Results 1 to 36 of 36
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    Mathias 034 STK project RS4 + PT6262 !
    Hey Guys , I'm gonna start my build thread cause the time has come for some MAJOR changes in my B5 ownership
    I'm in the first batch of the 034 STK so very happy to share my build project with you guys for the next couple months!
    I sold my ENTIRE S4 engine to a fellow member on a UK forum including just about everything on the car going from K04's to AWE downpipes, JHM FMIC, RS4 airbox ...just name it I sold it. At this moment the only thing left in my garage is my S4 with an empty engine bay , an RS4 gearbox , a DTS and some other minor parts I kept
    I purchased a FULL OEM RS4 Long block without turbo's, manifolds and stuff like that and that's gonna be the heart of this all , this is on the way as we speak so should be here somewhere next week and ready to go to the machine shop!
    First off I wanna thank Max@034 for answering my (I think 110 emails) for the last couple weeks but in return I also made his seller balance go UP ALOT for the last few weeks so we made eachother happy
    Let's go ...
    Engine : OEM RS4
    Pistons : OEM RS4 (New rings + hone)
    Rods : Integrated Engeneering + ARP bolts
    Bearings : Glyco 034
    Main studs : ARP
    Heads : OEM RS4
    Valves : Supertech Inconel exhaust valves
    Springs/Retainers: Supertech Titan
    Headgaskets : 034 0.5 Comp drop
    Inlet Mani + TB : OEM RS4
    Injectors : EV14 Bosch 750cc
    Coils : TFSI coil conversion with 034 adapters
    Exhaust : New style SSAC 2 x 2.5inch cat-back
    Clutch : Southbend Extreme 6 puck Graphite / 16lb steel flywheel
    Manifolds : 2.8 V6
    Catch Can : AMW OCC
    Turbokit = Full 034 Single Turbokit
    Turbo : Precision PT6262 A/R .63 Ballbearing
    Intercooler : Precision 750hp
    Intake : 034 Intake + Carbon Shroud
    Additional stuff :
    Full service timing belt kit + metal thermostat housing
    034 Motorsport engine mounts
    RS4 FDP Gearbox
    ESP DTS
    JHM shifter Trio
    RS4 Propshaft
    RS4 Rear Diff
    Advanced 4:1
    Hoping to make 550whp on pumpgas (98oct) and around 600whp on Meth. The methanol kit will need to wait tough cause I'd first like the car to be running like a champ without problems and dialed in perfect on pumpgas before spending any more money
    This is where I'm at right now! Should have taken a before pic but this is literally the cleanest I could get the engine bay! The difference before and after is EPIC , damn that thing was dirty! I am gonna spray, paint and coat some stuff but it's very clean and degreased right now
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    Veteran Member Four Rings AudiForeman's Avatar
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    subscribed .
    I cant wait to see progress of this. if you dont mind me asking how much for the rs4 gearbox? rs4 engine? and where did you buy it? UKebay?
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    nice list of parts good luck man subscribed !!!!
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Feb 20 2008
    belgium
    Quote Originally Posted by AudiForeman View Post
    subscribed .
    I live in Belgium so I have these parts for sale around here from time to time
    Feb 20 2008
    belgium
    Quote Originally Posted by UkuRiSh View Post
    Thanks man! Really excited to see what it will do!
    Established Member Three Rings s4930's Avatar
    Mar 01 2012
    south florida
    subscribed! your gonna be my online guinea pig lol im hoping to be able to have a setup similar to yours!
    034 STK PT6262 BB :)
    Feb 20 2008
    belgium
    With pulling the engine and stripping everything I was suprises what a mess the whole A/C is and how stuff is involved with that + the weight of the compressor and everything got me thinking of ditching the A/C but I'm a bit undecided on this .... Anyone know how much weight the full A/C setup is if you take EVERYTHING away ?
    Aug 29 2010
    Pittsburgh PA
    YESS !!! Such a good guy to buy the kit I know you will update and keep uys well informed! Good luck and mucho HP to you.
    Veteran Member Four Rings howardfootball's Avatar
    Oct 20 2010
    '57 Ford Thunderbird
    MD
    Quote Originally Posted by Audi_S4 View Post
    I'm guessing about 100lbs. That's the common number I see when people take out A/C on any car.
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    That turbo should spool well as a .63 on the 2.8 motor. I know Dan ran into surge problems at 35+psi. Not sure your plans but 550whp sounds like a heavy boosting goal.
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Established Member Two Rings RudeJude518's Avatar
    Oct 10 2010
    Albany, NY
    In for updates!!! And pics!!!!
    Xbox Gamertag: Ya uraHERB soi
    Call of Duty when I can find time between work and taking care of the new baby.
    Jun 10 2012
    Springfield, MO
    Wow, I can't wait to watch and see progress
    May 13 2011
    2015 BMW F30
    This will be quite the project. Eager for results/progress!
    | Autospeed | JHM | Pure MS
    Feb 20 2008
    belgium
    Quote Originally Posted by viceprp View Post
    034 hit 570whp with an unfinished tune on race gas on 27psi. I don't plan on running more then 30psi anyways but it should be in the 525-550whp region when finished. RS4 Engine is also a bit more torque'ish then a built 2.8 in the head and cam department , that together with the .63 , RS4 shorter gearbox and the Duall BB'ing option will be alot better spool then what Max his car is doing right now
    Sep 17 2005
    Fremont, California
    Mathias has high flow heads and his motor will be similar to our 2.8L test motor, minus the 2.8L shortblock. But he has the RS4 upper intake components, etc.
    We are pretty confident we can hit over 600whp on 110oct at under 30psi, no methanol. The test car did 570whp @27psi before the clutch started slipping, and this was only at 7000rpm. The 4" anti-surge compressor housing should help things too.
    93/94 octane with methanol will easily push 550whp. Right now we know it does around 525whp on 91 with meth, and 93/94oct will add a LOT more to that.
    On our 3.0L GTi-RS motor (034EFI IIc, CAT cams, tubular manifolds), we did extensive testing of turbos and turbine housings to see the differences in AR's, etc. With a Precision Turbo GT35R, we tested 3 housings ( 1.02, .82, .64), all of which produced the same peak power within ~10whp. The difference was that the .64 housing produce over 100 ft/lbs more torque on some parts of the graph (down low), spooling way faster with better response, and with only ~10whp difference which can easily be changing dyno conditions.
    This is a 2.7L motor and our test car is a 2.8L motor, so the .64 housing should be even more geared. While the .82 to .64 housing change will likely be less dramatic then on a GT35R (the 6262 is larger), we have confidence it will show a good improvement all over the range.
    While some cars tend to produce more power with larger turbine housings, the Audi 30v motors seem to really like small tight housings.
    Oct 10 2010
    Albany, NY
    Quote Originally Posted by Max@034 View Post
    Seem to really like small tight housings
    Amen brother, amen.
    Feb 20 2008
    belgium
    I just had confirmation my new SSAC 2 x 2.5 inch Cat-Back arrived at Marks place !
    At first I'll be very happy if the new motor runs like a champ and the initial setup and startup doesn't give me too much of a headache. From the moment on that it's prooved to be faultless and ready I'll have it tuned to be a monster :)
    Feb 20 2008
    belgium
    New V6 Manifolds arrived yesterday
    They do look ALOT better flowing then the 2.7TT versions IRL ! Can imagine they improve spool alot !
    Feb 20 2008
    belgium
    RS4 Engine arrived on pallet this morning and is now safely in my garage = HAPPY :)
    Also my RS4 piston rings came in. Damn those Audi stealerships !!! I got a 15% discount true my friends garage and it's still 314€ for the set (6)
    Now it's time to take the engine apart and have the block cleaned and honed and assembled with the goooodies !
    Sep 17 2005
    Fremont, California
    Feb 20 2008
    belgium
    Oh yeah :) Sweetness ...
    Feb 20 2008
    belgium
    My car is currently at the bodyshop to get a full respray inside and out , in the meantime I bought me
    - Quattro GmbH 360x32mm drilled discs
    - Porsche 996TT brake calipers
    - Braided lines
    Got me some more small goodies from 034:
    Gates racing timing belt
    Metal slave + braided line
    SAI blockoff kit
    Now waiting for the complete STK to arrive , I'll make pics of all my parts when it arrives ! When it does arrive I'll start tearing down the RS4 engine and bringing everything to the machine shop!
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    What does the SAI Block off do? I thought it was only for auto cars
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Feb 20 2008
    belgium
    RS4 engines have it too. it's a whole system in the back off the engine, it's for emissions but it sucks balls so it needs to go and blocked off with these nice cnc'd plates 034 makes :)
    Jan 09 2011
    Pleasant Gap PA
    Why would you waste 30 bucks buying plates when all you have to do is get two machinist balls (from any machine shop) for less then 2 bucks. Dabble a bit of loctite red on it. And tap it into the holes. In case you were wondering this is what the factory does with the oem heads. There is no difference between auto and manual heads. One has a pressed in ball and the other doesnt. thats it. So why spend 30 bucks for shiny useless plates no one is going to see.
    Senior Member Three Rings silverman's Avatar
    Sep 27 2008
    '98 A4 1.8tqm. Bilstein pss9.
    Hartford, CT.
    ^^^ Continuity.
    Cactus green B5 A4!
    Feb 20 2008
    belgium
    Quote Originally Posted by sweets4style View Post
    I know they are there , good enough for me. There's alot of stuff I "could" make myself or do cheaper but it wouldn't look this nice and in the end of the day it's not your 30$ , there's people spending loads and loads of cash on useless things every day, nothing to worry about if it aint your $
    Veteran Member Four Rings gottaBdope's Avatar
    Apr 07 2012
    '99 Clown Shoe
    Colorful, Colorado
    sooo...updates?
    ^Rory^
    *2014 Audi S6* <- Daily
    *1999 BMW Z3 Coupe* <- Street-legal Track
    Oct 27 2011
    TOYS
    Philly Suburbs
    He sold his turbo kit.
    Apr 07 2012
    '99 Clown Shoe
    Colorful, Colorado
    Well, that's disappointing. Thanks for the repsonse.
    ^Rory^
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by gottaBdope View Post
    I'm sure he will update, but unfortunately his new chassis that this project was going in turned out to be wrecked beyond use internally. Audi_S4 decided to scrap the RS4 chassis and the single turbo project and go a different route. Someone else on the forum has purchased the kit and will be receiving it in the new future.
    Veteran Member Three Rings Brens's Avatar
    Jan 07 2012
    B5 S4, MK1 TT 225, 3rd Gen Tacoma, 3rd Gen 4Runner
    Charleston, SC
    Re: Mathias 034 STK project RS4 + PT6262 !
    So this entire project bt the dust?
    Anything you can tell us about the chassis' internal damage, Max?
    Sent from my ADR6400L using Tapatalk 2
    -Brendan
    Brilliant Black B6 A4 Avant - 5spd 1.8T - Recaro - RNS-E - VMR - Daz - Woody Insides - Clutch/ Tune - Pink Coolant
    Mar 01 2012
    south florida
    Quote Originally Posted by Brens View Post
    i bought the kit from him but my build wont be as exciting as his unfortunately... he told me that the rs4 he was planning on using was in a wreck and the damage was beyond repair. i dont think any serious damage was done to the engine though as he was planning on pulling it apart and selling it but i could be wrong.
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    This coulda been sick... so sad to see projects go under like this.
    RIP Daz, you will be missed.
    Feb 20 2008
    belgium
    Yeah indeed it was kinda depressed but in the end I got good money selling all the parts (good thing I never installed any of the parts and it was all new boxed up)
    I bought an A3 3.2 S-Line with DSG gearbox and I have since fallen completely in love with this car. It's almost 10yrs newer than my S4 and feels that way in every aspect. For now I did some minor adjustments like rimz,coilovers but have a pile of parts waiting to be installed and also the just released 034 Single turbokit with a PT5858
    The gearshifts of the DSG leave the 01E completely in the dust , some may say it's an automatic and it's a no go for a sports car but I can tell you that from all my friends who have driven my car (even in stock form) every single one was seriously impressed with the gearbox and told me they would love to have one instead of rowing true the gears. Also you gotta admit the 01E just SUCKS :)
    Mar 08 2012
    MI
    yes, it does. I love the dsg so much more...
