http://www.034motorsport.com/engine-...18t-p-392.html
-Brian
-Brian
-Brian
2010 VW GTI
Previous cars:
2003 A4 1.8T APR Stage 1+
USP CLUB MEMBER #34
-Brian
-Kyle
2005 Audi A4 Avant USP / 1.8T / Brilliant Red
2004 Audi A4 1.8T - big turbo and some stuff - gone
2003 Audi A4 1.8TQM - gone
-Theodore-
"I swear, your mom and I are just facebook friends."
-Brian
-Brian
-Brian
-Brian
USP CLUB MEMBER #34
-Brian
-Brian
H&R SS CO, 034 MS REAR SWAY BAR, 034 MS TURBO INLET HOSE, 034 MS STREET DENSITY MOTOR MOUNTS, EUROCODE 3" TESTPIPE, APR CARBONIO INTAKE, APR STAGE 2, MAGNAFLOW CATBACK EXHAUST, BLACKHOUSED & CC MODDED HEADLIGHTS, STOP TECH STREET KIT BRAKES, DEBADGED, THULE ROOF RACK, 19X8.5 VMR 708S GUNMETAL
-Brian
Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 ******************************************************************************- Address 01: Engine Controller: 8E0 909 518 AF Component: 1.8L R4/5VT G 0003 Coding: 0016701 Shop #: WSC 08144 3 Faults Found: 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 008 - Implausible Signal - Intermittent 16687 - Cylinder 3 Misfire Detected P0303 - 008 - Implausible Signal - Intermittent 16686 - Cylinder 2 Misfire Detected P0302 - 008 - Implausible Signal - Intermittent Readiness: 0000 0000 ******************************************************************************- Address 03: ABS Brakes Controller: 8E0 614 517 H Component: ABS/ESP allrad 2328 Coding: 04275 Shop #: WSC 00000 No fault code found. ******************************************************************************- Address 08: Auto HVAC Controller: 8E0 820 043 L Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 63351 No fault code found. ******************************************************************************- Address 09: Cent. Elect. Controller: 8E0 907 279 E Component: int. Lastmodul USA 0305 Coding: 00013 Shop #: WSC 63351 No fault code found. ******************************************************************************- Skipping Address 15-Airbags ******************************************************************************- Address 16: Steering wheel Controller: 8E0 953 549 N Component: Lenksáulenmodul 0911 Coding: 00041 Shop #: WSC 00000 No fault code found. ******************************************************************************- Address 17: Instruments Controller: 8E0 920 950 L Component: KOMBI+WEGFAHRS. RB4 D35 Coding: 03200 Shop #: WSC 13254 WAULC68E13A205524 AUZ6Z0B0269774 1 Fault Found: 01176 - Key 07-10 - Signal too Low - Intermittent ******************************************************************************- Address 45: Inter. Monitor Controller: 8E0 951 177 Component: Innenraumueberw. 0604 Coding: 00001 Shop #: WSC 40322 No fault code found. ******************************************************************************- Address 46: Central Conv. Controller: 8E0 959 433 BB Component: Komfortgerát T7B 1311 Coding: 11896 Shop #: WSC 63351 1 Fault Found: 01562 - Right Rear Door 59-00 - Can't Unlock ******************************************************************************- Address 55: Xenon Range Controller: 4Z7 907 357 Component: dynamische LWR D08 Coding: 00060 Shop #: WSC 63351 No fault code found. ******************************************************************************- Address 56: Radio Controller: 8E0 035 195 F Component: symphony II NP2 0051 Coding: 01201 Shop #: WSC 40322 No fault code found. End **************************************************************************************************
-Brian
USP CLUB MEMBER #34
