bigger turbo. So i want the fmic now.
  5. #165
    Apr 22 2012
    Norway
    Quote Originally Posted by slowone11 View Post
    Which fmic are you planning to buy?
  6. #166
    Feb 15 2015
    The unitronic now. I was looking at cts and awe.
  7. #167
    Feb 15 2015
    Well now im also looking at 034 in black
  8. #168
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    I believe 034 distributes black Wagner tuning intercoolers,. A reputable worldwide brand...
    I'm interested in this myself... Looks to be very good quality for around 700$
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
  9. #169
    Feb 15 2015
    The wagner tuning is $850 with hoses. Id like the black because my car is dark and im doing the rs4 grill too.
  10. #170
    Sep 03 2012
    Lehigh Valley, PA
    Still not a bad price!!... Unless the forge brand for ours drops in price!
  11. #171
    Feb 15 2015
    The only one i think is ridiculous is Eurocode....$1500 come on now its an A4 not an S4
  12. #172
    Veteran Member Four Rings Dub_prime's Avatar
    Sep 10 2012
    2010 A4, 2008 Passat, 2002 GTI
    Bham AL
    They used to regularly be in the $850-900 range on sale, with the turbo muffler delete and hard pipes that's a reasonably good deal. Unfortunately they haven't run that deal in over a year...
  13. #173
    Feb 15 2015
    If it was that price it would be a great deal.
  14. #174
    Veteran Member Four Rings Marko S's Avatar
    Mar 03 2015
    Any reviews on the wagner one offered by 034?
    Current: 2019 Audi A4 Allroad Technik
    Past: 2011 Audi A4 Prem+ Stage 2+
  15. #175
    Apr 22 2012
    Norway
    If my calculations are correct then this ic has a 17.5l core volume. Wonder about turbo lag?
  16. #176
    Feb 15 2015
    17 is high. I the most of the others are closer to 10+l....check your calculation again. It might be off
  17. #177
    Apr 22 2012
    Norway
    We are talking about this ic right?
    Wagner FMIC
    On the wagner page they say:
    "178% more cooling surface and 158% more volume (Core dimensions 610mm x 440 mm x 65mm)"
    and on 034M page they say:
    "610mm x 440mm x 65mm core, providing a 78% larger cooling surface and 58% more volume"
    but same dimension :)
    Anyway 6.1dm * 4.4dm * 0.65dm = 17.44dm^3 = ~17.4L core volume.
    So closer to 158% over stock than 58% as 034 writes.
    Also look at the test result. 19C ambient gives a max IAT at 26C where stock IC is 62C
    Unitronic FMIS is ~10.4L
    Will be fun to hear from some one testing the wagner IC about lag and IAT temps.
  18. #178
    Mar 03 2015
    Wagner FMIC
    Can you do a quick fmic for dummies explanation as to what all that means?
  19. #179
    Veteran Member Three Rings Carlos74's Avatar
    Mar 30 2014
    Palatine, IL
    17.4L is pretty impressive. I will be installing a CTS turbo FMIC hopefully next weekend. According to CTS specs the IC should be at 11.3 L... Not too shabby
    Sent from my HTC One using Tapatalk
    APR l CTS l EUROCODE l ECS l 034 l PODI l GFB l MAGNAFLOW l H&R l SPC l STANCE l SPULEN l HANKOOK l NGK
    IG: c_lowsB8
  20. #180
    Feb 15 2015
    Yes context.eax this is the same IC. Wow there has to be some lag there. Why would the number be so much higher then all the rest?
  21. #181
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    Wagner FMIC
    How does this compare to the AWE one? I was leaning towards that one but I'm digging this one for its looks (black).
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
  22. #182
    Feb 15 2015
    Ordered my Wagner tuning fmic today. Should be here Wednesday. Ill have pics up soon.
  23. #183
    Apr 22 2012
    Norway
    Quote Originally Posted by Sgibb16 View Post
    I could not find the size of the AWE IC.
  24. #184
    Apr 22 2012
    Norway
    Cool. Do you have VCDS to do some logging?
    Also if you could measure the distance from the IC to the crash bar to see if it fulfill the 45 degree rule.
  25. #185
    Feb 15 2015
    I dont have vcds
  26. #186
    Jan 12 2009
    Tampa
    Anyone try powerhaus intercooler and have stats and logs on that? Interested
  27. #187
    Senior Member Two Rings kmunz264's Avatar
    Dec 19 2014
    Port Republic Maryland
    Has anyone tried unitronic intercooler?
    Edit: sorry should of read through the thread first
  28. #188
    Jul 02 2012
    Fredericksburg, VA
    Interested to see a review on the Wagner IC.
  29. #189
    Veteran Member Four Rings boomtime's Avatar
    Apr 22 2013
    Audi, BMW, Ford
    Rocky Mountains
    Went back to stock FMIC and charge pipes from the Eurocode FMIC this weekend.
    The car is noticeably slower on 93 octane tune now and throttle response seems slightly worse.
    So to answer the question: is the 2.5 inch piping and core worse for lag and throttle response over stock?
    The answer is no, not from my experience.
    The eventual supremacy of reason.
    CPMB K04+e85
    Twin Turbo 391
    E36 Drift Queen
  30. #190
    Dec 19 2014
    Do you have the unitronic tune as well? I'm guessing it doesn't really matter but I'm apr tuned and was wondering if this would really matter
  31. #191
    Apr 22 2012
    Norway
    Quote Originally Posted by kyleowen94 View Post
    I have the Revo tune and the chart is from Revo stage 2 using the stock IHI K03 turbo.
    I don't think the tune brand should have anything to say.
  32. #192
    Dec 19 2014
    Okay thanks
  33. #193
    Feb 15 2015
    straight from Germany courtesy of Wagner tuning! This thing is the size of a radiator! So cool. More pics this weekend when I install it.
  34. #194
    May 21 2015
    Nissan R32 GTR, Ducati 659
    Melbourne, Victoria, Australia
    so the TDi intercooler fits straight into a TFSi?
  35. #195
    Jul 02 2012
    Fredericksburg, VA
    Moar pics!!
  36. #196
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    http://www.wagner-tuning.com/Perform...1050_p_97.html
    ^ Is this the one? If so that is gonna be sweet!
  37. #197
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
  38. #198
    Feb 15 2015
    Yes that is the one! Stealth mode!
  39. #199
    Apr 22 2013
    Audi, BMW, Ford
    Rocky Mountains
    Is that 2" or 2.25" diameter plumbing? Doesn't look like 2.5
    CPMB K04+e85
    Twin Turbo 391
    E36 Drift Queen
  40. #200
    Feb 15 2015
    Not sure ill have to measure when i install
